Who is riding wide tires (35-42 mm) on the road?
35mm GP5000 + Roval Terra Aero CLX + 40psi = super fast and comfy. They measure 37mm and it results in perfect 1.05 rule fit.
Good to know. What bike are you running that on? The Crux 5?
Very true and I have struggled mightily with plugs above around 45 psi.
Mog
Got any pics?
I’m using Stan’s new Rolled Goal sealant in my road tires. It’s supposed to be better for high pressures. We’ll see…
Does riding 32mm vs 35mm nominal-width tires feel different on the road and carving down mountains?
If accompanied with lower pressures then incrementally, yes. But also depends on road surface - if it’s dry and great tarmac then you’re not really going to notice any difference in ride quality or grip, if anything the wider tire is going to feel a little more sluggish.
I noticed a huge difference going from 25 to 28.
And a similar albeit not as big jump when going from 28 to 32.
But 32 to 35, I can barely tell.
55mm’s on the other hand I can tell, but what it gives in comfort it frustrates with a feeling of riding a slug.
Yes if tarmac is not perfect.
In my experience 32 and 35 are very similar, but wider in general provides much more immunity to bumps and road imperfections, and provides better cornering traction. That give me more confidence to corner at higher speeds.
For a while i was rocking Spec Roubaix they seemed to measure out around 35-38 on a given day.
Have since moved to 32mm (?) GP500) and, honestly, miss the volume.
In what way?
Leading on from the above points I’ve narrowed down to the following options:
They’ll be going H-Son Hyrda rims at 20mm internal 25mm external for the everything bike, pure summer speed isn’t require as I’m the last of the rim brake riders (or so it seems!) and I’m a smaller dude at 67kg. I’m leaning towards the 34mm since it’s a bundle so a about 15 quid cheaper (but Halfords do have a couple other Eagle options at damn near the same price which doesn’t help).
For the all day long distance - I want to do some more >200km again when healthy I’m leaning towards the comfort factor.
I will accept I am prob over thinking this as a 215W ftp (well it was in Aug) rider, but that’s all I can do on bikes right now is think about it!
I’d challenge this and say the tire itself will have a bigger effect, not necessarily the width by itself. I’ve been running GP5000 in 35 (inflate to 39mm) for around 4 months now and I wouldn’t say they’re any more sluggish feeling than 32s or even 30s of the same tire. I recently rode some 38 Corsa Pro Control that inflated to right at 40mm and they feel like riding in mud. So I wouldn’t say it’s that 1mm width difference that explains the feeling. I think it’s the tire makeup.
I’m wondering if what you’re feeling is the added comfort and equating it to sluggishness. Much like on gravel where the wider tires felt slower because they were just more comfortable and people were hesitant because they thought they were going slower. Maybe the wider tires are just soaking up the road chatter better and are more comfortable overall so they end up feeling a little sluggish to you. Just a thought. Or the added weight which could be felt
My favorite setup is still 32s on a 29int rim that inflate out to 35.6mm. The external on the rims is 36.7mm so they create a very clean transition. And you get all the benefits of a wider tire with the weight of a 32. Best of all worlds.
In the last year or 2 I’ve run the same tires (GP5000s) across various bikes and wheels in sizes from 25 to 35mm. 35mm feels a little more sluggish in terms of how nimble they are if really pushing through a corner on good tarmac (if it’s a crappy surface then the extra grip more than makes up for it) and in terms of holding my own on fast group rides with a lot of surges and accelerations. It’s very possible that it’s the lower pressure. It’s also possible that it’s because I don’t currently have any road wheels that are well suited to a 35mm tire so they bulge out a fair bit wider than the rims which is maybe costing enough aero watts at high speeds to be noticeable.
As I’ve said above, I’m a big fan of the 35s for most riding and am looking at getting some wheels that will work well with them. Just if it comes to racing or going fast on a decent surface I think the optimum is still around 28 or maybe 30. Pro peloton seems to have reached the same conclusion with current technology at least. Albeit they’re a fair bit faster, lighter and have better tarmac than I do!
Merlin cycles have gp5000 on special offer which makes it very affordable for top end tyres so the decision needs making.
It’ll be doing audax/everything/mudguarded rig with hson hydra rims (20mm internal). I’ve been leaning towards the 32s from the comments above, especially if they run a bit wider. But 35mm does sound comfortable even if they’re not tan wall!
Not tan wall?! I think you answered your own question.
Hah! 32 feels great to me nowadays. Cushy. Perhaps I’m just getting old…
