What is the current status of the power deviation mentioned in GPLama review, and the possibility of it having to do with the temperature sensor?
Has it been fixed?
Have read a few reports of them getting very hot, with or without associated failure so Iād want to be sure theyāve fixed that before buying one.
Is buying a jet black volt not cheaper any more?
Iād imagine thatās itās like with any product. Not 100% of them would be absolutely flawless
Thank you so much for the response.
So Iām assuming itās then still an ongoing issue that has not been patched.
I think Iām to much of an analytical person to not be bothered by a slight number deviation, so I will look at alternatieves.
What would be looking at out of interest? Kickr core? Tacx flux?
I have been considering the Elite Suito (similar price point at least here in EU) or the Kickr Core.
Iām also in the search for a mid level DD trainer. Really canāt make up my mind. Itās between kickr core and hub for me although those inaccuracies mentioned above put me off the Zwiftās product a little bit. On the other hand⦠Iām 47 yo dad. Not GT racer! A couple of watts here or there wonāt matterā¦
yes, if I wanted to do something that dumb I could have put a 12-speed Shimano compatible cassette on the HG freehub of my Kickr v3 and destroyed some chains and possibly cause excessive wear on my Red AXS eTap crank and cassette. I mean, drivetrain components are cheap, right?
And readily available, tooā¦
Man, itās now nearly impossible to look past the Hub for anyone but the most serious Zwift racers IMO
Good info about the Hub firmware update in this article:
Are these still looking like the best combo of value and performance for the budget conscious direct drive turbos? My current wheel on saris M2 is just so noisy and eats expensive tyres so want to replace it for winter.
Been looking at this too in the last few days (as the weather is suddenly cooling down and the roads are going to get a lot busier when the schools go back next week).
I think it is ⦠in europe the Zwift hub is 499+25 delivery with a cassette. From reviews I get the impression that itās not quite as accurate as the āmid-rangeā trainers that are around 600 (Elite Suito, Wahoo Kickr core, Tacx Flux S) but itās better than the cheaper but similar looking JetBlack/Explova models.
The two other trainers I find interesting are the Decathlon d500/d900 (no reviews, similar specs and hopefully will be in the winter sales) and the Saris H3, which is a top-end trainer that has been available below 600. I actually saw it for less than 500 before the summer but hesitated as I wasnāt sure if Saris are still going and providing support.
Iām happy to be corrected on any of the above! Iām planning to wait until Black friday, but will be keeping an eye open for any good deals on the above models.
@timb34 600 is a terrific price for the Core as many of the components are the same as Wahoos top models. I have one and have been very pleased with it.
Do any of these direct-drive trainers provide a distance cycled when using TR?
I have an older stationary bike that I generally like, but none of my apps (TR, Garmin 1030, others) are able to produce distance metrics.
They do, but distance isnāt a good metric we recommend using for indoor training as we arenāt actually moving anywhere. The estimation of the distance youād have moved during a trainer session will vary depending on what gear combination youāre using.
We do offer Virtual Speed and Distance for Strava, which gets that estimation closer by using your power data to give a more lifelike estimate of how fast and far youād have ridden outside.
We have more info on speed/distance on indoor trainers in this article.
Iām very happy with the hub. Bought in on release day and have been using it ever since, initially with Zwift and TR at the same time with BT/ANT+ - no problems at all - and nowadays with TR only.
Since the firmware update that shipped auto-calibration among other things, I believe that the biggest flaw has been dealt with to the extent possible without modifying the hardware.
If you are a pretty high-level athlete, you might have other demands but for a time-crunched low-volume plan rider with a sprint power far below the 1800 watts max and who doesnāt plan to zwift competitively, I have not once regretted the purchase so far.
Sounds promising! Think Iām leaning towards this over the volt as I canāt find a v2 yet, and although the wahoo is using top spec components itās is almost 50% more when taking into account a new cassette.
The Zwift Hub is the same as the Volt v2, though Zwift have their own firmware.
I have a Volt v1, it seems fine, but I havenāt anything to compare it with. Power values are a little lower rhan my stages, up to about sweetspot, but that might be the Stagesā fault.
The thing to be aware of with the v1 is that disc brake bikes likely donāt fit. I had to make a modification to make it work. I believe the v2/hub have changed the shape of the housing, which makes it work out of the box.
