Thank you for the advice! Achieved the goal of being able to do multiple workouts per week. Got the HR and breathing up etc.
One question that I have with this strategy: If the goal is to not fatigue the legs, enhance the load on the heart to be able to do more workouts, what about the heart? Is it unproblematic to do multiple of these in a short amount of time?
VO2 will also fatigue the heart… but based on what I’ve read, more people have legs as their limiting factor, not their heart. Hence the logic of preserving legs I think.
I’ve heard of cardiac issues a couple times, though none coached by us since we know what to look for, plus we make sure people are cleared by their docs for high intensity. Problems seem to occur when taking the efforts to silly extremes, not enough recovery, not enough food or sleep, or all of the above. Or someone who just jumped into it off the couch (me). Cardiac problems seem to indicate that you were either not healthy or well trained enough to begin with, or were ignoring myriad signs that you should have stopped a long while before.
tldr: if you’re watching the power progress, odds are decent that you’re recovering just fine. But regardless, if anything seems weird, stop immediately and go see a doctor.
Thanks to everyone who has chimed in to this thread. Hopefully I have learned some things to implement into my VO2 training.
So I have it right, I’ve summarised the thread into the following:
Enter VO2 max intervals with an eye on a higher than normal cadence with an eye to sustain the target watts - preferably higher.
Go deep each rep to replicate the effort and better the effort, but keep RPM up as the HR activation is what we are after with the Watts a compliment to that physiological affect.
Find a cadence/gear that allows you to achieve the above and go all out
Worry less about failing the Watt target and worry more about the HR
Do I have that right or have I missed something? Please correct me where I have erred
Not quite. Not so much the rate at which the heart is beating as the amount of work it’s doing. Your breathing is a better indicator that you’re doing it right than your HR.
Got 2 weeks / 4 quality VO2 days done. 4-6min intervals high cadence almost all out. Now on 3rd week my gf got the flu and I had a sore throat too but it seems to be passing. Pretty sure if I do high intensity I will be sick too I think I’ll just make this my rest week.
I was hoping to do a threshold / over-under block after this but is 2 weeks of VO2 enough or should I do some more VO2 / short power stuff first?
My heart rate is already a lot lower when doing endurance.
8 workouts in 2 weeks is probably plenty, especially if this is your first time with something like this.
HR being low could be stroke volume, but probably more likely fatigue at least during the block/immediately following. That said, it’s not uncommon for me to see lower HRs in endurance riding in the few weeks back after VO2 blocks.
I only did 2 workouts per week, but I managed to complete the 3rd week.
Did 5 x VO2 workouts and a 20min pr where I sprained something in my chest breathing so hard.
I hope it’s enough can’t imagine doing more than 2 of these a week.
I used to struggle holding 110rpm but it feels so much easier after switching to shorter cranks.
Started with 4x4min and ended with this, got 16min at over 90% heart rate.
6 will be OK especially in your first effort at that. Usually when I give 2 per week I give them back to back so you get a strong stimulus each week then recover from it. It works, not quite as well as the bigger overall load. I usually aim for 3x3 for most people, but it’s tough, for sure, especially with life stress and such.
I’m almost done and have 2 hard workouts left! Today my description was “F my life”. It’s definitely a whole new stimulus and @kurt.braeckel has helped immensely.
I have a few ways I prescribe this block; the most common is 3x3 with a day between and then two days between once a week. Really I’ll slide things around as needed but goal is 9 workouts over 3 weeks. Other way is 3x2, with back to back on the 2s. Last is the nuclear option which ends up being 3 in two days with about 60 hours between sets, then go again, repeat 5 times.
So it depends on a lot of things but I strongly recommend against the nuclear option for most people. 3x3 is good if you’ve done structured training in prior seasons.
A huge part of this is the mental “dread”. I’ve never given 3 back-to-back-to-back. Could it work? Sure. I think most people would probably hate it especially by the third day. With the nuclear option, you’re essentially doing 3 workouts in about 30 hours, so you don’t really have time to feel bad. When I did it a couple of times, the third workout was often my “strongest” one and then I’d want to throw my bike in the river, so almost 3 days off between those was good for a reset to go again.
I’m planning to do a 2 week VO2-block starting next week. I’m guessing that 8 VO2 workouts should be feasable but I’m still figuring out how to organise them - any ideas here?
I’m thinking that 2 back-to-back workout days followed by 1 recovery day could be doable. Repeat 4 times (totaling 8 workouts in 11 days) and allow room for some extra recovery if needed.
Couple of questions:
How much extra (z1/2) volume should I add? I’ve averaged ~20 hrs per week for the winter and ~1000 hrs per year for the last three years. I have two weeks off from work and I have pretty much nothing else in my calendar during those two weeks so plenty of time to ride my bike
Should I do anything else but VO2 workouts? Any threshold or anaerobic work needed for maintenance? How about gym work?
Stick to one workout (e.g. 5x5min high cadence) or rotate a couple different ones?
Not a great layout in my opinion. Either stack them MORE (like two in one day) with MORE rest between, or spread them out more. Planning to do 4 of these workouts in 5 days (twice) is a bad plan.
General rule of thumb is EASY volume about the same as what you’re used to. A little drop in volume is OK, but endurance needs to be bottom of zone 2.
Jesus, no. Gym work OK, but no legs.
Depends on how you structure it and structure it overall, but most people don’t need 25 minutes of stimulus in a workout especially if you’re doing a focused block.
Yeah, I think I need to spread those workouts a bit more. Maybe 3 workouts squeezed together as you mentioned earlier (morning, evening, morning) followed by 2 or 3 easy days? That would yield 9 - 12 workouts total.
Easy volume - check, light gym work - check, additional workouts went out of the window
I’ve done two one week blocks previously, both of which went great. One week is just short enough that you can kinda hammer trough it but two weeks seem way more intimidating. Heck, outside of VO2 blocks I do maybe 10 VO2 workouts in a whole year
I will say this being my first time doing a block like this. It is mentally fatiguing as much as it is physical.
There have been a few days where I was procrastinating big time, didn’t think I could do the work. It was all in my head, so far I think I’ve done well this block. Really focusing on that harder start and keeping the cadence high. I don’t feel burnt out because I understand the reason behind doing this block. I’m keeping my eyes on the long term benefits and taking it day by day.
Also, I have been trying to eat in a small surplus and focusing on carbs with moderate protein. Usually I’d eat a protein bar as a snack. This block I would eat some home cooked sourdough bread instead.
One more “hard day”, and I’m ready to rest, mentally.
Definitely have to fuel more (eat more) when you’re doing this kind of intensity. And yes, agree, it’s as much a mental challenge as anything. If you do the work correctly, your body can do this (and more in some cases), but there is a “dread” that starts to hit that second week for sure. That’s due to CNS fatigue because each set is very taxing, IMO, but we push through that as long as physically we’re hanging in there. Eventually, the wheels come off. That doesn’t happen often for trained people doing the 3x3 I typically use, but definitely will happen with the nuclear option. Usually that’s what stops the block (the wheels coming off). And again, not something we’re after very often at all. The "I don’t wanna"s are a great indicator for short-term overtraining/acute fatigue and we almost always listen to that.
From what I’ve seen in your workouts, they’re looking good!
