This has been my experience as well. Flawless performance since spring on Rival AXS.
You definitely have some air trapped in the line, once you figure out how to bleed it, and shimmy the bike up and down to work the air out, they will work much better.
So I checked this, turns out the calipers themselves were set very far back. So pulling the lever in moved the pads, but they just had to move very far. If that makes sense.
So took the wheel off, gently squeezed the levers a bit to âpopâ the calipers in more, and they are great
no bleed required!
Great to hear you could fix it. Enjoy your bike. Rival AXS eTap is a great value IMHO.
Iâm been a shimano lad for life, and am looking at the rival groups now.
Few questions which will be obvious for Seam users!
if you buy a bike with 1x are the levers the sam should you want to swap to 2x at some stage? Just requiring a front axâs derailleur and complete 2x crankset.
where is the best place to cut weight from the rival groupset? Iâve searched everywhere for weights, but there doesnât seem to be much precise info.
I have a set of new Zipp 303 Firecrest with a shimano free hub is it simply a matter of purchasing a xdr freehub-Approx $90?
Kind regards
Gg
Yes, the levers and everything by the cranks is identical. It is really as simple as buying a new crank, a FD and pairing it.
The crank. Get a Red crank and youâll save a few hundred g. I donât know the weights off the top of my head, but I think the Red 1x crank is about 200 g lighter than my Force AXS crank.
Yes.
What @OreoCookie said, especially re: the crankâŚthat thing is a damn boat anchor. Hell, even the old Rival crank was heavy and IIRC, the new one is heavier.
Crank!
Yup. I would have gone for a Red crank for an extra $120 if it hadnât meant waiting an extra 2 months (on top of the 4 months). Iâm still eyeing Red crank arms and try to convince myself that spending 250 ⏠for lighter cranks ainât all that bad. ![]()
This.
I have Force AXS with the same problem. They are great until the pads wear, then the lever throw before contact gets to be bad enough the lever makes contact with the bar at the point of max braking. Not dangerous, yet, but annoying.
Iâve had the bike in the shop several times to try and fix this, as well as a few bleed attempts myself. Nothing lasts. The shop was finally able to get the SRAM to warrantee them. Sadly, replacements wonât arrive until spring.
Now, when it gets bad enough, I pull the wheel and put in a pad spacer thatâs a touch thinner than the rotor, and squeeze firmly. That usually works.
Park tool has a good video on how the system is supposed to work: How To Clean Hydraulic Brake Pistons - Tech Tuesday #104 - YouTube
I tried cleaning the pistons, and it made no difference.
-Tim
Maybe a new RD as well depending on what comes with your bike. The XPLR RD is 1x only.
