PSA: DT Swiss issues Recall notice on certain ERC/CRC/HEC wheels via Escape Collective - Upgraded from Stop Ride
DT Swiss issues Stop Ride notice on certain ERC/CRC/HEC wheels via Escape Collective
Following a few reported failures of “spontaneous delamination”, DT Swiss has issued a stop ride notice on the ERC, CRC, and HEC wheels with rim depths of 35 and 45 mm.
The notice exclusively applies to products manufactured and delivered from September 1, 2024 and onwards. Wheels with DT Swiss’ ID serial numbers 2,750,000 or higher are affected.
Now upgraded to a recall affecting the following products
Official recall has been published on the CPSC site. Might be a few more wheels than originally mentioned.
This recall involves DT Swiss Carbon Fiber Road Wheels. The wheels have model codes ERC 35mm/45mm, CRC 35mm/45mm, HEC 35mm/45mm, and ARC 50mm/55mm/65mm. These wheels were sold aftermarket and as original equipment on various high-end road bicycle brands. The DT Swiss ID code and the model code are located on the wheel rim on a small label located on the outside of the rim which, indicates “DT Swiss ID” followed by a 7-digit code. All wheels with DT Swiss ID code 2740000 or higher are affected by this recall.
