Tubeless tape for 17mm wheels
I normally use Stans tape. But I’m trying to tape the wheels on my 2014 warbird and they are 17mm I’d. Stans only goes down to 21. What tape should I use?
When I tape my wheels I usually use tape that is 3-4 mm wider than my wheel’s ID. So if that Stan’s measurement is the tape width and not the recommended wheel width then it should be good.
Thanks, I looked and they recommend it only down to 19mm
Orange Seal comes in 18mm Rim Tape | Orange Seal
Tesa 4289 in 19mm
Extra work, but…cut it?
I tried that. It ended up a hot mess.
Dt swiss is available in 19 mm. Imo the quality is better than many other brands, for example orange seal.
