I’m doing a self-designed progression, coming off of a broken collarbone and 3 weeks “on the couch” I started easy with 5x10@90%, and have progressed in three weeks-plus a rest week to 3x25@90%. FTP baseline was 248, FTP last test was 274 (maintained 282 for 36 min). TTE at 248 was 35min, TTE at 274 FTP is 49:00. (My peak FTP (ramp test) is 284, but TTE was less than 40min).
I consistently set power records over an hour with some of the longer SS workouts. 3x25 has definitely reached the “Very Challenging” level at current FTP. My structure for this current three-week work block is:
M: Long SST intervals
T: Easy hour + max cadence sprints
W: Long Steady Tempo
R: Off
F: Long SST intervals
S: Long, steady Z2 (3.5+hrs)
S: Off
This will be my last “extensive” block. I’ll be switching to true FTP work next block (higher power, but less overall TiZ).
Thus far, I’m very pleased with my “something in between MV and HV” program. Last block was about 475TSS per week. This one will be more like 550TSS, which will be the highest I’ve done for a block, but feels very manageable all sub-threshold. Hope to knock out a 1x90@90% by the end of the block.
I think I’ve read all the posts here, so forgive me if I’m missed an answer to my question…
I’ve basically put together my own SS block similar to many others here. Basically 3 SS workouts per week for 3 weeks, with a recovery week to follow. So far it’s going well, and I expect to be able to stay on the plan progression.
My questions concerns how to follow it.
Currently I’ve scheduled a vo2 block to follow this one. So I’ll be doing 3 weeks of vo2 focus + 1 recovery week, then back to another SS block.
Where to start that second SS block is what I’m concerning myself with. If I’m relating it to my current 3 week block, it makes sense to me that I may be able to start a bit further along than where I started my current one.
My current block is
week 1 ends with a 1x45 SS effort,
week 2 ends with 1x60, and
week 3 ends with 1x75.
Do you think it’s safe to say that my second block I could start with a week that ends in 1x60 (essentially week 2 of my current block) or should I expect to lose more than that during my vo2 focused block? I know we’re all different, blah blah blah. I’m just curious if others have done something similar (rotated blocks), and what the experience was like.
Also, if you all think a vo2 focused block splitting them up is a bad idea, I’d love to hear why. I’m mixing it in, because…
I like it
I don’t want to lose that part of my fitness more than is necessary.
Sounds like great progress! I’ve had a similar experience; PRs on basically every long SS ride, etc. Definitely ready to do some higher intensity work after a couple months of this
I don’t think you’ll lose anything in such a short time, while you’re still on the bike several times a week doing intervals.
You don’t say what your weeks look like, but maybe do 1x60 in your first SST workout of the new block and 1x75 by the end of the first week. Or if you’re feeling adventurous, just jump in at 75, and stop after 60 mins if it’s too much.
I am doing almost the same!
I completed the 1x75min 2 weeks ago, am now in my second and last week of VO2.
Instead of pushing the time out from 75min, I am going back to start of the sweetspot progression with a 5% (manual, no test) bump in FTP.
Great results and really good to see more success - I really do think this is proving a very successful strategy for many people.
Like you I’m about at the end and plan a big finale of 100 mins on Saturday - probably a 4x25m. Then its a test next week so will be very interesting to see what the ramp test tells me about FTP gains… The way the latest sessions have been feeling makes me very optimistic.
I think it will depend on what happens to your FTP after the 2 blocks. If you get a good bump after that then you may need to go back to shorter intervals in order to build TTE out, but if it doesn’t change that much then you could probably pick up pretty much where you left off.
As FTP goes up the TTE goes down, sometimes very significantly, so you may just need to just jump in and see what you can do?
Just based on the Trainerroad podcast and the Kolie Moore’s podcast. If I recall right, they both talk about quickly reaching a plateau with VO2 max. I think some say it can happen as early as 4 workouts?
So I decided to try 2 weeks of: 30/15s, 4x5min & 3x8min
Good point about the ftp change. I’m more than a little curious to see what happens at the end of this block. My time-on-bike is down right right now (compared to a month ago), but the time is more focused. Should be interesting.
I’ve also read/heard from several sources about the idea that most of the adaption comes from the first 6-8 workouts (not just with vo2 work) so I am inclined to agree with you that a short block can be enough. I plan a 4 week (3+1) FTP block followed by a 4 week vo2 block, after Xmas.
It’s a good strategy for this time of year. The important caveat is that I think there needs to be a long Z2 ride coupled with all of the SST progress. That way you come out of these training blocks with strong legs and good aerobic adaptation as well.
As my volume has increased, I dropped one of the SST sessions to a steady tempo ride, so just two long SST sessions that I focus on being ready to nail, then the long ride. Those are my three “key” workouts. If I have to shorten the tempo or drop the short Z2 on Tuesday, I don’t worry about it.
Jumped from 75 mins last week to 120 mins this week. I only put my FTP up 5w since last time I did this one, so knew it was achievable. The only battle was with fatigue, this being the 3rd day of SST in a row it was an effort to keep the cadence up in the 2nd hour.
After 50 mins I felt like I’d had enough, after 80 mins I really just couldn’t be assed, but sometimes you’ve just got to embrace the suck.
I do have wko5 but I am going simpler - 4 weeks long tempo and 8 weeks SST is enough for me to see gains but not long enough to stagnate. Many coaches suggest 1-2 blocks with a single focus is plenty and then its time to move on. I’ve also heard it said a few times that it might be as little as 6-8 sessions that is needed to see pretty much all the adaptions from a block of training.
I’d strongly recommend the wko educational webinars with Tim Cusick discussing endurance, TTE, fatigue resistance etc, even if you dont use wko, as he talks a lot about all of this as well.
No… i do not accept this because now I would have to do 120 min, again, with my new ftp and I do not want to please delete this workout from your history
But 2h is always better than 1h because longer is better Recently work really messed my plans with training and I will have back to tracks. But I will have 2h at back of my head in the next block.
