I actually love Antelope as a workout because of the short recoveries. Some of the versions have slightly longer recoveries and I will almost always go with the shorter recovery version because I know I don’t need the extra rest. I think it’s a fantastic workout to use for adjusting to a new FTP as well.
Yep, spot on
They drop down to 40% for the rest intervals, so not even Z2. I’ll have to do some tweaking
I believe it’s to cater for a wider range of users who may be new to TR. For me personally I would skip ahead and start with 15-20 minute intervals.
I haven’t listened to that episode of the podcast; what kind of adaptations are they talking about (@empiricalcycling)? When they talk about 10 minutes being the minimum at “threshold”, do they mean literally 100% FTP, or the traditional 91-105% zone? Like @mcneese.chad said, Antelope (and variants) is in a gazillion of the base plans, so TR is probably using it to target the aerobic-base-y stuff (mitochondria, glycogen storage, yadda yadda). Is 5x10 SS (and by extension the 4x8, 5x7, 7x6, etc. sets that make up most of SSB) too short for that purpose?
Always about the zone. (as far as I know Kolie likes to “lower” your FTP 2-3% so you are staying below your FTP but in zone). The idea is that cells attempts to reset themselfes to resting condition, and you do not want this. So according to Kolie - 10 minutes is the minium interval time to see some gains and after the condition of 10 minutes is met, the TiZ is more important than interval lenght. So 7x10 is better than 3x15. Of course there is also a case of TTE - if your TTE is 60 minutes, doing 4x10 minutes of FTP will not challenge your systems, so you want TiZ to be longer than your TTE.
That being said, I dont really see the point of intervallising (is that a word?) Sst work to small units. 30 or even 60 min chunks are perfectly doable and repeatable if a real world FTP is being used as a point of reference. Going long you get to deal with central fatigue, holding form, and resist the urge to quit beside TIZ.
Just my $0.02, of course.
Ok thanks, that makes a lot of sense. From this thread and the way the TR plans are set up, it sounds like we can sort of focus sweet spot work in a couple (almost orthogonal?) directions: strength endurance/fatigue resistance (so that’s this thread, with increasingly longer interval times and TiZ), and base-building (Ericsson, Carson, Monitor, Antelope, etc.). Is that right? If I do a two-hour Z2 ride on the trainer, I get aerobic adaptations even though I’m nowhere close to exhaustion, so increasing TTE is more about the fatigue-resistance goal?
Seems logical. I am not sure it was the intention but you can treat this in that way. I was thinking about more experienced people that need more stimulus than 10 min ss intervals but on the other hand these are people that work with coach or use their own workouts.
At least with SS there are some longer sessions. With threshold there is more of a problem because long threshold workouts are usually replaced with suprathreshold and I am not sure if this is a good replacement (as you can see the number of people that struggle with SPB is huge. Changing the suprathreshold with threshold workouts makes all the difference in my personal experience).
as long as you’re increasing duration or watts, you’re heading in the right direction. There’s a lot of 88-90% thrown around here, and while I’m not one to nitpick, by definition that’s not sweet spot and it’s just tempo…bump it up towards 93-94%; doesn’t seem like much, but it def makes a difference IMO…so those time durations but at 92%; then at 94%; once you’re doing 90minutes of it, hit threshold. If you can do 90 minutes of true Sweet Spot, you’ve got solid aerobic fitness; time to pile on the watts.
That just seems wrong. Every definiation of SST I’ve seen starts in the 80s. SST overlaps with zone 3 and 4.
https://www.hunterallenpowerblog.com/2015/05/power-training-zones-101.html
https://fascatcoaching.com/tips/how-to-sweet-spot/
But I agree training in the higher part of SST has it’s benefits.
Yup, Coggan classic levels has tempo at 76-90% and threshold at 91-105%. Coach Frank Overton at FasCat uses a wider range for sweet spot putting it at 84-97%.
Coggan classic levels did not recognize sweet spot, and that changed with the introduction of Coggan iLevels:
In Coggan’s words:
“Based on the logic behind the original approach, levels 1-4 remain anchored to FTP, with the addition of a new level 4a (SweetSpot) at 88-94 percent of FTP to satisfy the requests of numerous coaches who have found value in prescribing workouts at this intensity.”
I was going to reply to @brendanhousler comment stating what you people have but he has a blog post that says sweet spot is 88-97%. Wondering if he means if a rider is only limiting their power to 88-90% then they’re really only riding in z3 versus using the entire sweet spot range using whoever’s definition of sweet spot it is you subscribe to. See if Brendan responds.
Thanks for pointing that out. But I’d never call Sweet Spot 84% even though frank is the creator of it. I worked with his coaches for years and 85% would be called tempo.
My point: go harder.
Brendan John Housler
EVOQ.BIKE - Get Our Newsletter
Strava
LinkedIn
Let’s split the difference. 92.5% only! ![]()
Strava
LinkedIn
I want to preface and say I love all the stuff you put out Brendan, and immensely respect your take. However, I feel like it’s exactly the opposite. For SS, people generally need to go much easier. What you are describing is threshold, and while it has it’s place, has a high physiological toll. SS is firmly 85 to 90% for the purposes here.
I like Monitor+5…only a minute between the intervals …short though they are…fatigue begins to build quite deceptively at the end!
I didn’t read that far back, but to expand a bit on my 10 minute minimum interval lengths… we’re looking for mainly peripheral adaptation with FTP type work, so thinking specifically with respect to the aerobic signaling pathways in cells, and knowing that it takes a little while to “warm up” the aerobic pathways as well as the fact that duration > intensity with regards to this type of signaling, 10 minutes FTP interval is what I think of as the minimum effective dose. IIRC that was a very early episode and I was hesitant about how much depth to get into, as well as not being as confident as I am now in my level of understanding. I may have just mentioned lactate and figured that would be enough?. I also don’t assign FTP intervals >100% of where I think someone’s is, usually a few watts shy.
I would never prescribe a 10 minute SST interval unless someone just got off the couch. My minimum interval length is 20 minutes, if someone can hold that many watts for over an hour. And if you’re having trouble with 20 minutes there, you have much bigger problems. Looking at further comments, I also will submit that anyone being pedantic about how hard SST is or isn’t is trying to justify their own training, or trying to show off. It’s irrelevant.
As for SST progression, if I were being very, VERY nice to someone I’d start 2x20, 4x15, 3x20, 2x30, and so on. For a very experienced athlete, about 90 minutes is a minimum dose, and 2h or more is better as we come up on target races. But on the other side of things, some folks do have a really hard time with increasing TiZ, and we always run into some issue or other. So there aren’t actually any hard and fast rules about anything, which is why I don’t write canned plans. Everything gets individualized, and most of the media I put out there, podcasts, articles, webinars, is geared at helping people individualize their own training.
Sounds good! We all won’t agree on everything, and there are many ways to get things done. Gotta do what feels right to you as the athlete.
Good luck!
Strava
LinkedIn
When you say “by definition” I guess what you are referencing is your definition?
Because I don’t think definitionally what you are saying corresponds to what most people would say about it.
Sweet spot is the percentage of FTP where there is an intersection of Training Effect and Maximum Duration. That intersection isn’t the same for everyone but I don’t know that I have heard someone be as dogmatic as you in terms of the percentages you equate to success.
“Bumping it up” as illustrated in the graph does potentially lead to an increase in FTP but the volume generally needs to decrease as a result.
I guess to play devil’s advocate, I would take your example one additional step. “Bump it up towards 98-99%, doesn’t seem like much, but it def makes a difference.” Yes it makes a difference but there is a reason sweet spot isn’t done at FTP. The improvements are potentially more significant but so are the consequences. Which gets us back to sweet spot. Much of the training benefit without a commensurate level of consequences.
I respect you as an athlete, but I don’t know that your definition of sweet spot is one I will be adopting anytime soon.
.PS - I know you don’t need the graph, just posting for the benefit of others.
