As has been said, HR is not a great proxy for hitting VO2 max if the work bouts are short. Astrand saw this in the 60s ā work bouts under 2min didnāt produce high HR or high lactate (when the recovery periods were the same length or longer than the work interval ā when the recovery interval is half the length of the work interval or less, things change ā a lot).
Itās all about the manipulation of intensity, duration, and recovery interval.
Bouts under 2min need to either be higher than the power output you can actually sustain for an ~6min effort or you need a rest interval that is more like 25% of the work interval.
The set I posted above didnāt hit me hard until the last 10 repeats, because the recoveries were :30. Right now I donāt think I could hold 390w for 6 minutes, so the 390w work intervals were about the right intensity ā but I needed the :30 rest to hold that output.
No one was pricking my finger or measuring my oxygen consumption, but by the 12th interval, my breathing was deep and labored for most of the recovery interval ā the same breathing sensations I would associate with the last 2min of a 4min hill repeat at 390-400w. Subjectively, that tells me that I had done enough work on incomplete recovery for the first 15min of the set to make me work at a high % of VO2 during the short 1min work intervals over the last 15min.
Iād argue that if you are work matching the efforts (youāre 115% of FTP or higher ā the same effort you would do for a continuous ālongā VO2 interval, and youāre getting the same amount of time in zone during the set), and if the recoveries are less than or equal to 50% of the work interval, ok, do enough of them and youāre going to elicit VO2 max eventually.
Iām going to do sets of 1min on/:15 off next week, and 2:00 on/:30 off the week after. Iāll do some repeats on my 4min hill in early March and tell yaāll how it goes.
Seiler has been YouTubing on this lately. Motivated me to dig out my own copy of Textbook of Work Physiology for old timeās sake.
