Hey Everyone,
Does anyone know if it’s possible to set the installation angles for a set of Garmin Vector Pedals without a head unit? I picked up a pair used clearly without doing enough research.
Or perhaps, can anyone suggest the cheapest head unit possible that would allow me to properly calibrate the pedals?
Thanks,
-Nick
If you are a TR user I believe that as long as they are torqued to the right spec all you need to do is open the TR app and start pedalling and build to 90 rpm. Once you start seeing a power number than click on the pedals under devices and calibrate. The process is the same on my Wahoo head unit.
Thanks!! I’ll give that a try!
Thanks Guys!!
When I initially popped the pedals on, I saw 0 power and started troubleshooting.
I replaced the batteries to reset everything, and sure enough after only a minute of riding, power data started coming!
Also - as for the crank length, I used the vector firmware update tool, which let’s you set the crank length.
I’m in business!!
Thanks again for the help!
-Nick
