Cycling events during a triathlon plan
Earlier today I removed a triathlon race from my plan, and when prompted if I wanted to update my plan, I said yes since I now wanted that weekend to be populated with normal workouts as opposed to an opener on Saturday and a race on Sunday.
As I was trying to do this, I received the error “Your events include both triathlon and non-triathlon disciplines. All events in a plan must be the same type. Remove or change events so they all match.” I opened a chat, and eventually received confirmation that “Now it is not possible to have cycling and triathlon events in the same plan, different event types require their own separate plans.”
Now, I’ve been using TR to plan my years like this for a decade or more. I primarily do triathlon, but each summer there is sometimes some road racing or MTB mixed in. Now, despite these other disciplines being on my calendar, I cannot update my plan because it will no longer accept the other disciplines.
Has anyone else encountered this? Does anyone know why this change was made? How is anyone else handling this sort of issue?
I have not, but the devil may be in the detail.
I have one A race at the beginning of June, Olympic triathlon
I have one A race end of September, Hald Distance triathlon
I just added a made up Road Race, B event in August no problem
My guess would be that you’ve deleted your A race so the plan no longer has an A race associated, and/or you are trying to replace the A race with a cycling event - don’t do tha :slight_smile:
Instead just edit the plan, change the type and event there
I am facing same issue… I am using pc web to create the plan… I have no idea how to add some cycling events in the middle of triathlon plan… I can create plan1(triathlon), plan2(cycling), plan3(triathlon) but this means that I have a complete stop of swimming and running in the second plan and I shouldn’t. This was a regression from the previous version… Old plan will work if not updated but as soon you remove it or update will stop work… This is a RED flag for me…
What happens if you just go into the calendar and add an event without editing the plan?
the event is added, I press adapt plan… it starts to adapt the existing workouts (at least shows that animation) but nothing more is added:
So you’re not getting the error th OP is seeing.
I think it’s behaving as expected for you. You don’t have openers for your B race, and you’ve scheduled a race on the same day as a workout. I’m not expecting anything to be added.
As a C race this is something you just do in your normal training schedule. We’re you expecting it to replace the workout, or change your training to be cycling focussed?
Just discovered the same. And like you, I have been doing this same thing for years.
I have a triathlon A race on my calendar as an event, plus 2 B race cycling events. In the past, I could add a custom training plan no problem. Now, it just gives that error and refuses.
If I’m understanding what you’re showing here, I think the difference is that you already have a plan on the calendar and now add the cycling B event afterwards and asking it to adapt. In my case, I don’t have any existing plan on the calendar. The only items appearing are 2 cycling B races, then triathlon A race. And it refuses to to add a custom training plan for me citing that error about Tri and non-try events.
EDIT: I deleted the cycling events, then was able to add custom plan with only the Tri event on the calendar. Once the plan was on the calendar, I re-added the cycling events and it asked to adapt.
Ahh.. The new warning message may be because of me.. a few weeks ago I was having a problem where I’d set up a Triathlon plan with one A race, then added B/C running and bike events.
But when I moved/added/changed an event the whole thing freaked out and deleted everything except swims and runs.
The workaround suggested by support was to add other events as triathlons too - but with really short durations in the swim/bike/run.
Seems to be more stable and adapt enough to be useful. But this thread ives me hope that TR is working on it and will provide a more useful and flexible planner… one day
