New wheel on trainer
I have a vortex and it works. If you’re not on the main floor of said apartment and you like your neighbors…
Look for the 4iiii trainer
or find the older version stac zero … they’re the most silent ones and as mentioned by someone else, it works with magnets so wouldnt be compatible with carbon wheels.
  • Little known, but it’s also not recommended for aluminum rims with pinned joints. That is because the steel used in the pins is problematic.
  • They say you need a welded aluminum rim, with no pins, for proper use. So it’s a bit more tricky than just picking any aluminum rim wheel.
