Would love to see any evidence that the fitter from the video can actually eyeball a 2mm difference like he claims.
He’s not saying he can eyeball the 2 mm difference. He would measure that in the evaluation at the start. He is saying he can eyeball the rider compensating for the difference: dropping a hip, pointing the toes on one side, a “hitch” in the knee movement.
I’ll admit that I can never see the knee hitch thing he and James talk about, but if you view someone from the back you can see hip movement quite easily.
Unfortunately, the only way to see that on yourself is to take a video. I was surprised just how much I was bouncing on the bike when I watched my recording.
Fair call, I was a bit snarky in my initial reply sorry. I watched the video again, and as you say he claims to see the change resulting from a 2-3mm difference.
Unfortunately measurement of leg length discrepancies is quite difficult to do accurately/reliably: Leg length discrepancy: A systematic review on the validity and reliability of clinical assessments and imaging diagnostics used in clinical practice - PMC Unless he is using bone imaging of some sort I doubt he is accurately measuring the minute LLD he is claiming to be seeing the effects of.
I’m not questioning whether he can make some people feel more comfortable by shimming one cleat by 2-3mm. The problem is people like him:
- Make claims about what they can see and measure that probably aren’t true
- Overstate the importance of the things they see and measure, ie in this case that (essentially) all cyclists need to have a 2-3mm LLD corrected with shims
The evidence (that I can find) is far less specific than this, eg:
- The Retul system more or less works for non-injury pain, comfort and fatigue: Long-Term Effects of a Kinematic Bikefitting Method on Pain, Comfort, and Fatigue: A Prospective Cohort Study - PMC Reference ranges for joint angles are provided, but they are about 10 degrees for most angles (ie. a lot of leeway)
- Correcting LLD with shims: https://openventio.org/wp-content/uploads/An-Integrated-Analysis-of-Leg-Length-Differences-and-the-Effect-of-Correctional-Techniques-on-Stroke-Mechanics-and-Performance-Indicators-in-Competitive-Cyclists-SEMOJ-1-103.pdf It corrects torque imbalance but there was no increase in power output and efficiency was reduced (at least in the short term, no long term data available)
- Knee pain in cycling: Potential factors associated with knee pain in cyclists: a systematic review - PMC Frontal plane motion is associated with knee pain, but there’s no evidence (yet?) that pain can be fixed or prevented by changing frontal plane motion
(Not defending MVF here - it clearly hasn’t worked for numerous people in this thread, and I’m glad you found a fit you’re happy with)
I found that I only got good results once I used a tripod to keep the camera in the exact same spot. And make sure it’s at saddle height and not tilted at all. Before that it would be inconsistent.
I found it gets me pretty much in the ballpark for saddle height and reach. Have had to adjust my saddle a little bit more forward but that’s it.
Yup. I did that. One time I got wacky results and realized it was because I accidentally recorded with the wide camera, which makes the video a bit fish eyed, so that makes sense. Other than that the results were consistent to themselves. If it asked me to make an adjustment in one direction and I did, the resulting angles moved in the direction they wanted.
I just think the ranges they wanted the angles, and where they defined “good enough” was not working well for me. I found in some areas (related to saddle height and setback) I needed to be much closer to optimal than they suggested. In other areas, like shoulder angle, I am more comfortable outside their range.
I’m honestly confused on what you don’t like if people coming to get more comfortable are leaving more comfortable. They got what they payed for.
Also, the vast majority of people are in fact asymmetric:
Many human body parts undergo development with bilateral symmetry. This implies that the right and left sides can be divided into identical mirror images. However, due to biological factors inherent to processes of development as well as environmental disturbances, perfect bilateral symmetry is rarely found.
In normal life, such asymmetries don’t cause any functional problems. However, as Neil points out cycling is a very unnatural activity in that we fix our feet to pedals that are moving in one plane only and repeat that exact motion many, many times. By contrast during walking our feet, legs and hips move a lot more and vary their motion in multiple planes and so can more easily compensate without injury.
I would expect to see reduced power output (short term) in some more extreme cases because after fixing a problem the muscles will be used in different proportions than before. They muscles as neurons have been trained on the old position. It sound take weeks to months to fully realize the potential of a new position if it’s correcting significant compensation.
Also, the point of a fit is comfort and avoiding pain, not increased power, so it’s not even the right metric. It’s just easier to measure. But anecdotally, there’s a reason bike fitting is popular. Being comfortable is necessary to have good power, at least long term.
I have no dislike for that at all. If someone’s happy with their individual outcome, great!
The problem is:
- Health or fitness professionals overstating their abilities, and implying that any person or system that doesn’t have their abilities isn’t good enough.
- Their clients (or Youtube viewers) then believing that is required for every individual.
I believe there should be a more honest relationship between professional and client - and between influencer and Youtube audience.
Yes! But until there’s evidence supporting that this both A: causes a problem, and B: correcting it prevents or fixes the problem, I think we should view with suspicion anyone acting as if A+B are universally true - especially when there’s a financial motive. (If this evidence has been published I apologise!! I couldn’t find it)
There’s some really interesting discussions on recent Escape Collective - Performance Process episodes with different people discussing their philosophies (no data
) on bike fit, including optimising for both comfort and power. As you say, comfort is necessary for power long term, and short term studies don’t provide data on long term outcomes.
But that’s just it. The evidence is that good fitters are using shims and clients are satisfied that it improved their comfort. If the fitter is right or wrong about the why behind it I don’t care.
But also wonder why you don’t believe the leg length theory. Have you ever had a fit before? I had a Retul fit and the fitter did basic things like visually compare the height of my patellas, tibias, etc. They did the same for me in physical therapy.
Do you need a micrometer to tell if two pipes are the same length? Of course not, you can align the ends and use your eyes. And from there it’s basic logic that matching length improves mechanics on a symmetric machine.
If we were talking running for example, I would question if ending leg length is beneficial. But on the bike it makes perfect sense. I don’t need a study to prove that. N=1, getting yourself fit, and seeing if it helps you out is all the proof needed.
Did you ever get to the bottom of your knee problems? I’m having similar issues at the moment and a bit lost with it, I’ve had no knee pain issues even on 200 mile rides until last year when I felt knee pain early on in a 147 mile ride. The bike shop noticed the seat post was slipping slightly and I thought that was the cause, I’ve done a number of long rides on the rollers without issues but feeling knee pain again on long outdoor rides. I’ve tried taking the seat down a bit but I’m not sure if it’s residual pain from the long ride but it doesn’t feel right.
I’ve spent a while reading up reviews on bike fit apps and of course the experiences are very mixed, I don’t have an IOS device so can’t try the Bike Fast Fit one so looking at my velo fit. Although wondering about borrowing an IOS device just to get an idea first if the app is going to help. I’d be interested to know if you’ve managed to find an approach that’s helped you.
John,
You can create a free account and do a trial upload on www.myvelofit.com and the system will give you non-specific feedback “In range”, or “needs adjustment”. If you want the corrective measurements you can pay. Usually it takes 2-3 adjustments to update fit (since the bike changes all affect each other).
Reviving this thread as I found out today that with MyVeloFit you can also pay for an “ExpertReview” of the fit in MyVeloFit
This video talked with Phil Burt as he is one of the expert reviewers you can pay to review your MyVeloFit to help with adjustments.
I tried this service for both myself and my wife. It just didn’t work for us, but I really wish it had.
