I do this when I do hard-start VO2 intervals. First 15-20 seconds are a high-cadence full gas effort and then I settle into the target power for the remainder of the interval. However, it will naturally decline in power while heart rate and respiratory rate are still very much elevated.
Notice anything drastically different? Look at how quickly my heart rate elevates with the inclusion of the hard start. It took only 44 seconds to achieve 92% of max whereas without a hard start it took over 2 minutes to achieve 92% of max.
For maximum time at or really close to VO2max gimme the hard starts.
But if they are custom workouts adaptive training won’t assign them.
Also those look like hard starts which isn’t what the study was about. They were talking about the whole interval power targets. Though this may have the same effect
If there was demand for tr to look into how the do vo2 workouts so that if this is the better way to setup intervals they could change how they do them
I’m sure there are more, just hard to find. Or more are coming, workout filtering seems to support searching for them but currently it returns no workouts:
Those are the categories I’ve seen in the filter. I see Steps under anerobic but those all seem to be in the opposite direction.
Any thoughts on this @SeanHurley ? I know the custom workouts from the team do that but I was more thinking in terms of getting Skynet to recommend them for adaptive training so I can still follow a TR plan. Thanks
It depends on VO2max experience. I’m mostly focused on LSD and threshold type of plans, doing only occasional out-of-plan VO2max week to spice things up. Because of that, I’m really bad pacing such efforts i.e. if I go for max, I’ll likely do not finish whole workout. For that reason, I prefer to go with prescribed power and just scale it up to my abilities. Even then I used to blow up before the end. That’s why I like decreasing stepped workouts: while HR still keeps going higher, it is actually getting easier.
I like having a target power as this keeps me focused. Eventually, you learn what “full gas” feels like for a given duration.
I did a few 4-minuters yesterday with hard starts. The power just ended up being what it was, regardless of my “target” (which was 390-400). Average power for the three as % of FTP was: 126%, 119% and 111%. So, not on target, but full gas, and not a fail because…
You can see that in all of them my average heart rate is high, like 91-92% of max, and my breathing-rate was also high. Definitely in VO2 zone, regardless of power. Again, VO2 is not a power-target, but having a target is not wrong.
