With the standard calculations I am 11 points over! After setting up my new Garmin Edge I was getting congratulations for a new max heart rate, yikes!
220-70=150…actual 144 so not to bad other than low in general.
So what does max HR rate mean in terms of work? May be a dumb question, but does higher max mean more capacity or other net gains vs someone with a lower max? I’m around 174 or so @ 51 yrs young. Thanks.
Same here. Actual is 14bpm higher than 220-age.
And some interesting stats on what caused people to stop the test (Treadmill ramp test):
“Leg fatigue was the primary test termination criteria in 82% of the exercise tests. Dyspnea was the primary termination criterion in 17% of the tests, whereas chest discomfort/arrhythmias were the primary termination criterion in only 1%“
I wonder if it’s the same distribution in the TR population for why people stop on the ramp test…
Edit: poll created
220 - 43 = 177. My max is 183.
Thanks for posting the link to this study. Although there is a correlation between age and maximal heart rate, the high variability is very interesting. I seem to fit pretty close to their average, though, in that the 209.2 - 0.72*age closely approximates my maximal heart rate.
Max observed HR: 196
| formula | result | delta |
| 220 - 36 | 184 | -12 |
| 220 - 0.64 * 36 | 197 | +1 |
| 209.2 - 0.72 * 36 | 183 | -13 |
Even moar formulas:
Age 37 so formula give max of 220-38 = 182.
I’ve seen a max of 192 a few months ago so about 10 off for me.
Age 47
220-47= 173
Max I’ve seen on the trainer is 182
Max I’ve seen on the road is 189 (Albeit about a year ago)
Max I’ve seen since getting
HRM: 188
Wrist max: 201 (It’s terribly unreliable, especially if you are black)
Age: 28 which is 192
RPE of 677% max haha
52/197 off by 29.
Way off. Formula says my max heart rate should 168 bpm, but I regularly push 185 and max out around 190. Resting heart rate ranges from 49 - 53 bpm.
Age 61. Observed MaxHR of 190.
220-78 = 142. Actual highest = 150 bpm. Off by 8. Hopelessly average.
I think you are right. According to the formula my max is a measure that I regularly reach when doing longish threshold workouts. I am not sure what my max is, but from what I can understand, few can reach their max HR on a bike (running up stairs might do it, if you have enough stairs) and, once again from what I understand, if you reach your max, you’re more or less ready to puke. I’m too much of a coward to go there.
I’m 67 and have seen 168 on TR workouts (not regularly, but I have seen it) and the formula gives me 155. I see over 160 fairly often, without getting close to puking. I figure 10 beats more over 168 would do the trick.
Interesting.
220 - my age(37) = 183
My actual HRmax= 196
So the HUNT formula is dead on
220 - (37x.64)= 196
Just did it on me: 220 - (67x.64) = 177
Sounds just about right.
