Elite Directo XR set up issues
Hi. I’ve just bought an Elite Directo XR. I have a Scott Addict 2020 which has a thru axel size 12x142. I am trying to use spacer F which is provided with the trainer on the same side as the cassette. I seem to have an issue whereby the spacer won’t screw all the way in which then doesn’t allow the axel to screw into the spacer. So should the spacer screw all the way In - I have seen a YouTube that suggests it should screw all the way and then be loose. It appears as though the tube in the trainer might be incorrectly installed by the manufacturer.
Any help appreciated as I have spent hours trying to find a fix.
This is what spacer F looks like
No it doesn’t screw in all the way - I think it is supposed to… I think the tube where the yellow arrow highlights is stopping it from going all the way in.
Thanks again for your help - the photos of what it should look like put my mind at rest it’s the trainer not the installer! Looks like it will need to go back to be replaced.
Many thanks for all your help - yours was actually one of the YouTube channels I looked at originally!
