Plan Builder – Training Load Warning when rearranging workouts
Hi,
I’m new to TR and I’m trying to set up a training plan for a Gran Fondo (130 km, 2,000 m elevation), aiming for around 7–9 hours per week with two intensity days.
I’m having trouble understanding how Plan Builder evaluates my schedule.
With exactly the same weekly volume (7:00–8:15 hours, 358–405 TSS), I get different results:
  • No warning: Mon Easy, Tue/Thu Hard Intervals, Fri Endurance, Sat Dynamic Endurance.
  • Overtraining warning: Mon Easy, Tue/Thu Hard Intervals, Sat Dynamic Endurance, Sun Endurance.
The only change is moving the 90-minute endurance ride from Friday to Sunday.
My questions:
  1. Why does this trigger an overtraining warning when weekly hours and TSS remain identical?
  2. Is this intentional behavior or a limitation of Plan Builder?
  3. How should I configure my schedule if I want two intensity days, Wednesday off the bike, a long Saturday ride, and some flexibility for strength training?
Thanks!Příloha od uživatele
My best guess would be that the AI thinks that 4 days of training in a row would be too much, and would prefer you break the week up into 2 day and 3 day groupings.
What happens if you put the 30 minute workout on Wednesday and the 1:30 workout on Sunday? That would at least be more in line with the typical TR way of scheduling things.
I don’t understand how the Plan Builder works. I would expect to simply specify which days I’m available and how much time I have on those days, and then have the Plan Builder schedule the training based on that availability—rather than having to figure out how to structure the days myself…
Well, it does. It gives you a recommended schedule, but it also warn you if you chose to change that schedule and it thinks you are planning to do too much.
So, as long as a red warning doesn’t appear, everything is fine and the plan can remain as is? Or is there any recommendation regarding this?
Another question: how much of your training history does TR have? You mentioned you were new to TR, so it’s possible that TR just doesn’t know your capabilities, if it doesn’t have much history. And are you a master’s athlete? If so, that might contribute to the situation, also, as having your two hard interval days scheduled with only one day between them is likely the issue TR sees with your latest schedule iteration.
I don’t think the Plan Builder AI IS that smart and I just started ignoring the warning.
I train five days a week. Three hard days, two endurance days, TR knows my past data yet every season I still get the overtraining warning.
This led me to just give up on it and just do the time that I know works.
I’m not sure how much of my training history TR has imported, or whether it has imported all of it. However, the weekly schedule is fairly similar to what I’ve typically been doing, so I assume it has.
The issue is most likely related to the distribution of intensity. I tried moving the second intensity day to Friday, and the warning disappeared (see screenshot). I was just under the impression that hard intervals shouldn’t generally be scheduled the day before a long ride.
I’m new to TR, and yes, I’m a masters athlete who needs a bit more recovery time. I’ve been cycling regularly for about a year and a half and have been using Xert for my training over the past year. Now I’d like to try something different and see how well it works for me.
So far this year, I’ve logged 376 hours on the bike.
Imported activities will show in the calendar so you can go back and see what’s there.
looks good:
4,014total
23TrainerRoad
3,991other
