Sweet Spot Progression
Wildernesses 101?
Rookie mistake with long FTP tests - I didn’t expect to last 50 mins, especially with the ramp, so I had to get off the bike for another work meeting (the perks of working from home). I manually adjusted intensity during the ramp so that I was pretty smoked at the end, but think next time I’ll just do Progression 3 (just hold target FTP til exhaustion basically).
I like that approach - I usually have to travel every once in a while and will use those as deload days, just doing easy rides on the hotel Peloton. In your 16/5 or even 23/5, I assume you still have days off in the load days, right?
Wasn’t planning to follow Plan Builder, just used it for inspiration. Cool, your plan sounds like what I had in mind too.
If I did this, probably no dedicated Vo2 block after that, right?
Maah Daah Hey 100 - very underrated race in my opinion.
Thanks all for your input - curious if @kurt.braeckel @brendanhousler @CaptainThunderpants @WindWarrior @RONDAL have other thoughts as regulars here in the thread :slight_smile:
I’ve been doing my long tests progression 3 style (started before reading about the KM protocols). Start a little conservative, settle in, and after 15-20 minutes or so do some on-the-fly adjustments and push power up a bit.
If you decide you want to go this route, flip the VO2max block and do it now. Six weeks is about the time for adaptations to hit, and you want to be able to work after that.
So you could 3wk VO2 -7-10 days recovery - 4wk aerobic build - recover - 4wk aerobic build - taper.
You could also mess with your microcycles and make them 16on/5off, and do that five times. Easy way to do that is start a build block on Saturday then end on the third Sunday, five days recovery time, start again on Saturday. I’m actually doing this now when I have 9 weeks till big events, so I’ll get three distinct build cycles in. (Just went further and saw BBT made this same recommendation). And yes, you program as normal in a 16/5 rotation… generally I’ll get 5-6 hard days and at least 3 long rides in that 16 day pack, add in 1-2 recovery rides, 1-2 days completely off, and 2-3 neuromuscular/endurance maintenance or tempo, and bang on.
Works well for older dudes like me.
Do you literally ride 16days in a row, then take time off?
When I do 16/5, I ride Saturday through Saturday, Sunday off (unless I have a race), then Monday through Saturday or Sunday. Usually one or two days off, and then a recovery ride or two. Keep a long ride in each week, interval sessions depends on race schedule… Really all of it just depends on the race schedule. I don’t run 16/5 in base/offseason, just when I know I’m going to be going hard a lot/racing and need more recovery time overall.
I can post my plan for my upcoming block here when I’m back at my comp.
I really like the idea of these, gives a good time horizon for concretely planning out blocks until the race, but also small enough cycles that I can sketch out workouts for those 16 days.
I’ve found that a few days with easy riding/off the bike are good enough to recover, so I’ve been riding hard or long most weekends anyway.
Good point - I’ll take a few days to get back into it after my 9 days completely off the bike, then do VO2 work first. The recovery of VO2 work can presumably still be riding in Z2, just stay away from intensity?
Then after, I’ll go back to aerobic builds through SS/Threshold progressions and potentially starting with more specifc race prep (over/unders, hard starts, burst in intervals, etc.)
I’d be very interested in that. Thanks a lot for your response! Excited for the coming months :slight_smile:
Would be good to see this. My schedule/life has fallen such that I am having a recovery week this week, before a race next Sunday. Interested to see how you prep the week before races, and would you do different in my position.
I’m trying to do extensive work to push out TTE, but races are sporadically appearing here and there. Am in 2 minds about moving threshold intervals into the long Sunday Z2 ride this week. I could then move the SST earlier and maybe some short VO2 efforts on Weds/Thur…
This has been my recent plan - went from a big z2/z3 base period for 3 months into the vo2 block, based on the adaption time people were talking about, and the opportunity to then build FTP under a higher ceiling. I had an A event late April so wanted to get the benefits of the VO2 block under my belt before then (sadly that has gone away for this year though :frowning: )
Worth bearing in mind the experiences of many, myself included, that these VO2 blocks wipe you out! It was a full 2 weeks afterwards before I was ready to begin threshold work. I’m only a few weeks into that threshold build but feeling good and hoping a couple of blocks of o/u’s and longer threshold work will drive up FTP a little. Worst case it will be good event specific work for some long GFs and a week in the mountains in the summer!
My sweet spot progression is not sexy at all. Basically, 80 - 90 minutes total time at power in erg mode, while keeping HR in the 140 - 145 bpm range (80 - 84% max HR with a 150 bpm ceiling). Add 3 watts per week on the Kickr…to Tempo and Vo2. As long as heart rate stays in the right range I keep adding 3W with each week. If it doesn’t, I go for another week at the same power. I’ve been up to 4.5 hrs of Z3+Z5 in a week at times.
I think Z2+Z3+Z5 is the best way to go for me…strictly a time trialist.
Here’s my three weeks. I am technically starting my 16 working days on Friday, so my recovery 5 day block goes Sunday to Thursday, same for the next block. Most of these workouts are notional, so they might change. Also of note, I’m working on raising volume, but being conservative with it, so first I’m lengthening the long rides and trying to hit two of them per week. That’s why you’ll see a couple of 1 hour neuromuscular days in there. Eventually those will stretch out to be longer when I’m able to handle more hours overall. Note that I have a race NEXT Sunday but I can’t make it, so that’s my one true day off in this block.
I also don’t schedule all of my pre-race weeks the way this week is scheduled. I’d probably have more intensity than I do this week, but this is a true recovery week coming off my last three week block (and allergy season!).
Finally, the last week (starting on the 11th) is my “normal” schedule for a training week right now.
Interval - Long - shorter Z2/Z3/neuromuscular - recovery - Interval - Long - Off.
Happy to take feedback - every coach needs a coach!
Between yours and @Bbt67 schedule examples I’ve been inspired to use your shorter rest week idea.
The 16 days on etc doesn’t work for me as my training is scheduled 90% around my kids school/preschool bookings and 10% work.
But using the shorter rest week could/should work really well to allow me to align my rest for the school holidays and work. Plus, by the time I get to my rest week I usually really need a couple days completely off the saddle, but am ready to go before seven days.
Hopefully it works well. It was a nightmare setting it up as TR was having some wild hissy fits and injecting multiple extra plans. I’ve had to redo my whole year, but that’s another story😅
Yeah, I can imagine the TR hive mind doesn’t play well with asymmetric micro cycles relative to weekly calendars. That would be a pain.
Thanks for sharing - always interesting to see others’ schedules for some ideas :grinning:
Or if you’re me, interesting to see how little I ride/train compared to others
:joy:
A young man’s folly :rofl:.
I know you jest :wink:.
I really think it’s a dangerous thing that I’ve seen a lot of, especially when I was a bit younger. You have to have exceptionally thick skin/high self confidence. Otherwise you’ll inevitably be jealous of people’s time to train, or natural gifts/genetics.
Up until a few weeks ago when I left my full-time job to focus on building my coaching business, I rode 5 days a week and between 8-10 hours, usually 450-500 TSS, so this volume is new for me, too! First week I did 13hrs and 630 TSS, then fell off and allergies hit me like a truck last week. So again, this isn’t my normal… yet. :slight_smile:
Without races, here’s how I would schedule 16/5 for myself. YMMV:
Interval - Long - Recovery Ride/Rest - Interval - Long - maintenance Z2/Z3/neuro - recovery ride - Interval - Long ride - rest day - Interval - Long ride - maintenance Z2/Z3/neuro - recovery ride - Interval - Long Ride
Start recovery week: rest day - recovery ride - recovery ride/rest day depending on feeling - low Z2 + openers - Z2 + short duration testing…
…into work weeks. Long duration PDC testing would go in one of the work week interval sessions.
Build the long rides out to 4hrs each, interval sessions are 90 minutes+, intervals 20-45 min then Z2 before or after depending on goals, maintenance/neuro ride 1-3 hours, recovery no more than 1hr.
I could definitely see scenarios where riders who are not growing volume (as I am) would be able to add an additional interval session, but obviously THAT depends on what types of intervals we’re talking about, too.
I’ve always struggled with the TR rest week approach of a week of just short z2 work. Looking at some other plans they all had some form of reduced volume intensity
This last week I tried something a little different and had rest days Sun-Wed and had 2 days completely off the bike and just did a couple of short walks, day 3 was Goddard -4 openers and then a day with 1 hr easy endurance Colosseum -4. So only 4 days effectively.
It seemed to work well as I smashed my hardest o/u session yet on my first day back and feel good. This was after 3 weeks ‘on’ based on 2 hard days a week and as much z2/low z3 volume as I can accumulate around it. For context I’m 51 but dont work much.
In general I think TR’s recovery weeks (at least in their old canned plans) are/were too hard. But you could say that about every part of their old plans… The design was simply increase TSS incrementally and then decrease it one week, rather than putting much thought into actually structuring proper recovery.
