For what’s it’s worth I pasted a screenshot of that cloudripper workout of yours into AI along with your max heart rate and it thinks you should have rated it moderate or maybe hard…
Asking ai what ones RPE is? Isnt the whole point of RPE to ask what the person felt for the workout?..
That’s the idea - but some people don’t seem to struggle ![]()
That’s his average HR not max
. And yes predicted RPE is mostly Easy and Moderate which isn’t, I would expect moderate to hard
They said their max HR was 203 - so I stuck in the screenshot of the workout, stated the max HR and asked what the expected RPE would be…
I’m not by any means saying that this is what everyone should do - just showing that that data combined with the stated FTP and max HR does not tally with a ride that would usually be marked “easy”.
I think they need to calibrate their RPE responses.
As it is the software is correctly predicting the RPE response based on it knowing they the athlete responds to the survey strangely.
Maybe the issue isn’t the warning itself but how it’s presented. A small percentage struggling shouldn’t automatically make a workout look unsuitable for everyone.
I missed that part..excuse me
AI RPE, I love it!! ![]()
I rate hard rides accordingly. i.e. the prior week, 5:15 hours at .77 IF, I rated hard.
Cloudripper -1 is 1:45 @ .8 IF, I rated easy per TR’s guideline of:
- This ride felt easy and non-taxing, requiring little effort or focus. You could repeat the ride and pass it without issue.
Don’t copy my homework though, to try get the AI to tell me what I felt though. ![]()
1.45 @ 0.8IF should not feel easy though? ![]()
Either your FTP is too low or you are not rating the workouts in a typical manor - in your case I think both - your FTP is too low and you don’t answer the RPE surveys in a typical manor ![]()
The issue seems be that it’s trying to find you a 1:30 workout that you will rate “Hard” but it can’t find you one because you seem to either rate them “easy” or fail them.
I think the answer in your situation is to either do one of the TR FTP tests or manually bump up your FTP until Cloudripper -1 feels “hard” and then mark it “hard”.
Another course of action would be to keep your FTP where it is and then manually choose a harder alternative - you will have to ignore the “high probability of failure” warning and prove to the AI that you can get through a high intensity workout without quitting.
I do think the cause for this whole issue is your interpretation RPE - but I don’t mean to victim blame - the system may need to be improved to better account for athletes who answer the surveys the way that you do.
Cloudripper and easy shouldn’t be used in the same sentence. Maybe the trainer/power meter is over-reporting watts.
I suspect there’s a lot of what you describe going on. It eventually catches up with people and results in dissatisfaction with a plummeting AIFTP when workout failure or underperformances do inevitably occur.
Kev has a good point and it is one i have had to utilize especially when just signing up after time away. Just pick workout that you think you can do, that will be somewhere in the ‘Hard’ to maybe ‘Very Hard’ - you know you can do it, you know it will be tough, it will feel like a good workout that challenged you. “Let me show this AI what I’m can do!.. hold my (beer)carbs”
Then do it… rate it accordingly (adjust % Intensity if needed to get to Hard… or higher up to Very Hard).
Do that once or twice with a couple training zones (vo2, threshold, sweetspot) and it should hopefully account for your new power curve you have generated (hopefully updated 6wk graph) and have associated RPE for you. Then like a coach it can know your fitness better and give good workouts moving forward. (in theory)
Except it doesn’t. I did this for six months and birthing changed. Each week I had to change the work out and/or intensity/recovery
