Finished ssblv1 and ssblv2 and gone from 212w to 222w, ready to start short power build.
Second highest watt per kilo since training but I think if I wasn’t power matching it would be higher. My cranks are about 10w lower than turbo. If we weren’t locked down either my weight would also be a lot lower! Which bodes well for post lockdown rides.
This is not so much an FTP brag as it is a thumbs up to structured training. My FTP is way lower than previously at the moment.
Looking back at my data for the past few years I’ve managed to bump my off the couch FTP up to 200 after 3 months of nearly nothing. That’s also 200 solid in LV that I was able to increase volume on within 4 weeks without noticeable fatigue.
Given that I hadn’t cycled for nearly 20 years when I started on TR, that’s pretty freaking solid. My best guess at FTP as a beginner cyclist was 160 (if I compare virtual power to my current power meter/trainer).
I’m actually more proud of this “off the couch FTP” than I am of my best ever.
Here’s to the next ramp test.
Started back on TR in October after a few years away. Previously I’d been using virtual power but got a 4iiii power meter to get more consistent figures.
I’m 61 and weigh 85-86kg. Started with an FTP of 241W so 2.83W/kg. Since then I’ve done SSB LV1 & LV2, Sustained Power Build LV and am now on Climbing Road Race Speciality, I know there’s no point really in doing Speciality but when I’d last used TR I never got to speciality since by then winter had ended so I rode outside. Anyway my FTP is now 266W so 3.13W/kg an increase of 10%. However that’s pretty much across the board, here’s my power curves comparing Base and Build:
There’s a fairly consistent 25-30W increase. Not so much in the sprints but I’m not really a sprinter.
I seem to underperform on the Ramp Test but I do so consistently so I’ve a good feel for what I should be doing. The 266W was gained on a Ramp Test and not subject to any “fiddle factor”.
I remember from one of the podcasts that Chad or Nate said that for older riders it wasn’t so much about improving FTP but maintaining it. I’d like to get to 3.5W/kg which at current weight would be 297W, might be a big ask.
Here is my FTP progress since the beginning of last year. I came back from an injury Jan '19 so that’s why the curve is quite steep at that period. All tests are from the Ramp Test protocol.
And a question to you guys, how does 8 min best from your power curve compare to your FTP in terms of percentages? I held 370W for 8 mins i.e. ~1,17% of FTP and thinking whether it’s time for a new Ramp…
I recently changed up to mid volume and my latest FTP test went up 11%. I was really on form on that day. As I expected, I bit off more than I could chew and the hard intervals on Monadnock +4 were more than I could muster. Toxic night sweats and cold symptoms too.
I’ve knocked my FTP down by 5% so I can get some quality back into my sessions. Not dreading the workouts now.
My FTP is 266W and from my personal records page my best 8min power is 298W so that’s 112%. If I’d done the 8min FTP test and applied the 90% to that figure I’d end up with 268W which is well within the error range of my power meter.
I did the classic beginner mistake and jumped into SSBHV1 as my first introduction to structured training and got muscle strains before the last couple of workouts so skipped them and ended up having a slightly extended recovery week. Went from FTP of 301 to 317 and 88kg to 86Kg over 6 weeks (3.42 W/Kg to 3.68 W/Kg).
Now onto SSBMV2 for a more sustainable training load, adding in the occasional run and strength stuff.
Keep in mind with the 8 minute test you need to repeat the effort twice with an anaerobic “drainer” in the beginning. That being said if your workouts are feeling on the easier side, and if you’re a bit out from your next scheduled ramp test, test again.
I set a 8 minute power pr 3 days ago as it were, at 376w, (ftp 331) which is 113%. Effort probably wouldn’t be repeatable, maybe at closer to 112%
Ramp test before SSB2 HV was 282, just finished it and ramp test now was 301. Probably a little skewed tho cuz I could have gone a little longer on the 282, and I had nothing left to give on this one (I really wanted to hit 300). But Im still pretty happy, thought before test I might have actually gone down some, heh.
I think I just need to make sure that it wasn’t an off day b/c to your point I was consistent and nailing all workouts so I was confident there would be a gain. If it’s still under then I’ll just increase the percentage slightly.
Do I take this as an increase?
Was at 259w in Oct, didn’t train for months after a crash so jumped back in at 250w a few weeks ago.
Just did a ramp test where the last minute was 355w (266 FTP) but…
When moving from 325w to 340w I changed 2 gears instead of 1 and completely lost power and concentration, to then get back and hit the 355w minute at 359w then was done.
Do I need to retest or set it at 266w?
FWIW I was not rested either after doing Mills @ 88TSS yesterday.
