Thanks for the detailed answer.
Oh nice, keep us updated on your Aerotune experimentations!
I am/we are really interested in knowing more on the subject.
Sometimes stiffer carbon rims actually would cause more of an issue with this. Because the rim doesn’t deform as much at the road it then shifts out of plane more. It also can cause some issue with brake rub in rim brake bikes. Not sure this would cause much issue at the chainstay though.
I have Roval Terra CLX wheels on my OPEN U.P.
When I’m riding off-road I pair these with 40mm WTB Raddler tires.
But on-road I run the same wheels with 28mm Conti GP5000 which come up at ~30mm owing to the 25mm internal rim width of the Rovals. They’re incredibly comfortable in the road configuration (60/65 psi front/rear).
I can only achieve the same level of comfort with my Enve 3.4 SES wheels on my road bike by pairing with 27mm tubeless tires and running them at 50/55 psi front/rear.
Wider tires seem waaaaay more comfortable to me. I don’t think there’s any noticeable difference in speed, at least not the speeds I ride at (25-35 km/h depending on how lumpy it is).
A better option than the hypothetical tubeless Rene Herse 32s are the tubeless Conti 5000 32s. I’ve been using these exclusively for my road setup on my gravel bike and have been very durable. I use them on a mixture of pavement and gravel and haven’t had any flats with thousands of km (actually on my second set). They roll very fast and seal perfectly.
I normally get mine from bike24, and just checked their stock - 17 to 18 weeks it’s stating!
I guess I better nurse mine and buy another set over the winter.
Sounds PLUSH! For some reason our bike shop recommended 33mm tires from my Domane gravel set up, 38mm must float.
That Flo test, if valid, don’t make the case for aero wheels at all.
They are saying that the difference between their 49mm wheel and their 77mm wheel is negligible. Even the difference between 49mm and 77mm + disc is hardly anything.
And 25mm tire on the 49mm rim versus the 32mm tire is about 1/2 watt. So 105% rule is meaningless?
Their chart shows only 1m20s to 1m30s savings over a Mavic Open Pro on a 40km TT.
Those figures sound, intuitively, about right to me.
I’ve just listened to Chris Boardman commentating on the world TT champs for the BBC, noting that 80% of all air resistance was down to body position, with clothing coming in next, followed by wheels and helmet. As an aside, he noted the shaping of the actual bike was almost an irrelevance until you’re looking for those last few seconds at the highest level.
If we (generously) proportion say 10% of air resistance to wheels, then a 90s difference over a 50 minute event (not for me lol), or 3%, seems about right.
Much less scientifically, over a long, steady ride I notice perhaps a 0.3-0.4kph average speed difference between my bike with alloys and my bike with mid-section carbon rims. Now, there are dozens of differences between the bikes, so this is hardly a robust finding, but a just over 1% difference at ‘cruising’ speed likewise seems to make sense to me.
I just expected there to be a much bigger difference between 49mm wheels and 77mm wheels or 77mm+disc. I also expected there to be a larger difference between 25mm and 32mm non-aero optimized. That’s all.
If they don’t factor in yaw at all, then maybe that is the issue. I know Zipp was famous for their “time saved in a 40km TT” charts but they probably always used the 15 degree part of the chart to make their claim.
I have 50mm wheels on my bike. They seemed to have made a good bit of difference. It’s hard to quantify but I set a lot of new PRs and got KOMs after I got the wheels.
I think about safety too. How well your bike deals with road anomalies will depend on the size of the tire relative to the anomaly. Larger tires are thus a benefit. I don’t want to rely on constant attention for my safety, because I know that isn’t possible (whether due to fatigue, or getting distracted by a car, or having the sun pop into your eyes, or being in a group and left with no option but forward). I use 650b with Rene Herse 48mm tires. I have no problems keeping up in group rides. If I have 48mm Rene Herse knobbies instead of slicks on the bike, then it feels like I have to pedal a bit harder.
FLO put out some interesting podcasts. The CEO did a whole series on how they did their testing, that was really informative.
Do you think it applies to say an aero road bike vs. a traditional steel bike? Or do you think TT bikes are fast because of position and not so much tube shape?
The reason I ask is my 2020 Domane is so much slower than my 2011 Shiv…but there is a huge position difference that is hard to quantify. It’s literally like 18mph vs. 20mph with the same effort. My 40K bike (Premier Tactical) with the skin suit and aero helmet is another mph faster FWIW.
Also, when it comes to actual rides on actual roads…the domane is my go-to. I can take evasive action with aplomb, it has great brakes, and I feel the bike will take care of me. Vs. the TT bikes who don’t really care about me at all and don’t even slow down much less stop.
Joe
Both, but the biggest gains are from position.
Well I think this too (that position and frame make a difference but position more) but Boardman…who probably knows a thing or two about going fast…apparently doesn’t.
How can that even be true? I mean…he rode the Lotus! Not some round tube steel job, right?
Joe
Well it’s almost an irrelevance for me and probably 95% of this board, but if you’re going for the hour record or world title, then the very small gains attributable directly to the frame are relevant. I think Xavier Disley puts it well:
So for some people, 2,3,5w gains make all the difference in the world, but for most of us, they don’t, and that’s what I think Boardman was getting at.
He was also looking for the last few seconds at the highest level ![]()
I’m sure there is some hyperbole in his statement….but he is absolutely correct that the vast majority of the gains are through position. If you put someone in a good TT position on a round-tuned bike and compared their time to aero TT frame but riding in a “road”position, they’ll be significantly faster on the round tubed bike.
But if you put them on identical positions on the two frames, they will be faster, but to a much smaller margin, on the TT frame.
Yes, it’s all part of marginal gains and at the highest level, marginal gains can add up to something meaningful.
However, marginal gains can add up to net losses in average situations. If you have a 54-tooth chain ring for efficiency reasons, you reduce the number of usable gears in most situations, especially outside of race scenarios. (There are very few places where I live where I can safely (!) go beyond 70 km/h.) And you are limiting the number of climbing gears. Are 1–3 W saved in your gears worth grinding uphill? (Plus, most people don’t clean their drive trains sufficiently often, myself included. That’s often worth much more added friction.)
Ditto for running 28 mm instead of 32 mm tires. Having a more comfortable ride with more grip is another marginal gain that could be a net loss for many riders.
Personally, I think many performance-oriented people forget about the big gains amateurs can make: proper bike fit, proper body position (which includes e. g. working on your flexibility and your core), proper gearing so that you don’t grind uphill, working on bike handling, etc. Now pros are much closer to the theoretical optimum here than we are (than I am, I should probably say).
Since one year I am using 28 mm conti 5000 tl.
And I love this smooth ride feel. When I began cycling we are on 19 mm
Full recommendation for 28 mm on the road.
