Advice for new XC MTB rider
I’m an experienced road rider just getting into XC MTB to get some variability in my riding and develop some new skills - maybe try racing when I build up some confidence.
Got a few things I know need improvement and amhoping for some tips/tricks to make more progress:
  1. Sore hands from gripping the bars + braking.
  2. Berm and pump technique
  3. How to tackle dropoff sequences
I’ve only been to our local trail centre three times (mostly down to the weather over winter) - so a lot of this is going to be inexperience, but I’d like to learn and am having a hoot even at my current skill level.
None of the trail features are all that big - I’m tackling all of it on an XC bike - but I’d like to be more controlled through the trail so that I can maintain my speed.
Some more details about the things I’m trying to improve.
Sore hands:
I seem to get sore/aching hands which (I think) are from gripping the bars and braking. In road riding I have a loose grip, but on the MTB my hands felt like they were much more actively gripping.
Is there anything I need to change setup wise? Or is this just something I’ll get used to?
Berm/Pump
I think these are related, but I don’t get the timing of pumps in the trail and lose all momentum.
Similarly, I’m not sure what the right position is for berms to gain traction and successfully pump out of them.
Are there any cues which might help?
Drop offs;
One of our trail features is a sequence of repeat 30cm drops through a rock garden. Something about the sequence is throwing me…
On small drop offs (curb height) and for one offs it’s fine. But on anything much deeper I feel like the front wheel is just dropping, at which point I instinctively bail from the next step in the sequence.
I’ve tried doing a small manual off the ridge to keep the front wheel more level, but that didn’t seem to work.
I’m not out of control or crashing, but it doesn’t feel like I’m fully in control either.
Do I need to keep the weight further back when I go off the ridge? Conscious I need both wheels to land at roughly the same time so that I can control the direction I’m heading in.
For the hands and braking, make sure you have 1 finger on the brakes on each side. Also try to relax and bend your elbows to act as additional suspension. These techniques should help but will also take some practice.
If you have XC friends/teammates that are more experienced than you, ride with them and follow their wheels, or watch them pick their lines and observe their techniques. Also have them watch you and ask for some advice.
I would also recommend hiring a coach or taking a class, some locations or MTB park areas or clubs have this for a day session which will help a lot as well.
Before I knew better, I was frequently using two fingers and my hands were sore.
Could be a couple things on the hands. Angle and position of your brakes could be a problem. I like using ESI chunky foam grips and think they help with the damping. Also make sure your fork/rebound settings are correct. Lastly loosen your grip with your hands, you are probably deathgripping and that’s causing issues.
Pumping will come with practice on the bike and figuring out the balance.
Drops are hard to nail and would probably be good to take a skills class that someone who knows what they are doing. Other thing is to practice on a curb, then a 1 foot drop with run in and then up from there. Different speeds, probably don’t need to go super slow since XC riding usually has speed to it.
Best thing you can do it pay for some coaching!
But a couple of tips below.
Think about this from a “work” perspective. If the bike has to push your body weight up as you go over a rise, then this takes work to raise your weight which slows you down.
Therefore, if you can stand tall on the bike and allow the bike to move up by bending your arms / legs as the bike goes over the rise, you will not lift your weight and therefore not slow down.
On the other side of the hump you can then push the bike down (as you just let the bike move up) and therefore raise your body up relative to the bike. This effectively increases your weight during this motion so you gain a speed boost on the down-slope.
Drop offs;
You have two options,
Option 1:
before the drop, lower your chest close to the bars. As the wheel goes over the drop, push your arms down. The aim is to use your arms as suspension so your shoulders / head does not feel the drop (i.e. all the drop is taken up by your arms and therefore your head and shoulders don’t feel it. You will then quickly need to get into position for the second drop.
Option 2:
As your front wheel goes over the drop, shift your weight back (try not pull on the bars) to un-weight the front wheel. For this to work you need your weight sufficiently forward to allow yourself enough backwards movement.
What @Niv24 and @Elgro said.
On hands, also check front tire pressure is not too high, and that your front suspension is set up correctly. Pressure, damper in the “open” position for the chunkier sections. In addition to rebound.
This is probably the best series I’ve ever seen on how to mountain bike.
I’m from from being the most skilled XC rider, but I do OK for an ex-roadie gravel racer. When I’ve been off the MTB for a long time, there are a few tips that really help me get comfortable again-
  • Heavy feet, light hands. This will help with that hand pressure/fatigue. When I concentrate on keeping my weight low and centered in the bottom bracket, the hands naturally get lighter and it also improves stability/control.
  • Bike/body separation - move the bike to the terrain and keep the body stable where it makes sense. Helps with turning and also absorbing terrain.
  • Keep my eyes down the trail. I’m not even sure why it helps, but it helps me.
Those are a few of the things that help me, but it’s different for everyone. Lots of good videos and books out there and local clinics or lessons can be great also.
+1 for coaching, especially if you’re new.
It’s much easier to learn the right way the first time, instead of having to unlearn your bad habits you formed.
Thanks all - some useful descriptions in there!
+1 for the Ben Cathro video series ‘How to Bike’ linked above. It’s amazing.
Session features to build skills. Film yourself doing features you struggle with. Sometimes there is quite a large difference between what you think you’re doing and what you’re actually doing, body-position wise.
Another thing to check is make sure your bars aren’t too wide. Lot of bars come at 800mm and likely way too wide for your shoulders in a push up position. Cutting them down to actually fit you can help as well.
Getting instruction is very important. The only problem is where to find good instruction in certain areas as well as someone who is teaching the right technique. If you like to read, first read “ mountain bike like a champion” by ned overrand and pick up lee mccormicks book on mastering mtb skills. I dont agree with everything Lee says as it is backwards from some, but its a great start to get you visualizing what you need to do.
Sore hands:
You nailed it. I coach:
holding the bars like you would hold a Baby’s arms.
one finger on the brake (make sure your brake angle doesnt trigger too much pain and numbness.) Also, Bay sweep is important and a few degrees makes a wild difference. Make sure your wrists arent overly dropped. I know some very good racers who ride like this and they suffer through numb hands and fingers more than they should.
Remember, you are over gripping because you arent confident yet.
As you are turning, create forward pressure from the outside arm in the turn. You dont have as much grip on MTB, so bike body separation is key while staying centered over the BB and tire contact patch to create grip vs, just moto lean on a road bike.
You are as light on the bar as possible, not leaning on the bar the whole time. This required a well developed core. As a mountain biker, I can tell you that my Drop bar bike (offroad) is much more tiring on the arms (specifically Tris) than a MTB. Now the MTB will hit my shoulders in a much different way
Berm/Pump
This is where i start day one with NICA riders. Most people dont know where they are going wrong until they are filmed. It would be best to be filmed, coach, and read up on this. there are different types of berms.
In most cases, you want :
  • Bike body separation first and foremost and out of the saddle
  • braking done before the berm. often hard and sudden
  • You’ve already scanned the berm before entering
  • You are looking at and then past the exit which will turn your shoulders and help you through the turn without feeling stuffed. You can carry more speed because the front isnt copressing and freaking you out. Exaggerate this
  • In big constructed berms, I like outside foot down, or outside foot forward and flat crank. This opens the hips toward the exit.
  • In loose berms braking is your enemy.
  • I find if you put everything above together, but need a touch of traction for the slingshot affect, ill apply a little weight on the saddle at the point where im about to create a nunch of force that will result in a slide.
Drop offs;
Peak and push. Watch slow motion video and see what is happening in skilled riders. Perhaps have yourself filmed in slomo as well.
Self reflection is often the key o seeing what is going on. Ill film my self on gnarly features some time to figure out where I may be failing. Sometimes when you play it back, the line is so obvious.
The little gorilla tripod to hold your phone is your friend. It can be stashed in a jersey pocket comfortably and can wrap aroudn a tree branch or balance your phone anywhere.
There are so many youtube videos available on berms and drops. My only advice is practice and more practice until there is significant muscle memory. Also, practice small jumps and bunny hops.
Sore hands could be an issue with your grips on the bar. Most of your weight needs to be on your legs, perhaps your frame is too small.
Bike body separation is way more important on mtn bikes than road bikes. Good luck!
