Strength Training
So I’m currently buying up a small home gym so a couple of ideas:
Bench:
Amazon basics flat bench for $55.
https://www.amazon.com/AmazonBasics-WB-Flat-Weight-Bench/dp/B072Z1WN4S/ref=sxin_2_ac_d_pm?ac_md=1-0-VW5kZXIgJDEwMA%3D%3D-ac_d_pm&cv_ct_cx=gym+bench&dchild=1&keywords=gym+bench&pd_rd_i=B072Z1WN4S&pd_rd_r=4849d911-577c-4188-a300-ee691388f271&pd_rd_w=Oaon7&pd_rd_wg=4HLx4&pf_rd_p=516e6e17-ed95-417b-b7a4-ad2c7b9cbae3&pf_rd_r=9MYHGHDGP5FVBDTRVHRX&psc=1&qid=1584712589
Flooring/Mats:
You may be able to find cheaper alternatives and idk where you live, but in the US Tractor Supply has 4’x6’x.75" stall mats for $35 each.
There are a couple $100 squat stand options on amazon also. Though if you feel you need spotter arms or a full rack then that gets a little more expensive.
Depending on your need for a nicer bar or not you may be able to find some for cheap on a local free and for sale page. Also used is probably the best way to go for plates. Especially if you only need steel and not bumper plates. I’ve usually seen them for $0.90/lb in the US though that may be different if you live overseas
Thanks for the ideas. :+1:
Secondhand isn’t particularly appealing and could be tricky actually picking up/paying!
What would be the deciding factors between steel and bumper?
Since you mentioned 5x5 I’m assuming you’re not doing olympic weightlifting movements or crossfit. If that’s the case and you are usually careful with putting down your deadlifts then you should be fine with steel plates on some stall mats. But if you do these lifts, are rougher with your deadlift drops, or are worried about the floor that you are lifting on then I would at least get a pair of 20kg bumpers to soften the drops then you can get the rest of the plates steel to save money.
Also, I have been using this website to get ideas for cheaper or alternative equipment ideas.
P.S. For barbells I have usually seen CAP and Titan as brands mentioned for decent sub$200 barbells. But if you spring for more Rogue Fitness’ Rogue Bar 2.0 or their Ohio Bar are both very well reviewed for more in the $250-$300 range.
A few years back, I got a cheap squat rack from Amazon and that thing made me super nervous. (Plus the smell and manufacturing quality were definitely indicative of chinesium) If I were going back in time, I’d make sure my squat rack was a stable, better quality version. I can live with a super basic bench and get weights second hand, but when I started squatting heavier weights, my concern about the rack failing were high. I ended up selling a lot of my weight lifting equipment when I moved so I don’t have it anymore.
Yeah, it’s fair comment - like most things I’m thinking, how cheap can I do this? And also like most things you get what you pay for, so if sub £500 is too cheap then it is what it is. :slight_smile:
Maybe I could get a lighter setup and do higher reps - I think most triathlon coaches advise high reps for strength training…
Yeah, I mean, dead lifting or squatting 250kg has diminishing returns for a cyclist, so you gotta factor in whether you are lifting to help your cycling or lifting just to get super strong. I struggle between those two masters because I’m built like a lifter but I want to be a scrawny cyclist sometimes too. If you find yourself serving the Strength master more often, then maybe going to a weightlifting gym is the right choice over a home gym.
But with this virus going around, of course we make do with what we have!
There is plenty of research that supports the idea that lifting with lower weights can still build strength, so you shouldn’t be missing out. :grinning:
Check out Mira fit.
I picked up a power cage, bench, Olympic bar and around 120kg of bumper plates for circa £500. Delivered.
Everything is out of stock now!
All gyms in the UK were closed last night…
Wow, we’re panic buying gym kit now :flushed:.
Has anyone fitted their bike set up within a power rack?
I’m trying to plan space, I have two bikes in the cave at the moment in front of the screen and Apple TV. If the bikes could fit inside the power rack when I’ve cycling, then I could flip them up and out of the way when lifting…?
Think of how nice it would be to reach up and grab the overhead bar after and especially hard interval…I say go for it
Does anyone have a recommendation for an app with good plans / routines for strength / mobility maintenance?
I find it much easier and more efficient if I just have a routine to do, and don’t have to think about it. Plus, when I build routines myself, I fall into doing exercises I “like”, and avoid exercises I don’t like.
Athlean-X has a nice body weight program out. It is one of his recent YouTube videos. My wife started it today.
Been using it for years, close to 10 years. It is fantastic and always improving.
Cool!
So I’m having a bit of a laugh creating so makeshift free weights today.
So far I have available;
1x old shower rail (pole)
8x Driveblocks 4.2kg (each, handheld)
4x tyres 215/55/16 10.5kg
1x Sack of Compost 50l 17.5kg
2x Front wheel/tyre 19.7kg
2x Rear wheel/tyre 20.8kg
2x large terracotta urns (unknown)
And from that I’ve managed so far;
5x5 pull-ups
5x10 over head press @ 21kg
1x5 half deadlift @ 42kg
3x squats with urns (too heavy to hold Atlas ball style) :hot_face:
0x squats with wheels (fell off pole on the clean and jerk) :smile:
Somehow the old shower rail threaded through my kids swing hooks can withstand my 81kg body weight for pull-ups!
Bar is only 5ft so I can’t get a second set of tyres on it.
Brilliant! :grinning:
I am planning to do the same thing with a squat rock and rollers. That is whenever a vendor has a squat rack in stock again. This whole country is sold out of gym equipment — it is amazing.
Yeah it’s a nightmare finding a barbell.
At 10:30 I got this email…
Saw it at 11 and clicked the link…
:weary:
Even if you could get the barbell, you probably couldn’t get a plate anyways. We are a state of non-essential business closures and they showed a local fitness equipment store just after it was announced. Massive lineup and they said they were sold out of all barbells, plates, kettle bells etc. I managed to order a set of 20" barbell handles but that was over a week ago. Plates, if available, would be be costly to ship. Anything used online goes right away
Just wait though. There will be a flood of barely used equipment on online classifieds in about 6-9 months
