Stages StagesBike SB20 (Smart Bike)
I am super curious as well. Would love to know, but not sure they’d answer a non-owner’s question like that.
I submitted a ticket to Stages asking this question. Will report back when I get a response
Here’s Stages response:
So you were correct
Great to confirm. Thanks for asking them and sharing here :smiley:
Flywheel speed is proportional to foot speed…the SB20 is physically a single-speed. If resistance goes up and flywheel speed stays the same, then you’ve also raised your power. If resistance goes up and power stays the same, then flywheel speed goes down.
There may be some kind of technical wizardry like PWM giving some smartbikes more realistic “momentum” under virtual gear changes. The 50lb flywheel in the SB20 likely makes it more difficult to implement something like that.
IOW, when you shift gears in real life and maintain power, your wheel speed stays the same. On the SB20, the wheel speed drops…you’ve basically added gravity or modified the slope you’re riding on.
Have been eyeing the SB20 now when I saw that they have a sale (2200 euros) on it from Stages themselves.
One issue though that keeps popping up and keeps me from buying it is the whole power meter issue with it reading oddly if forces are applied that are no “straight down” if that makes sense?
Is this something anyone has had issues with?
Or any other issues related to the PMs that might be a reoccurring issue?
FWIW my SB20 agrees pretty closely with both Assioma Duo and Vector 3. Typically within 2-3 watts. Yes, I don’t have a weird pedaling style. Garmin says my PCO is -2 left, +4 right.
This is completely insane and is clearly happening to more than 1% of the population.
I wish they would detail the proper foot position.
Depending on where my cleat is on my shoe can change the reading of the Stages by 20-30 watts.
I know people have gone into this deeply, but here’s what I’ve observed for me:
-The wider the Q factor, the higher the power (the more I move my cleats in the higher the power)
-Possibly lower cadence/higher torque, the higher the power
-Seat height may make a slight difference
-Didn’t notice much difference going to a shorter crank length
-Discrepancy seems worse, the higher the power.
Stages did tell me they replaced a lot of the power units on the early releases and they are sending me new power units. We will see if that’s better.
Who uses pedals that are 65mm? Jesus.
All I know is that my fit has me push my cleats as far back and inside as I can (increasing my Q factor and making my PCO +10ish). At 300 watts according to both Vectors and Assiomas, the SB20 ends up being 20-35 watts high.
Got the replacement meters. In addition to being kind of a PITA to install (well, the right side anyway), they provide nearly identical results to the first set. With my cleat set up as instructed by my bike fitter, the Stages is 10% higher than Assioma Duos at 300ish watts calibrated by me via static weight test.
Unfortunately, the degree to which the Stages is out seems to be torque dependent, so I’m not sure how useful it actually is as a training tool.
It’s really too bad because (aside from the shifting mechanics) I actually really love the bike.
Hopefully Stages will do something to make this right for folks who are experiencing this problem.
What do you mean by this?
Yes. In fact, most of my testing has been done with Vector 3 pedals with Rally SPD-SL bodies. Both sets of pedals seem to generally agree with one another. At around 300 watts, the Stages is 20-35 watts high. Here are some samples with the Assiomas and the V3s:
DC Rainmaker Analyzer
https://analyze.dcrainmaker.com/#/public/519328e6-3704-4085-5182-446665a394cf
The closest I’ve gotten is with the V3s with my cleats moved roughly to the center of the shoe on a longer ride with slightly lower effort (PCO: L +8, R +3. For me, normally L +15, R +7) Still 10+ watts out:
https://analyze.dcrainmaker.com/#/public/ee6847dc-6ee0-43a7-58a1-aafd882b0d1c
I would like to hear more about this. I am so frustrated with my SB20 that I use it less and less these days and have reverted to my Kickr or rollers when I actually care about measuring watts accurately.
Do you own the Duos? Can you not ride the SB20 with these if you do? That is what I do and have no issues.
I recognise the inaccuracies of the SB20 power meter but the above negates this and will still give you the benefits of the bike you like
Yep, and I’ll probably have to do that.
However, there is the other element to this: full price ($2899) was paid for a bike that promised accurate power measurement, something that other smart bikes have generally done acceptably well.
I have a big problem with a product that doesn’t deliver on its basic functionality.
Without the ability to accurately measure power, this bike may be worth $1000-1100. Not to mention the cost of the power meter pedals that I now have to use on there, I’m out $1800 in my mind.
So, yes, I can work around it, but it’s not cool and not right.
Has anyone tried using something like this gel under the feet to get a bit of compliance / comfort?
So, I’m now on my second pair of replacement meters. Interestingly, these are much closer than the first two. I have no understanding as to why that’s the case. So far, after two rides, the Stages is “only” reading 5-6% higher than my Assiomas versus 8-12% for the first two. Nothing else has changed. Cleat position and rider have remained consistent.
Is it possible that they cherry picked some meters that might read lower? Have they half-fixed a problem?
I haven’t done a deep dive on the data yet, but I’m curious as to how well they track across effort levels.
Another hypothesis is that the batteries arrived drained some and the power is reporting low as a result (another know issue with the SB20). Unfortunately, I don’t think I’ll be able to check that today as my legs are toast from four straight days of riding for extended periods at 90-95% threshold.
Just started using mine, does anyone find sprinting (yes I know never great indoors, but I enjoy zwift races) really strange on the SB20? I found after the initial speed increase in the flywheel it feels as though it tries to add a ton of resistance for some reason and slows down your cadence? No erg mode, just free riding in Zwift.
