Heart rate monitors
I always wear one and look at the data later. I have a garmin hrm tri currently and works well. Before I had a Wahoo tickr which I did like but had to replace the strap a few times.
I’ve had couple of different HRM over the years (all with chest straps) and find they all cut out (or drop to v low heart rate - say around 50-60 whilst working out- stay at that for a while when seem to wake up and jump back up to actual HR (say 160).
Have I just been unlucky with HRM or is it me! Currently have a 4iiii one (viiiiva I think it is called). I don’t really care to much for cycling since I have power but would be good to have HR on my runs.
For reference, HR when I first wake up his usually 45-50 bpm and highest HR (seen few times during CX races) is 192-193 bpm (average around 185bpm for hour cyclocross race). I’m 37 years old.
Polar released a H10 firmware update in April that adds support for Ant+.
https://support.polar.com/en/updates/polar-h10-firmware-update-ant-now-available-0
Since updating to that version I’ve been able to use it with my Garmin Forerunner watch.
I upgraded from a Wahoo Tickr to a Polar H10. It has extra electrode coverage and I trust it absolutely.
I also use a dab of ECG electrode gel I bought from Amazon that I spread across the sensor so I have absolutely solid heart rate coverage all the time.
Everything I’ve read suggests that chest straps are still the best. And for my time I’d like the best of the chest straps with the best possible interface to my body. Overkill, but works for me.
Same here. I wear it on my forearm for 100% of indoor rides.
Outdoors I prefers a chest strap. The scosche works fine outdoors too of course. Just personal preference.
Do you have a link? Is ECG gel same as ultrasound gel?
I have a garmin vivoactive HR watch.
I still use a strap. The garmin one worked but i think i left it when visiting the in laws… so i now use the wahoo one i’d bought for my wife (who didn’t care). Works great.
The watch definitely is a hit or miss
I’m in Germany and bought two ECG gels on Amazon. Both were well rated and work well.
When I was in the US this was what I used:
I would think ECG gel is going to work much better than ultrasound gel; ultrasounds don’t need electrical conductivity AFAIK, and those electrolytes in ECG gel are what will conduct the electrical signals of your heart. Same reason sweat works better than water at conducting.
The vibrations through the handlebars make wrist-based OHR a very poor place to measure HR for outdoor cycling. The Sosche offers the ability to move it to the forearm or upper arm, which both have a deeper blood supply, and are more isolated from vibrations.
However, all OHR are fairly slow to respond to changes in HR, so if you are wanting to track HR during shorter intervals, then a chest strap is the better way to go. Over time, salt from sweat can build up in the fabric of the strap, causing erroneous readings - I’d recommend getting a HRM with a removable sensor unit, so that you can replace the fabric strap cheaply every 12-18 months. A dual ANT+/BLE sensor is probably more future-proof.
Wahoo Tick’r does it for me. After burning through a Garmin and a Lezyne in less than 6 months each, my Tick’r is going strong 2 years later of heavy, hot, sweaty use.
Ok, so another name in the mix: scosche.
I’ve tried fitbit watch and wahoo wrist based and chest strap. all dropped in and out, depending on the connection to the skin. vibrations do not help wrist based straps / watches. chest based did not seem much better.
so now i use a scosche strap, mounted on the upper arm. vibrations are dampened; it’s easy to get on and off; it does not seem to lose connections to the skin. bluetooth and ant+. you do need a headunit to record on, though.
(leans forward, lip visibly trembling) “GO ON …”
Thanks everybody for your responses. I should have mentioned that I’m looking for a stand alone unit, as I do not have a Garmin or anything like that. I could go for something that links to a phone app though.
I think nothing beat strap heart monitoring. I have Garmin-HRM dual and recently bought cheap Magene heart rate monitoring at 1/5 of Garmin price ( I think)… no difference… the Garmin dual can be used while swimming…
My Garmin HRM only connect through ant+ but all the Magene sensors work both with ant+ and bluetooth…
but at the price, I will go for Magene straps…
note: recently I bought lots of Magene product:
Magene Gravat (smart trainer)
Magene HRM
2x Magene speed/cadence sensor
Magene Ridge (power meter)
Ive never used a magene heart rate monitor but the speed and cadence sensors work awesome.
For heart rate I use a 4iiii’s viiiiva and it is awesome. Has storage. Is a ant hub. No issues at all. Also have a garmin HR swim that I have had 0 issues with as well.
How long has Garmin HRM been both bluetooth and Ant+?
Wahoo Tickr here too. Besides replacing batteries every six months, is pretty reliable, not like the rest of the product line…
I use the Garmin HRM-Swim for indoor training (also for swimming). Other than changing the battery after about 2 years, it’s been perfectly reliable, and I don’t worry about my profuse sweating causing issues with the softer strap on the HRM-Tri. It’s ANT+ only, but I’ve got a dongle for connecting TR to the smart trainer, so it’s not an issue for me.
@grenhall We’re brothers from another mother! Or, just weirdo cyclists. Why? I used to wear my HR strap playing hockey too. I’d leave my phone on the bench, and my team-mates would yell at me when they KNEW I was getting tired based on HR. Here’s a 60 minute game a few years ago. Easy to spot my (lame ass) shifts as a right winger:
@chad ain’t got nothing on these intervals!
TICKR user here and I was in the same camp as the OP and not using one outside until last year. Racing with HR has been very helpful and use it as a guide. Especially helpful on the climbs.
Re: Wahoo, I’ve had good CS from them. They replaced a failing one year old Kickr with a new 2019 and they paid to ship the old one back (failed one sounded like a big rig…failed bearings). YMMV, but Wahoo has been good and their CS has come through for me.
