Thinking about sizing down on my next bike (Likely an Epic 9). Currently ride an Epic Evo 2022 - Medium. It rides good but frequently I feel I stand too tall. Testing a size Small in my area is tough. I ride a 51cm road bike and a 52cm gravel bike and can’t be happier about my fit. I wonder about your experiences and insights regarding this.
What do you mean by “stand too tall”? That seems more like a stack issue. BTW I’m 165cm and ride a medium Epic 8. The reach difference between S and M is significant (30 mm).
What stem do you use? I’m around 177 cm tall and ride a medium Epic 8 and feel I’m definitely about maxed. I ride with a 90mm/-6 degree stem. I love the fit and handling of the bike and it’s phenomenal on flats and climbing, but sometimes does feel a bit aggressive on more technical descents. Granted, that’s what the dropper post is for, plus my skills could use some polishing for sure.
Yeah, I was in a similar position, but that’s how I liked to ride the bike. I could have ridden a large with a shorter stem..
I was riding 80 - 90 mm stems on it.
I’m now riding a medium/large Trek Top Fuel with a 70mm stem, so my reach with the stem is 535 – right between the 80 and 90mm on the Epic (530 and 540mm).
Get ready for all the “you shouldn’t be riding anything longer than a 50mm stem” comments
I’m in the same boat you are. The last bike I owned that felt like it fit great was a 2020 Mach4SL. I ran it with a 70mm stem and that thing could handle on rails and punch well above its weight.
If I compare it’s geo to the new bikes, most all smalls fit within the wheelbase and reach of that medium Mach4SL, even the new Mach4SL in small is closer.
Yesss, LOL. As someone with long legs/short torso and have ran anywhere from a 30mm stem to an 80mm stem on the same Diverge it’s all about ignoring the static and meeting the rider where they are at. That being said, I prefer a smaller bike and to tweak fit adjustments via cockpit. OP, my take is that some adjustments you will actually not notice as much as people will make you think, if the fit is dialed. Right now my mountain bike has a 70mm stem on it and it’s not any “sketchier” or slower via testing than the shorter, stock config.
The Evo 7 has a slightly shorter reach than the same-size Epic 9, so you aren’t getting a full size-down difference in reach. I think that would work well for you.
Having had an Epic 7, Epic 8/ 8 Evo and now a 9 all within the last year, I had them all in a size large and sizing felt consistent across all of them. When looking at the 8/evo8, I test rode a medium as the Spesh chart had me right on the border of med and large but the medium had me feeling too front heavy and always feeling like I was going otb. The smaller size was a clear negative on handling.
That said, based on what I’ve found. If you’re playing with the idea of a different size, try find one locally in a 7/8 or 9. While the 7/8 won’t be exactly the same, as far as positioning yourself between the wheels you’ll know straight away whether you feel too far forward.
FWIW, the evo 8 has remained in the garage as a light trail/party bike where the 9 is 100% race focussed. If my epic 7 was an Evo (it wasn’t) I would’ve just kept it and put flight attendant on it, saved an awful lot of cash and had 95% the epic 9 experience.
The wheelbase has been the number I keep looking at. The feel of my older bike has been what I’m chasing, and like I said above, that keeps going back to a smaller frame.
I ride a L and prolly should be on a XL if a bike shop sized me. I had an XL prior and it seemed so unresponsive and like an oil tanker w no snap. I run a long post and long stem but feels great to me. Similarly I’d like to test ride an XL again w newer geometry but it’s difficult to find in a demo.
Yes, good point. The issues I want to address are:
Standover
Tight Turns
Front Lift in steep climbs
Issues one and 3 are solved by the geometry of the new Epic 9, either S or M. So for me is a compromise between solving the tight turns issue or preferring the stability of the longer wheelbase.
I don’t have a stability issue but it could be a situation where “I don’t know what I’m missing out”
