Oh I’m definitely on the wax train. I just feel like the entire process is somewhat overhyped by Josh and Friction Facts. I won’t change back to lube. I also have a pretty powerful ultra sonic cleaner and feel it doesn’t do that good of a job. The mineral spirits method is time consuming but it’s the gold standard to me. Do 4 chains at a time it’s not so bad, but I do clean waxed chains periodically.
What solution are you using in your ultrasonic bath? Are you heating the water?
I usually run the ultrasonic cleaner for 7 min, then flip the chain around and run again for another 7 min. Then I just rinse under a faucet. Gets the chain super clean.
I tried a gun parts cleaning solution that at one point was recommended by Silca, but found it didn’t work nearly as well as the Simple Green HD.
I saw this video was released by Silca today which provides suggestions on certain additives and care for the chain waxing process when rain/cold/snowy weather is to be expected. Makes sense. If someone is planning to do a significantly long ride/race, or ride in them regularly, it would be reasonable to add some of these products.
The video and the concept of adding Synergetic to the wax is pretty interesting for cold or rainy days.
I did wonder if just putting Synergetic directly onto a waxed chain might get you most of the way there without contaminating the wax in your pot. I realize Silca said just put a strip chip in to bind it up, but now your paying for the third of the bottle of Synergetic and a strip chip.
As the temperatures start to drop here locally in Ohio, i may try just adding some Synergetic directly onto the waxed chain and see how it feels and holds up.
Has anyone here actually noticed any degradation of wax performance in the cold? I rode a lot of miles last Pennsylvania winter and never had a hint of an issue. FWIW, I use paraffin with PTFE added. I also re-submerge approx every 150 miles (240km). Is adding Synergetic another solution in search of a problem/market?
silca hot wax takes forever to break in in freezing conditions based on my experience, once it even was squeaking after a fresh wax. In my experience Gulf wax works much better for fat biking, works fine at 0°F, breaks in easy, don’t have to worry about contaminating expensive wax with salt and still lasts 8 hours or so of riding.
You may not be putting it directly on the chain, but you are absolutely getting degreaser on your chain.
There is no need to use degreaser on a properly cleaned and waxed drivetrain.
Laughed when this came out. Summary, to make wax work in the wet, use oil
When I’ve ridden in 0-10 degrees Fahrenheit I felt like my chain had a lot of extra resistance and it was waxed, but it could have also been that my legs were frozen. I have a podcast interview with Josh tomorrow and I plan on asking him what would be his recommendation at really low temps.
Anything above 20 degrees I’ve never felt any extra resistance
@chasethebiker - if you get a chance please ask him if simply applying some Synergetic over a waxed chain would work heading into either a really cold day, or a day that has rain in the forecast?
To me that would be a really easy solution if those are not typical days you ride in and need a quick fix for your chain.
So after today 35km morning ride I run my finger through the chain and it’s clean again
So I conclude after application the leftover residue will flake off itself after about 80-90km or 3 hours ride
I use drip wax on my MTB and gravel bikes, but not my fatbike. I think the wax solidifies too much in the cold and flakes off too easily. A friend of mine (anecdote, but instructive nonetheless) rode the ITI one year on a waxed chain, and had several instances of broken chain until he replaced the chain and started using wet lube. Riding in the snow is also quite clean, so I find using wet lube isn’t as dirty as riding in the dusty summer.
After talking with Josh, he said if you’re biking in really cold weather (around 0 degrees Fahrenheit) you should add half a bottle of Silca Synergentic lube to your wax and that will make it softer/perform better at cold temps. If it’s just one or two cold rides, or more around 32 degrees you can add just a splash of Synergetic into the wax mixture or directly on your waxed chain.
You can use “waxingwithwark” and save 15% off the Silca website also if you need to buy a bottle
Thanks Chase for the follow up. Much appreciated.
I don’t tend to ride on really cold days but do get out at times when just above or below 32. Just putting a little Synergetic directly onto my waxed chain seems like the simplest option.
Ive been using super secret for a couple years now amd really like it. Chains stay clean, last longer. Silcas hot wax is supposed to be the same a super secret, except Super Secret has a liquid carrier in it for application.
My question is: is there really any reason for me to move onto hot wax? How is it better, since its supposed to be the same stuff?
Yes
Even if you were to soak your chain in a pan of drip wax, when you pulled it out some wax will run out of the space between the pins and rollers.
With hot waxing the chain is submerged for good penetration and more wax stays in the right place when removed.
The application will last longer
I hot wax and then use Super Secret to top it off before eventually cleaning and then re-hot waxing. For me this is a pretty good compromise but I do find I need to reapply Super Secret after most rides (typically 2 - 5 hours for me).
@gpl has talked about using Super Secret on a clean chain (not hot waxing) but found it took multiple applications for it to really work its way into the chain. It’s definitely a good lube but works out to be a lot more pricey than waxing in a pot.
Silca did a video on this. Short answer is they recommend applying 3 times, but ride your bike once before applying the third coat to compact the wax. Then the chain will have all the wax it can hold internally.
I started out with a Silca Pre-waxed chain and then was using Super Secret Drip, but when they had their pot on sale a few months ago I purchased that so I could hot wax once in a while and use the drip between hot waxes. I actually found it easier and cleaner to just hot wax all the time and stopped using the drip
