An air pig is cheaper than a compressor, it’s just a tank that you fill up at a gas station or from another compressor. Sometimes a used one might only cost 20$.
I’ve been running tubeless on all my bikes (road, gravel, mountain, fat) for 10+ years and have encountered many frustrations along the way, so have learned the hard way!
The root causes for this include:
There is a dried piece of sealant between the tire and the rim, preventing sealing
The tire bead is not fully seated against the rim
The tire diameter is too big for the wheel by a small amount
The solution for each is a bit different:
Clean off the dried pieces of sealant.
Pump the tire up to a higher pressure to get the tire to seat fully against the rim.
Install additional layers of rim tape to increase the effective diameter of the wheel
I had to replace a tyre last year (Vittoria Rubino on DT Swiss rim) which drove me to distraction. The old tyre (also a Rubino) seated perfectly with just a track pump, but this one was having none of it; cleaning, pumping furiously, soapy water - nothing. An Airshot finally got it seated and it has remained seated thankfully. A compressor would probably have been the more flexible long-term choice, but more expensive, plus there’s a nice simplicity to the Airshot and build quality that doesn’t feel like it’ll explode!
