VO2 max workout intervals too short?
I started doing a few VO2 max workouts, but I have a doubt if they are effective - for instance ‘Changhua’ , 8 intervals over 45’, but each one is only 1 minute followed by three minute rest. Not surprising my HR did not go up a lot. Shouldn’t it be rather 3-4 min and a1:1 rest ratio? I’m on a plan to improve FTP but also want to develop VO2 max, which is of course correlated
1m intervals are probably not going to elicit enough time at vo2 max to improve it.
@Chris77USA Is your workout plan just now starting to assign VO2max workouts? The first few may seem easy. Walk down the hill. They will get hard…don’t dig yourself a recovery hole now & then find out you are unable to answer the call when the VO2max workouts start to really get hard.
Are the 45” intervals all out sprints? The pattern you describe with long rest intervals is more akin to SIT rather than HIIT. It can boost your VO2 max, despite the shortness.
Do you switch off ERG for VO2 Max intervals ? I sometimes do, to push my HR up, VO2max IMO a maximal oxygen intake zone and less of a power zone.
Just did 5min intervals :skull_and_crossbones:, I’d say enjoy the shorter ones while you can, it will build up!
The first 15 seconds are called sprint at 310W, then 45 sec at 255W. TR estimates my FTP at 245. Started a program to improve it two weeks ago. Even if the wattage is higher, it is so short my heart rate only goes up when the 60 secs are almost over
Haha, ok will do. Most workouts TR plans are sweet spot around 5min. I find those much harder though
No I don’t. When the power goes up why should I switch erg mode off?
Try it and see if it helps. PS lots of folks VO2 Max zone (optimal air intake zone) is higher than what a pure power based model predicts, despite it being spot on for threshold etc. It depends a lot on the individual. If you search you’ll find a lot of discussions on the topic. As I say try it and see. ERG is maybe setting a ceiling below your actual capabilities.
It is the nature of SIT. It still nevertheless improves your VO2 max.
