Let’s assume for a minute you are a coach.
Your client tells you, a SS workout with a nominal rating of 2.4 was perceived moderate.
One week later, the client tells you, a SS workout with a nominal rating of 4.8 was perceived easy.
What conclusions can you draw from this? No idea? Same for me . . . and the “AI” (= software learning model).
Good feedback is an important part of the loop.
My guess is, using the offered answer options as intended will improve the situation.
That being said, consistency of the feedback is also important - so when you change your answers from just “easy” and “moderate” to the full (appropriate) spectrum, this change will also (at first) disrupt the learning process of the model.
It will take a while for the model to adapt to your new ratings. For this period you are probably best off adapting the suggested workouts towards what feels like progressive overload to you.
In my case (different kind of trouble with the learning model), it was mostly settled after one 4-week block.
Is it inconceivable that feeling a little fatigued made a 2.4 workout feel moderate, and then being fresh for a 4.8 to feel easy? The responses reflect the perceived difficulty. It was noted that all my responses are easy or moderate; also, the workout levels are not progressing. It seems like this is in alignment.
Have you always rated using just easy and moderate? Or is it recent?
That’s been pretty consistent, rating easy to moderate. I have rated hard or higher but that’s not common. Maybe my ratings are skewed low.
I’d say so. Exclusively using two out of the five available survey responses definitely seems like a unique approach.
Would you really not consider any of the workouts you’ve done as hard? ![]()
As I said, I have rated hard and higher but infrequently, which is my perception of the RPE.
The latest predictions were even worse in the wild drops. It initially predicted a +37 watt increase! Is anyone confident that with a 4-year history of TR-tracked training (plus the history it imported), an increase that large is realistic in 4 weeks? On the morning of my last scheduled threshold 6.3 workout, it predicted an FTP of 257, which was pretty stable for a couple of weeks. I completed that workout at or above the target, rated it easy because it was. Immediately after, it gave me a prediction of 247. Tell me that makes any sense. This gives me zero confidence that the training zones will be appropriate. I want to emphasize I don’t care what the numbers are as long as they make sense. The data it produces is complete nonsense to me as a software and electrical engineer.
Do you mean the VO2Max workout you did yesterday?
You did that one on a yellow day and even though you rated it easy it doesn’t tell the AI anything since you always rate easy or moderate. If you add the fact that you failed a similar workout last week, keep in mind that the AI doesn’t know if you heat trained, and had a lot of yellow days I’m not surprised that you have the same problems.
It all feels a bit “I have changed nothing and my problems haven’t miraculously gone away”.
Yes, my mistake in calling it a threshold. So you are making my point for me. That workout failure caused no change in the prediction. How would you explain the 10-point drop in the prediction after a successful workout? It is not the fact that my FTP is not changing; you are not actually responding to the major focus of the post. Your focus seems to be on a single workout failure, and whether or not I worked out on a yellow day, and passed. And if I am ranking them easy or moderate because they are, does that not send a signal to th e Ai that maybe it should increase the targets?
Truly don’t mean this as an attack timdave13 but I just gotta say, that calendar is absolutely chaotic. There is very little if any consistency there for your body to use to drive any kind of adaptation. What there is plenty of though is a heck of a lot of fatigue. It doesn’t surprise me that you’re not seeing the results you want.
Also from reading through the thread and looking at your calendar I think it has to be said that you are very likely either misunderstanding the RPE rating system and how its meant to be used or maybe you’re deliberately gaming it? Don’t know why you anyone would do that but plausible explanations for honestly rating a VO2 workout as Easy aren’t immediately springing to mind.
If that most recent VO2 workout was truly Easy I wouldn’t expect to see the apparent significant jump in heart rate for the hard intervals that is clearly visible. Something is amiss, either user error or what I don’t know, but it seems as though the AI is (understandably) struggling to make sense of the data you are giving it.
There has been many examples lately where the AI reduces the AIFTP prediction regardless of athletes successfully completing their workouts. In most cases that seems to be because the AI fears overtraining. That’s why I focus on yellow days and mentioned a failed workout, on a yellow day, which was the same (similar?) as the one you did this week that gave you the drop. This is all linked.
Another thing that I thought about yesterday. If your workouts truly has been easy and moderate for the last 8 months, the thing that seems most wrong is the fact that you get a suggested AIFTP increase in the first place. If I saw a block of planned workouts all expected to be easy I would expect the AIFTP prediction to trend towards 0, or even a reduction. Doing only easy stuff doesn’t make you stronger.
I think we are saying similar things now. If the workout stimulus is not sufficient, there will be no progression. And if I have been telling the AI that they are not challenging, I would expect it to make them more challenging to force that adaptation.
The most significant gripe I have, as has been all along, is that a +37 increase was predicted, which seems crazy to start with, and then the prediction was adjusted down due to lack of stimulus? The only thing that does make sense is that if it is using HR to infer the difficulty (harder) and use that as an indicator that the workouts are harder than my RPE, which is mostly based on how my legs feel. It has been hot, so my HR may be higher, but the effort does not feel that hard, so if I don’t perceive the higher HR as harder, I can understand this.
My 2 pence, without reading the entire thread but looking at the calendar. I don’t think outdoor workouts can deliver the quality of data needed and or compliance with a workout is often tricky. I would, if possible, bring one key workout indoors and be consistent with that, e.g. a weekly vo2 or threshold.
I do 2 key workouts indoors and 2-3 days outside doing endurance and the system is working brilliantly.
The quality of the fitness gain of the workout is definitely not the point of this thread. Here is the perfect example of my complaint. I went to bed last night with an FTP prediction of 270. I wake up this morning and it is 258. Someone please make sense of that? My plan did not change overnight nor did I do a workout while I slept
Ping a message into support@ or tag one of the regulars in to review your calendar.
Did a word search and didn’t find any mention of support.
Hey @timdave13 just to comment on the model using HR. I’ve had a couple SS workouts where my room was warmer than usual, and I got pretty significant HR drift. I rated the workouts Hard (as AI an I both expected) but my prediction dropped. So HR does have an impact on how AI evaluates your workouts. I would say it likely has a bigger impact for you since AI doesn’t get much resolution in your RPE ratings (they are usually easy/moderate).
Out of curiosity, what would happen if you took the next couple weeks and made the threshold and VO2 workouts hard/very hard by doing them at a higher power? My guess is the model would then learn what’s actually hard for you and progress you quicker. I’m not sure if you’re up for it, but it’d be a cool experiment and definately informative if you reported the results/changes…
I’m returning from 2.5 weeks off the bike due to a surgery. I had an easy ride today but my HR was elevated 5 to 7 beats during the 75% section of the endurance ride in the last two “intervals.” It felt easy, but my HR was elevated. That caused my prediction to drop. I was surprised how high my prediction was to begin with so the drop made sense to me but does support that HR is a factor.
OK, so this is starting to make some sense. Thanks for the input. I adjusted the actual workout to a harder one (similar to doing an easier workout at a higher zone) and plan to do this for a couple of weeks. But does not explain my overnight plummet in predicted FTP
. Thanks for the input!
@Caro.Gomez-Villafane do you have any insight to offer? I am not focused on whether my FTP goes down and getting my fragile ego dented. It is the apparent incoherence of the predictions it makes, like predicting a +37 watt increase from a 240 FTP when there is plenty of history that would flag that as “questionably realistic.” And why going to bed would cause a -12 watt decrease in prediction? I know my schedule is not ideal, but I generally get the workouts in, but due to work and travel it is what I have to do to get them in.
You went two weeks at the start of the most recent block without doing a single set of intervals.
The prediction may or may not have been perfect, but you can’t help but see why it expected you to progress further than you did, right?
