Well i did the sweetspot base low volume 1 and 2 and then a sustained power build also low volume. I think i really hit home my recovery with this. Getting enogh sleep also was a massive gamechanger. And of course nutrition. I stopped focussing on loosing weight but rather on performance. Weight stayed the same but the power spiked.
Good job! Let yourself be inspired by your huge improvements: 40% FTP increase and 4,4% weight loss. Probably you gained muscle mass so your bodyfat loss is most likely even more than 5%.
Only a month into TR but I’ve seen some improvements
March 23 2021. 120- zwift
April 26 2021. 147- TR
May 19 2021. 164
17 watt increase in 3 weeks on a LV base. Ended up deleting my plan mid block to account for ride changes and new plans
The ftp change in addition to losing 30 lbs in the last 2 months put me just into 2 w/kg. Goal of 200 watts by september!
Jan 150 —> Feb 182 —> Mar —> 194 —> Today 214
In late September I hit a new high of 237.
After dialing it down in the fall and then ramping training back up in mid-November, by January 7 I was up to back up to 235 and I was stoked.
3 days later, my Dad passed away unexpectedly and I spent 7 weeks living with my Mom while we tried to sort out care for her. By the time I saw my bike again it was March and I was down to 215.
Given all that’s transpired, I’ve taken a more measured approach to my training this spring. I can’t say I’ve been more consistent, but I’ve aimed to chew what I bite, and bite accordingly, rather than biting off more than I can chew.
In April I was up to 228.
This morning I hit 243, my highest Ramp Test FTP ever.
I was pleasantly surprised, I think in part because without group rides (though they are coming back) it’s been harder for me to tell how I’m doing. Also, my headspace has been out of whack with family on my mind, so I just haven’t been feeling the juice! But whatever I’ve been doing has been working.
I notice that without the over/under nature of my weekly group ride that my ability to recover from hard threshold/VO2 efforts is still in early season form. But my sustained power is way ahead of where I’ve been before this time of year.
Fingers crossed that progress continues.
My condolences, sorry to hear about your loss. Hope you guys can all be in a better place.
Those are good gains, which plan were you following?
@Penski Thank you.
Back in the late fall I was working my way through MVSSB, so my base was pretty good.
When I got started back up with training in March I started out with a handful of endurance workouts and easy outside rides just to get back in the flow. Then I picked back up with LVSSB augmented with outside rides. I found that as much as I can get in a groove for two or three weeks on a MV plan, that I haven’t been able to be consistent through a whole MV block. With the LV plan I can hit the key workouts and then have room and capacity for outside rides.
I raced Cat 4 Road and Cyclocross as a Cat 3 from 2013-2016 and burned out. Had good results in 2015 from a coach, but only used Heart Rate. Started and stopped a few times on TR, but have small kids and I just couldn’t figure out riding and family responsibilities. Got bit by the bug to start racing CX again in Fall of 2021 hoping that things would begin to open up this summer. Of course over the years, I gained some weight and maxed at 187 but now I’m at 167.
With lockdown/working from home I started back on TR in October 2020 and stuck with the Low Volume plan. I’m not a fan of the ramp test, so I stick with the 8 min FTP test.
Beginning with the Low Volume SS Base
October 2020 FTP: 162.
December 2020: 197.
Low Volume Build
January 2021 FTP: 236.
February 2021 FTP: 254.
Speciality phase, Rolling Road Race
March 2021 FTP: 269.
April 2021 FTP: 287. <–Using the Assioma’s
Restarting Low Volume Sweet Spot Base
May 2021 FTP: 296.
June 2021 FTP: 309.
August 2021 FTP: 300. ← Ramp Test
The Speciality Phase II test in April 2020 began and I switched my power meter from the PowerTap Pro (hub based) to Favero Assioma’s. So this jump in FTP may be lower if I kept using the same equipment.
Thinking of doing the ramp test next time, the two 8 minute intervals are just brutal. I’m really happy with the results and looking forward to doing CX again this Fall. Saw my first decline in FTP, by 2.9% in August 21. Got included into the AT Beta in late June and had a bunch of VO2 and Threshold work leading up to a gravel event the weekend before the test. Definitely think more sweet spot would have helped improve the FTP number.
Edited a couple times for FTP updates and to improve formatting.
Keep going like that and you’ll have to change your TR handle to BigSur!
Did an FTP test today after a solid five weeks of training. Very happy with the results! Especially after having to make some pretty solid changes in my diet before the block. TSS was around 4100 for the month of May - WK1 21hrs, WK2 18hrs, WK3 25hrs, WK4 17hrs and WK5 12hrs. WK3 included a vEverest on Alpe du Zwift in 11hrs.
Results below:
FTP TEST PRE:
19 April: @289w (3.91 w/kg)
FTP TEST POST:
31 May: @309w (4.31 w/kg)
RESULTS:
End of 5 week block
+20w (+7%) / -2.2kg weight
First thing I would do is check power source indoor and outdoor. Especially with a one sided PM you might be off… Then start asking yourself if you gave it all on the ramp test. You may have poor VO2max and great threshold ![]()
It is indeed a one sided power meter I use indoors and out. I switched to Ramp tests mid season but now I’ve achieved my goal at the first attempt. I might switch back to an 20mins test (or maybe try an 8). I don’t know how accurate Garmin VO2max is, its sitting at 62 parts after a cr@p TT, the highest its been I think after a block of interval training and pre ERG was 75 parts. Its maybe just ERG I don’t get on with ![]()
High threshold in relation to vo2 max (so typical TTer phenotype, combined with low anaerobic capacity) and your ramp test would vastly underestimate your FTP. You cannot have high FTP and poor vo2 max ![]()
It’s all relative, isn‘t it? My high explanatory skills were just no match for my great analysis. ![]()
Went from 260 to 267 today. After my first 6 weeks with trainerroad. However, 260 was determined via a ramp test with Zwift and I think they determine FTP differently than trainerroad and it was set a bit too high. I was probably more around 250-255 when I started (had to drop FTP to 250 in the first week, 255 for second and third week to complete workouts). I also lost 1kg putting me now to 4.17w/kg. This month marks my first year with cycling and I’m pretty happy where I’m at and where it’s going ![]()
Just referring to this chart - I’m endurance trained/training on MTB - does this essentially explain why I struggle at VO2max / FTP tests yet I’m happy to ride for hours at a time at 3wkg?
Depends what do yo reffer as vo2 max and FTP test. If you are thinking about ramp test and 120% of FTP then yes. High percentage of FTP in relation to your MAP power will be cause of the problem (maybe along with anaerobic capacity).
I’d love to understand your response a bit more.
Yes I struggle over 105% FTP (VO2max power) a lot. Its always been a difficult area for me although improved last year to get me to 288w/4wkg FTP. This year I’m following the same plan but FTP has dropped to 282, then 268/3.7wkg using a 20 mins test. After about 12 mins, my legs start to go and I need to “pause” for 30s regather and go again and this happened 3-4 times over the final 8 mins - I just can’t get through it and was really hoping to keep improving my FTP.
The latter FTP was set after Iowered my expectation of a negative split down to 270> 300 through the 20 mins but still “paused” twice in the final 8 mins.
To simplify things quite a lot - your FTP falls into a certain percentage of VO2 max:
So when you are operating just above FTP, let’s say 105% your FTP is getting closer to your maximal oxygen demand:
Getting closer to vo2 max causes faster fatigue. Think about certain riders like TTers - the power monster that can hold high wattage for a 40k TT but they do not have any “snap” for harder efforts on short climbs or sprints. Their FTP is probably as high as can get close to VO2 max. On the other side, you have sprinters - guys with enormous sprint but their FTP generally is on the lower side - they have the huge anaerobic capacity (so ability to work over FTP) but their FTP falls lower to VO2 max - so they will not win many TTs,
Of course, this is a generalization because there are many other factors (like mentioned anaerobic capacity, fibre composition etc). This can be analyzed better when checking the full power curve.
This sounds like a muscle endurance problem more than anything. Can be a problem with lactate’s byproducts clearing (you need a lot of Z2 riding and O/U, but mostly Z2) or not enough training over FTP. Both these things helped me a lot during this year of training. My TTE was 60 min but anything over FTP was torture. Adding a lot more Z2 (in comparison to last year) and some O/U intervals reduced the problem - and my FTP stays on similar levels to VO2 max the whole time.
Tested out this morning - 344 up from 333, +11 watts. Been hunting for 340+ for awhile, so I was pretty hyped😁
