New Shimano Di2 Dura-Ace R9200 & Ultegra R8100
The ONLY reason I like the idea of wireless is because of simplicity of the setup. Just 2 cables (of tubes if hydraulic brakes).
I personally dont mind having a wired system. If I were making a bike from scratch myself, I would preferred the simplicity of wireless…
but thats it…
I suspect the whole “wiredless” approach is also driven somewhat by pro preferences, i.e. pro mechanics having to run wires through an entire team’s frames (40+ bikes), or a larger battery not needing to be charged everyday (I imagine it is a huge chore to get a full team’s set of AXS batteries charged after every stage of a Grand Tour, you’d need upwards of 20 plug-ins). Shimano will always be trying to sell components to a large market, but their professional team input also goes a long way. We forget that if you are looking at Ultegra and Dura Ace level components, you are looking at groupsets that are specifically designed for racing, and that includes all of the logistics in addition to the obvious factors like weight, ergonomics, and shift-speed. If you want a groupset without a racing focus, there are options out there.
Anecdotally, I’ve been on more rides where people had a gear cable fray/break (maybe 3?) than people had di2 issues (zero). Not sure what the failure rates are in the wild across the population be both mechanical and electronic have their failure points. I think electronic just gets blown up more because it’s ‘new’ and lots of bike people like to be elitist about their 10spd campy mechanical steel bike with external routing.
In 30 years I have never seen a cable fray or break. Is this an offroad thing?
Def not an off road thing. This actually happened the day my Di2 kit came in. Mechanical knew it was done for and decided to be spiteful
Frayed cables in the newer Shimano internal routed cables (R7900, R6800 & all similar models since those, up to and including the latest R9100 & R8000) is a fairly common and known issue.
  • There is a very small radius bend in the shifter that can lead to severe fraying (that degrades shifting performance) and can quickly turn to a full break if not addressed.
  • That bend overstresses the winding and leads to relatively early failure compared to other shifter designs.
  • It’s common suggestion to replace the cables in this style shift more frequently to reduce the risk of issues. I’ve seen frays start on my own bikes, and plenty in our shop over the years. Not rare at all, IMO.
Ultegra shift lever thing. I’ve been on at least three group rides where it happened to some. General rule of thumb - replace your cables about once a year and f you ride 400 hours/year.
Definitely not. It happened to my mom twice in maybe 3 or 4 months on ultegra 6800 (right shifter) and has happened to me twice this year on 105 r7000 It’s definitely a real thing.
You typically get ~3-5 hours of weird and inconsistent shifting (doesn’t go into the smaller cogs easily) before it really breaks.
+1 for 6800 cables deciding to explode in the shifter.
Wow, I’ve been running the same 7900 drivetrain for 20 years and never seen it. I do change out my cables every couple of years though.
edit - strike that, I’ve been riding 7700 for 20 years (9 speed - not internally routed through the lever) Explains why I’ve never had it happen to me. However, I’ve never seen it happen to anyone else either…
I keep forgetting that I’m a tinker, for example my last gravel bike was a SS D/A bike with a goat link and a 11-36 cassette and a N/W chainring. I’ve never used a clutch until recently
Pretty sure Mark Beaumont rode across Africa with Di2!
I forget which article (cyclingtips?) mentioned limited availability at the end of October 2021, but when I asked my wrench he said next March. Looks like the quickest way to get the new 9200 is probably on a new bike :man_shrugging:
Link to a new thread related to just the power meter cranks:
Can someone explain to me 2x12 with standard road / road compact cassette gearing? (please don’t bother)
12sp 11-12-13-14-15-16-17-19-21 -24 -27 -30 223gr (does the 16t gear really add any value??)
11sp 11-12-13-14-15 -17-19-21 -24 -27 -30 211gr
11sp 11-12-13-14-15 -17-19-21-23-25 -28 193gr
10sp 11-12-13-14-15 -17-19-21-23-25 175gr
10sp 11-12-13-14-15 -17-19-21 -24 -28 185gr
I totally get 1x12 wide range, but it looks like 2x12 narrow range is completely unnecessary as implemented. I like gearing range, but the steps in the basic cassette lack value-add. I don’t see 1x12 helpful over 1x11 until you you’re at 11-34+. I just don’t see the need for 2x12sp unless you’re trying to run bigger rings on the front or a bigger chainring spread. Shiamano has the chainring spreads the same as prior and has dropped “full” 53/39t altogether (and consolidated their DA only pro gearing), leaving only “Mid-Compact” and “Compact”.
vs a 10sp “straight deck” - you’re just peppering in unnecessary gears and yield two extra low gears in sum. If you look at 10sp 11-28, which is great to use, you really only get a 1/2 gear lower. Shimano basically added 40gr of cassette to their road cassette over 10sp and 11sp (not worth it for the 16t; but maybe for the 28t vs 30t)
48t x 11-32t flat road cyclist… :slight_smile:
28 is the bailout gear! They’re putting you in 52/36 to begin with…. That’s the bailout gear! You’re always in bailout gear. 36/28 is double bailout. 36/30… how can you look a Belgian person in the eye? Or even you 19yr old self? :grin:
Yeah, and I think Shimano’s focus on pro road racers is actually limiting them. That’s why they don’t have a good do-it-all groupset like SRAM does, that’s why they were late to the gravel party and IMHO still haven’t cracked it. And that’s why they are still ignoring the 1x trend on road bikes.
Shimano seems to be proud of offering 54/40 chain rings to the public, but nothing smaller than compact. No proper large range cassettes either. IMHO this is misguided and a mistake. How often do you want to pedal at speeds >65 km/h on public roads? (For the record, that’s the speed I spin out at with my 1x setup.
I actually would have liked to try that back then. I also would have liked to try the various semi-automatic shifting modes, too. But the loaner did not include any cables nor the Bluetooth module.
Even the least fit riders I know including a lot of AARP members who don’t give two hoots about their performance can get up just about anything with their 34x34, I’m not sure who this wider SRAM range benefits practically speaking.
Also as someone who owns both 2x11 Di2 and Eagle AXS i will give my experience. Took the MTB for an easy ride yesterday on a flat gravel path. Tried to keep HR in endurance zone and spent a hell of a long time gear hunting because the jumps in that 10-50 cassette are HUGE. I would never want this kind of gearing on the road, it’s not a limiter on MTB trails but was really frustrating yesterday. MTB is a different story but I don’t see what road bikes have to gain from 1x that makes up for the downfalls
my college daughter recently informed me that she can get an AARP card and all the discounts :rofl:
I’m bigger rider and going up hills on 33x36 was better than doing the DeathRide on 34x32 (65rpm for 8 hours baby!!!). The Tarmac is 35x36 so a little better than the 34x34 upgrade I had on the Domane before selling it this year.
Shimano vs SRAM is mostly a wash for me, but I truly dig the aesthetics of SRAM Red AXS crankset & power meter. And the clutch = no chain slap so far. Definitely warming up to the closer gearing. But I’d ride either of them to be honest.
