2024 XC Bike & Equipment Thread
Anyone ridden a BC40 and current gen OIZ? Looking to update my 2020 OIZ this winter, and BC40 is leading my thinking. New Scalpel is also in the running.
I haven’t ridden BC40, but strongly considered it coming from my 2019 Oiz. I really like the aesthetics, geo, and that it’s US made and not very common. I ultimately just couldn’t get over the weight for the price.
I asked Allied through their customer chat on their website what the weight was on their Flight Attendant build and they told me they had recently built one up that was 26lb. I don’t know what size that was, and I’m not sure exactly what they included in the weight but I assume it didn’t have pedals and cages. That’s a big difference though between that and the Epic, Yeti ASR, ZFS-5, Scalpel.
I feel like that’s got to be for a larger frame, even if the BC40 is heavier than some of the competitors. My M Transition Spur is sub-26 with pedals and cage with a Ribbon SL on it (that fork is hefty compared to something like the SID) among other less weight-optimized decisions. With some more weight-conscious parts, I suspect I can pretty easily get it to sub-25, and the frame weight on the Spur is 5.4lbs for a M with shock.
+1. I considered it as a replacement for my scott. I even toured the Allied factory last month when I was there for Rule of 3. Super group of people and really cool to see stuff like this make in the US.
I ended going with a new Epic and It wasn’t so much the frame weight (BC40 about 1/2 lb heavier than an non-sworks epic 8 frame), but the price on a full build quickly got out of hand. By the time I added carbon wheels, lockout, etc. to get it configured similar (weight and specs) to the epic 8 expert, the BC40 was about $1500 more expensive than a comparable epic 8 retail vs. retail, and I ended up getting some bonus stuff thrown in with the epic. I know the epic is basically the toyota camry/honda accord of XC bikes and they are all over the place, but I look at my XC race bike as a tool and it had everything I wanted. A cool paint job and the unique brand (made in the US) is cool and I would have paid a ~$500 premium, but it was over $2k difference by the time everything was considered and I just couldn’t justify it. If I was just buying a frame and building up, I probably would have looked harder at the Allied and scheduled a test ride, etc…
Yeah I’d guess it was for a size L, maybe even XL, but there’s a lot of reviews out there with actual measured weights of BC40s coming in mid 24 or low 25 lbs pre-Flight Attendant. While FA is slightly heavier, I think it’s really the chunky Reverb AXS dropper on the FA build that is tipping it high. The sub 25 lb builds were all with lighter droppers.
Is 1-2 lbs really going to make or break your day? No, but in the end I was able to get a bike with very similar geo and travel for 3lb lighter even with a chunky AXS Reverb dropper on it, while also saving a few grand. That was just too many things for me to look past for the sake of having a really cool boutique bike.
fwiw after pouring a lot of time into my custom ZFS-5 build my honest conclusion is I should have just bought an Epic 8 and called it a day. I have something that is technically lighter and cheaper, but I spent a lot of time on it for the sake of being non-conforming that I don’t really think was worth it in the end. Turns out people buy Epic’s because they’re good.
Meanwhile I’m making my EE cry
Spend my money!
Here are my KPCs:
2x bottle cages
High anti-squat (similar to 2020 OIZ)
~67* head tube
Fox factory suspension (34sc fork)
Under $9k, bonus points for every $ under
Brands/Model:
Cervelo/ZFS-5
Orbea/OIZ
C-Dale/Scalpel
Scott/Spark - out for anti squat
Allied/BC40
Pivot/Mach 4SL- out for 2x bottle mounts
Giant/Anthem - out for 2x bottle mounts
Norco/revolver - just kind of uninspiring
Assumptions:
XTR build kit
Most likely will remove dropper and stick with my high post
Wheels and tires are a minor consideration for what is supplied OEM. IE if two bikes are “tied” but for the same money I can get better wheels, that may sway me
Should be able to get some discounting if I play my cards right for everything but the Allied
Well the Scalpel is now available with standard forks or a Lefty, but Boost off set is standard too, so replacing wheels doesn’t require AI offset gymnastics.
I have the 2021 gen with a Lefty 120 which makes it about as slack as current gen, and it’s super stable but very responsive even with my 700ml bars. Even with the lockout off, for me suspension bobbing is minimal at best.
The only one that Cannondale lists that comes with XTR is the 2021 Hi-Mod, so that might strike things for you.
Well noted on the Scalpel, they have to be the only brand that offers AXS on a Fox suspension build.
I feel like the antisquat on my ZFS-5 is way better than my 2019 Oiz, but some of that may be that mine has RS and the tune is less plush than Fox.
My whole sthick has been that the ZFS-5 120 is a great bike if you can find it on sale, but no one seems to have the Shimano spec at all, let alone on sale.
Not a bad deal on a SRAM build though.
The OIZ XTR build is hard to beat for the price. Plus it comes with Fox factory suspension and meets all of your requirements.
Ouch, just straight seatpost?! Time to convert to dropper now!
Ouch, do you think it was a part defect or do you just shred the gnar so hard that straight posts can’t handle it?
Only one with the Lefty is the Lab71 for US market I believe, which puts it into a price point up in the heavens
The Scalpel 1 & 2 are listed as available with a Lefty, but I haven’t seen one in the wild.
I took the dropper off to save weight!
No I don’t think it was a defect. I don’t know what the proper term is but I make the suspension do a lot of the work as opposed to standing up, we call it humping the bike here and a good example is I power up to a oncoming steep uphill/roller and just stay seated as the bike “humps” it
Here’s what I think happened
  1. I don’t even remember where that seatpost came from but it’s crazy light (145g total).
  2. I “hump” the bike, it’s just my riding style
  3. I’m over 90+kg
  4. There is a lot of seat-post extension/exposed.
I really think the seatpost was too light/weak.
I put a Race Face NEXT post on the bike now, it’s pretty sturdy.
About the BC40 being heavy.
The BC40 that Dylan Johnson built is a M frame that comes in at 10.26 kg or 22.5 lbs.
Not flight attendant but Fox and Sram AXS build-kit and some pretty cool parts. But still, that weight is pretty good for a full suspension bike with a dropper post.
Link to bike:
https://www.instagram.com/p/C5qso9WOUil/?utm_source=ig_web_copy_link&igsh=MzRlODBiNWFlZA==
PS: not a fanboy of DJ, I just remembered I found the weight of his bike pretty impressive.
I’m hesitant to weigh in for fear of it looking like a have vendetta against this bike, again I think it’s a killer bike, but Dylan’s build is running 100m Fox 32, an extravagant custom 1 piece handlebar and stem, previous non-T type eagle, very light and minimal tread tires, and what looks like to be at most a 75mm drop Transfer SL.
This is weight weenie build that you’d only run for light non-technical trails, which makes sense since it was his Sea Otter build.
There are multiple reviews out there from Pinkbike, Escape, Pros Closet, etc with real world weights. With an actual 120 spec it’s a 24-25lb bike. That’s fine, you can just get a good bit lighter for cheaper if you care about that sort of thing.
at this point seems like the Yeti or Sworks Epic 8 are the lightest bikes you can build with the same components? The yeti might even be lighter than the Epic
I believe the yeti frame/fork is slightly heavier than than the s-works epic, but it’s a little lighter than the regular epic. But they are all really close. The epic does have the in-frame storage compartment adding some weight, but that’s a good trade off in my opinion.
The top of the line ASR and the S-works Epic both come in under 23 lbs and both include the “heavy” reverb dropper and flight attendant suspension. You could easily get either of them under 22lbs with pedals if you wanted to go full weight weenie.
