The Bike Fitting Mega-Thread
That seems ludicrously frequent to me. I’ll pay attention next ride, though I suspect that when I’m on rolling road without significant gradient changes, I’ll spend 5-10min or more without moving my hands. The only time I’ve had numbness lately is when I’m riding a really awful sealcoat surface (there are several of those around here) and getting continuous vibration through the bars.
I seems like a job moving your hands around that much.
I ride mostly on the hoods but even there I’ll slightly shift my hands around. But I’m not going tops to hoods to drops every 30 seconds or every minute
On a leisure 5 hr gravel ride I probably spend 4:30 on the hoods, 20 mins on the drops, and 10 mins in an aero hoods position. A race dictates a good amount more on drops/aero, although our races are typically so hilly, an extensive time is still on the hoods climbing
Any change in position is usually dictated by terrain or advantage of changing for aero, rarely, comfort. I don’t really recall ever experiencing any kind of hand numbness or issues, and I ride in a pretty aggressive position with a 407mm reach and 566mm stack bike + 100mm -6 deg stem.
Changing that often for comfort is probably due to either a fit issue, lack of saddle time, or lack of core strength.
Hey! Quick question. My mtb saddle height is 69cm and with that my knee angle when i measured it was 140c and all feels spot on. But when i use my gravel bike with same saddle+pedal+shoe setup the 69cm height seems excessive and i end up at 68.5cm and when i measure knee angles they are also at 140c with this height. Only difference between the bikes are that i run my mtb saddle 35mm more forward than on gravel bike. Does that make any sense at all, that running saddle forward 35mm allows me to raise saddle 5mm, or am i being crazy or i have some measurement error somewhere?
Measured saddle height from where to where, exactly?
Same exact saddle on both bikes?
Same exact crank length on both bikes?
Generally speaking, saddle fore-aft will not lead to different saddle height. Assuming you match everything exactly above (components & measurement locations), there will be no delta from different fore-aft.
center of bb to 8cm saddle width. Same saddle, same cranks. Only difference is i run xtr pedals on mtb and xt on road bike, so 1.5mm of stack height difference there. Maybe wider q-factor has something to do with it ?
Yup, stack height and stance are likely factors at the very least.
And to add one more consideration, aside from a possible fore-aft delta, keep in mind handlebar reach & rise. Notable differences there may lead to different hip rotation on the saddle along with tension in the rear chain. Any of those may lead to a different effective leg angle as a higher, shorter hand position may be different lower leg tension vs longer & lower hands.
