Sram AXS creak noise
No sound at all on the big ring… not even at 500w+
Good idea to get it on a trainer, I will try that later.
Bike has 10 months, around 5-7 thousand km
Just heard your video. Sounds terrible. Don’t know if that’s the problem but it’s worth checking. If it’s coming from the BB area, then the small ring would put a different angular pressure on the BB. I am not saying that it is it but again, worth ruling out.
Also just tried taking out the FD completely to make sure… still creaking :weary:
Maybe the chain is rubbing somewhere, but not the FD?
If you put it on the trainer, can you put your phone underneath, so you can film the chain/chainset while you’re pedalling?
The other thing to check, how slack/tight is your rear derailleur when in the small ring? Maybe the chain is too slack.
Also, have you checked the small chainring for crack/damage?
The fact it makes noise consistently when you are at 3:00 makes it seem BB related though, and the sound does sound more like a bearing/bushing than anything.
Pedal threads greased?
I changed the pedals for another ones… still creaking
Is it possible you have a little lateral play in your crank axle?
I had a sound just like that on my AXS group, turns out I had forgotten a spacer. The crank was moving in and out slightly, causing chain rub at only one part of the pedal stroke. I couldn’t find it when it was up on a stand, but realized it when I put it on a trainer after noticing that lateral play.
Good idea. I am going to take the bike to a Specialized store next week and report if they find anything…
Are you sure it’s the BB area? If not…
Is your chain too long? Are you RD pulleys hitting the chain as it S through? Is the chain routed correctly through the RD arm- not hitting the supports?
Is it only in the bigger rear cogs? Is there a sound when you cross chain?
If it’s the BB, from that video, I’d say uneven chain ring wear or something with the BB/Crank isn’t seated well. It’s odd that the noise is 360deg.
You checked the preload ring on the NDS side to make sure it’s taught, right? That would slide the crank a bit to the side when you shift.
I have swapped the chain, rear derailleur, took off the FD, even swapped the cranks for another ones from a friend! I think the only thing left to change down there is the BB. Even after all this, the sound is still there.
As I mentioned before, the noise only occurs when stepping on the pedals, the part when you put pressure (2-6 o’clock), so it´s not 360. The sound comes all over the cassette.
Any good news on this?
I have a race this weekend, so I didn’t want to leave it at Specialized. Next week I will leave it with them and update if they find anything…
Chain hitting the FD cage. So either cage height, rotation or l/h.
I took the FD off the bike, the sound was still there, so unfortunately no.
Any news? I have exactly the same problem.
I was using the crank and chainrings for thousands of kms without an issue. Now, I put them on an old frame while my carbon frame is being repaired. Although it previously worked flawless on that frame, too, I’m now suddenly getting the same noise while on the inner chain ring.
DUB bottom bracket is almost new, shows no obvious damage and it would be strange that the noise is only audible when on the inner ring, but I can’t think of anything else that could cause the noise.
I haven’t gotten the bike to the specialized mechanics yet… kinda low on time lately, but the noise has been decreasing over time :confused:
I plan to take it as soon as I have some time, and will update. If you find anything please let me know too!
I replaced the bottom bracket, sound is still there as before. I don‘t know what to try next…
Try your rear derailleur hangar and your rear derailleur attachment point. Regrease both.
So, to update everyone and in case someone comes here in the future, I have mixed news: I don’t have the noise anymore… but I don’t know why.
I kept riding my bike for around 2-3 weeks after posting this and the noise just kept reducing gradually. After around 4 weeks I can’t hear it anymore.
As I mentioned before, I changed almost everything on my bike to no avail. The only parts I did not change were the frame and the BB. I have not idea what was it… but thanks everyone for the help. If this happens to me again or I see a problem, I will update.
