How to Use the New AI FTP Prediction (Without Letting It Drive You Crazy)
This seems crude, but I wonder if maybe the AI determines what the appropriate watts and duration are and then goes through the list of appropriate workouts alphabetically?
That would explain Cloudripper as well.
I had something similar and it might be even better than that. Do you wear an HR strap? It might be picking up something there that’s telling the system you’re not as fit as it thought.
Yep. I do wear a strap. Between my pegged HR and me rating it on the right hand side of the curve, I think it adjusted exactly the way it should have.
A thought to add to @aydraper’s opening post…
Going by one of the recent podcasts, it seems TR have focussed on the ‘F’ in FTP: “functional”, as in, functional for training. Naturally this means, within the TR ecosystem. The way I see it, TR’s FTP prediction is simply saying, this is what we’ll train you at next month. That’s it.
The number offered is not an assessment of general bike fitness.
Now… if we could have a power curve prediction, that would be mint!
I personally am not using the AI prediction, because the 5% bump after the old system resulted in threshold workouts feeling unnecessarily cruel. (I’m currently training 6 watts lower.) Once I’ve swallowed some cement & HTFU I might let it have its head…
I had the same feeling. Now that I have been doing more threshold etc at my old FTP maybe, just maybe I can bump my number up but I dont know that I am willing to do the level of work that TR thinks I can do. They are just a level of effort beyond which makes sense for myself. 10watts is just a bit too much for me at this point.
Ok. So, when we see our completed w/o and look at workout levels I guess it’s very hard to understand why a level could be lower then expected with no pauses then? Here I assume the lower watts cased this?
I don’t think that it is true that changes in the AI FTP prediction is a straight line assuming each workout follows the most likely RPE response.
It is true that RPE response is the only opportunity for the AI to get subjective data from the user. But it has all kinds of other time series information gathered during a workout – cadence, HR, power – that help it understand how your body actually responded to the workout. You can’t change those data once the workout is done, and the TR folks have certainly dropped hints that they factor into the AI’s calculation.
Great job completing those 2 hour Sweet Spot w/o. One thing that the AI can be looking at is your heart rate. Perhaps the AI is accounting for your HR relative to the work done and across prior SS w/o. So long as TR continues to assign 2hr SS w/o, the intervals will increase in duration and quantities with shorter recovery in between. As a 55+ yo, I try to keep my HR as stable as possible on the SS sessions. Also, make sure you are properly fueled, it makes the time and effort so much faster and easier. As a fast twitch rider, I drink 80g-90g / hr on my hard SS sessions. Good luck.
I just updated my weight in TR and was surprised that the system reran the prediction window after the change. @eddie I’m assuming that the AI is not looking at my weight but just automatically reruns as soon as something is changed in the “Account” tab?
I do believe that weight is one of the many things that feed into AI FTP. :sparkles:
Interesting. My weight tends to fluctuate a decent amount daily, and I do step on the scale before every ride (because I am obsessively honest about Zwift). Do you see any benefit to updating weight frequently regarding FTP prediction?
Kudos to you for keeping Zwift clean!
Check out this thread
I personally wouldn’t weigh myself every day. Even for Zwift. I’d consider once a week…
Whatever you decide, just know that looking at trends/averages is probably more realistic, as your weight will change throughout the course of a day, but if your body isn’t changing on average over days, or even weeks, does that really matter?
For highly competitive Zwifting, I guess I get it..
Either way, know that weight is a part of the equation. Maybe only update TR every so often, or when you see noticeable changes when weighing yourself for Zwift. :man_shrugging:
Every day is likely not helping you in TR.
Pepsi is far better than Coke…:wink:
Hey y’all! :waving_hand:
I just wanted to follow up on this one and a few other threads to let you know that the team just tracked down and fixed a bug that was causing AI FTP Prediction volatility. In some cases, an upcoming workout in your plan could swap to the next best workout (instead of the first best). If your workouts and AI FTP shifted without anything changing on your calendar, you were affected by this bug. The fix has already taken effect so you don’t need to do anything on your end for your workouts to be set correctly. :bug:
As always, stay in touch and let me know if you run into issues moving forward, but we think this is going to play a major role in eliminating FTP Prediction volatility moving forward. :partying_face:
Thx @eddie
What do you suggest as my ftp dropped from 255 to 244 (which I did not accept) after following the training plans (a plan you put in my calendar, an FTP plan and the Traka plan).
So what do you suggest now for me to do?
If I accept the 244, my training will be too easy. my today’s sweetspot workout als ready felt easier as supposed (moderate vs hard). So when accepting the 244, think all will be more easy as it already is..
Thx for your help…
I think that your training would actually improve if you lowered your FTP to 244.
All of the threshold workouts that you’ve done recently are below a level 3.0 (the last one was a level 1.9), and you’re rating them as hard.
Lowering your FTP would allow you to climb up to higher-level workouts, which are more productive.
Aside from that, I’d recommend sticking to the plan as best as possible. You’ve got a lot of races on your calendar, which means that you’re only getting in one hard structured workout each week. Ensuring that you are well rested and prepared for that key workout is important, but having productive workouts to take on is the first step. :+1:
Let me know if this helps!
Thank you @eddie
One question…
Your remark regarding the 1.9 treshold workout that I rated as “hard” was supposed to be hard, so inline with the AI system I believe. This training was also before my A race.
Last sweetspot was a 4.4 and I rated this as "moderate " instead of hard, even with a ftp setting of 255 instead of 244.
Think im having the bug too. How can I check and see this?
If yes, how to fix? I’ve already download the beta version.
To share my concerns.
As I did an ftp test (20 min) on the 8th of April, the calc number was about 255.
I don’t care about the ftp number, but I know it is a pct of this thats been used for workout settings, and my biggest concern is not to train at the correct number/zone and that the system (bug) will bring me in a downward spiral (as it is doing now).
Hope this explains and you can help as I do trust the system, do trust TR, but dont want to train with the incorrect number as its been infected by a bug.
Kr Jan
Hey Jan,
Yes, threshold workouts are supposed to be hard, but with that higher FTP you’re currently using, a low-level threshold workout in that 1.8 range is likely going to feel hard, whereas, with a lower FTP, you could likely take on higher-level threshold workouts with a level of 3.0 or higher.
Those higher-level workouts are often more productive, so it’s best to set your FTP in a place where you can take those on.
We assess your performance in each training zone separately, so there’s no need to worry about Sweet Spot, endurance, etc. If you lower your FTP, we’ll still get you the right training in those zones.
Does that make sense?
To summarize, with an FTP of 255, a level 1.8 threshold might feel hard, but with an FTP of 244, that same workout with the lower FTP won’t feel as hard, so you’ll be able to take on higher-level workouts with more or longer intervals.
With threshold training, it sometimes helps to work up to longer/more intervals for more time in zone during your workouts. You won’t do that with low-level workouts, but lowering your FTP will help get you there.
