Looking at the numbers, (from memory) the reach would be compensated from going from a 130mm stem to around an 110mm or so, and the stack would have stood me up a little, if anything a more comfortable position.
Realistically the 61 would likely have been too big, but I reckon I would fit a 58 just fine with an almost unnoticeable change.
I’m at the point in the year where my feet stop me from riding as much as I’d want to.
Mountain bike. Anything 2 hours and over, the balls of my feet hurt. I’ve got different shoes and custom insoles. Cleats are about 20-22mm behind the first met.
I can go back a little farther with the shoes I have.
It’s annoying as crap.
Hump
- What specifically?
- Aimed at addressing what specifically (guided and provide by whom)?
- Can’t likely hurt to try it and see what happens. If you slide them back more than a little bit, you may need to drop your saddle a tad too.
Outside questions:
What is your typical cadence and is this issue “new” for you in this use vs prior similar riding? If it happens to be on the lower side, it may be related to the overall force you apply to the foot.
Have you ever been better than this before, to maybe find some additional direction?
Shoes: Sidi, Specialized, Lake
Currently riding Sidis. Raced Sidis for years on the road with minimal to no issue.
Specialized BG Insoles, heat molded. No specific podiatrist fix, using for support. Second set.
Seems to have come on now that I’m riding MTB more. Early on when I first started riding road years ago, it would happen.
Depends on what you mean by issues. I have not really heard of or seen people have issues of pain or discomfort with large rear biased cleats. It may feel odd to be more centered over the pedal, and can seem like the foot loses power to some people once you get away from the forefoot. It decreases the impact of the 3rd joint motion at the ankle.
But like any change, take it in a small step if you are concerned, and certainly reset if you experience new or different pain vs the relief that is the aim.
Meaning, if you go all the way back and then get pain in the forefoot?
If I set my cleats up centered between the first and fifth met head, I’m 15mm behind the first met head.
That’s a neutral position, based off my reading.
Steve Hoggs method #1 says I could be starting 9-11 based off my foot size, which almost would feel like I’m riding on my tip toes.
Hump
- Yeah, if you shift in any direction really and get pain, consider if that change is problematic and reset as needed. On occasion, the change may be desired and some other position (saddle height, fore-aft, etc.) may need adjustment.
The Hogg and “new neutral” centered between the 1st/5th met heads are just good starting points. As ever, people may need to shift forward or rearward from either of those to suit their particular needs.
Do you find back farther more times than not?
I’ve been as far back as 20-22mm behind the first met head.
“New Neutral” as you mentioned for me is around 15mm
Didn’t really start getting this type of pain until it got hot and from riding MTB.
Don’t recall it when I raced and trained strictly road.
Hump
- I am not sure I understand the question.
If I had to generalize, more rearward seems best with respect to foot pain and discomfort, but that still doesn’t work for everyone.
Meaning when you got someone, are you seeing that more people need the cleats farther back than the New Neutral?
Hump
Ok. No, I seem to have moat people happy with the New Neutral location and only small numbers needing more aft positions.
Quiz for fitters:
Quick thoughts from the clip & single view:
- Leg length discrepancy
- Range of motion or other physical asymmetry between left-right lower body
- Saddle width too narrow or other injury history leading to offset position on the saddle
- Asymmetry above the hips that the mid section is trying to adapt
Was interested because this past week I noticed something going on with my hips and saddle - my right sit bone was slightly ahead of my left sit bone. I’d notice something was not right, and then reposition on the saddle to square up.
Any new injury or discomfort you could think might be leading to the offset position?
Could be some of what I mentioned above, but even stuff like a sore back, neck or other issue can lead to poor position.
Think I’m just a little stiff after taking a break and ramping up volume. I’m stepping up my core work.
That sure could be the case. Worth keeping an eye on it to see if you improve after you get accustomed to the work again.
2nd guess above, BOOM!!! ![]()
