It is. I’ve been doing target testing based on the duration that wko5 says will have the biggest impact on the model. The real missing piece is efforts longer than 2+ hours, but if I throw in efforts from the past several years, my mFTP will bump up a smidge. I don’t think my mFTP is severely over- or underestimated given my threshold workouts.
This is what I did for Build Block 2 and it went well. I’ve got two weeks of rest & thresh, then it’s back on the horse for another mini-build block surrounding a B (or C?) event.
I’ve bumped up my (trained, wko5 modeled) VO2Max by a good 15% I started doing VO2 work. Half with the first dedicated block, and half with the second mixed block. My (trained, wko5 modeled) FTP has improved by over 20% since the start of Block 1. These are all new gains–I started Block 1 at around my all-time highs from 2022. Maybe the VO2 is revisiting old rugby territory, idk. Both Garmin FirstBeat and Sikto’s formula have modeled a higher VO2Max than wko5; the absolute value is pushing into XC skier territory, so I’m going with wko5’s lowball. Either way, the values are trending up.
87-90% is where I’ve ranged all fall. FTP and VO2max seem to be in lockstep with one another and I can’t separate them further.
I thought my weight might be artificially inflating the score, but tossing in a lower weight raises the %. I’m not sure where these coeffs come from. Perhaps whatever model they use gets wonky at higher weights.
(avg(metric(lookup(weight,now)))*0.007 + 0.0108*(ftp(meanmax(power),90)))/(vo2max(meanmax(power),90))
My operating hypothesis is that I’m extremely slow twitch dominant. How all this slow twitch translates to my high weight room maxes remains a mystery. But I don’t deal with much muscle fatigue from either lifting or VO2. And I’m not skimping on VO2 either (clearly not, given the progress). I can tell when the VO2 stimulus is good because my HR will be elevated for the rest of the day and my RHR will be elevated for 1-3 days thereafter. Also my sleep is affected.
I’ve been treating threshold and VO2 as somewhat of a continuum. I will often push threshold work into VO2 territory (eg, just hammer the last few minutes of an interval). If I don’t have much fast-twitch fatigue to worry about, why not maximize training stimulus? For thresh I string together 10 min intervals with 1 min standing butt break (thank you to @ivegotabike for that suggestion). So like, 4x10 with 1 min break between. Last thresh of the progression of Block 2 was 2x (4x10). The 10 minutes is a real sweet spot for me psychologically. During longer intervals I end up holding on and zoning out. With 10 mins I’m able to focus on emphasizing different aspects of the pedal stroke, leaning into (instead of away from) areas of weakness.
Did you do a 5x5 straight out of the gate? 5x5 is what sits at the end of my VO2 progressions. I think 5x5 & 3x6 were my last VO2 double day.
