You don’t need to run their dropper to run manual override. Just install the extra pod above the bar, dropper below the bar. That’s what I did.
I use it without the override. I have a tuned transfer SL on my bike
I’ve tilted my chest mount gopro downward to see the crown lights for a preride of an xc course, and it was pedal or open more often than I’d like. If it’s smooth gravel, then it does lock out, but once I hit a small bump it goes into and stays in pedal or open more than I’d like. I ended up using the manual lock for that section during the race, but am in the process of manually setting the powerzones to see if that would help.
You can also play with the bias adjustment to make it go firmer quicker. In my experience, the only 2 modes the rear is in while pedaling with any pressure is pedal and lock, so I’m surprised to hear it’s staying open. Mine is only in open when coasting/descending or very soft pedaling. Also, if you are new to a 3-way lock with the pedal (middle) mode, you might give pedal mode a chance before assuming you want it locked more often. I’ve spent a ton of time on manual 3-way lockouts (both fox and rockshox) and pedal mode was where I spent the vast majority of the time. Open for descending, only locked for super smooth or out of saddle. But that’s me, I know some folks coming from hard tails that don’t want the rear moving at all unless then are descending.
Yeah, I ride with the bias maxed out to be more locked out. I just checked the video and there are definitely very short periods (2-3 secs?) when I’m continuously pedaling at 250-300w+ and it remains open, but I think that it’s open because I just hit a small bump. But I do see a tendency to revert back to pedal and not stay in open for a long period while pedaling 200W+.
That’s one nit pic I have on FA, it definitely has an internal clock for making some adjustments and I don’t think there is any way to configure it. I get why they need to have a balance between constant adjustments vs waiting, I just wish it was a configurable thing. For a 10 hour marathon event, a couple seconds in the “wrong” setting is probably a good trade off for battery life, but for a 1 hour xc event I could see the advantage of quicker changes. It’s really more of an annoyance than a real impact, the system works incredibly well but everything has room for improvement.
I have heard from the sram rep that increasing bias makes the flight attendant “react” quicker
still no launch control for flight attendant. Does anyone know when it will become available?
Interesting. I thought it was to lean more toward locking out. Good to know.
On another point… does anyone know if it is possible to program FA to spend most of the bell curve / time in pedal mode? I find it does a good job in going to open but more often then not tends to lock out rather than use the “magic middle.”
You can play with the “adaptive ride dynamics” wattage ranges in the app to raise the bar for when it prioritizes lockout. If you raise the wattage thresholds for medium/high, it will tend to lock out less. I assume you can get a similar effect just increasing the bias setting, but I assume that is going to alter the threshold for going open as well. Honestly not sure, I haven’t played with the bias setting as much as I’ve played with changing the wattage ranges manually. Maybe it’s just 2 ways to get to the same result. Also, my preference is to never have the fork lock out automatically, that’s reserved for manual override (which locks fork and shock).
It is now Feb 2026 and I still dont have it or cant find it. Cannot find on the internet how to activate this too
It has not been released yet….
