Hi all,
Quick question - I’ve added an event 3 weeks outside of my current adaptive training plan window. I can’t seem to manually update the start and end date of the current plan so adaptive training doesn’t seem to be adding in workouts up my last event.
Thoughts? Do i need to cancel current plan and re-build with the new event included? Is there just a time delay with TR servers to update full plan? Will it sort itself out eventually?
Thanks
John
Hey @johnborton1,
Did you get an answer to your question? I have the same issue…
I have a number of events chosen for the year, and I was hoping to build out the full year as much as possible (realizing that there will doubtless be adjustments along the way.)
So I’m not sure if this would work, but could you update your current A event to the one you would like to create and then add back in the old event?
I recently updated my plan from an A event in May to a different event in June and it all updated OK.
