SL8 purchase concerns
Hey folks,
Considering pulling the trigger on an S Works SL8 at some stage fairly soon. This will be in addition to my steel framed Condor Super Acciaio with mechanical Campagnolo Chorus and rim brake.
Quite a change, and unfortunately, no places at all offer a test ride before purchase. Couple of concerns -
Is disk brake rub still a thing? Which groupset offers the best disc brake performance?
Has anyone else gone from a bike similar to my Condor to an SL8 and noticed much difference? The SL8 would be a lot lighter and is carbon as opposed to steel in the Condor.
Cheers!
Just purchased an SL8 last week and now have about 200k on it. So far, I absolutely love it. No brake rub, easy shifting with the SRAM setup, and smooth ride
A brand new modern bike is going to feel pretty awesome.
Any mid-tier and above brakes can work flawlessly if they are set up and cared for properly.
I’ve been a fan of Shimano’s brakes for quite a few years, but I am intrigued to try Sram’s again at some point before too long.
You likely can’t go wrong with whatever comes on an S-Works bike. :person_shrugging:
There is certainly a learning curve with disk brakes. They aren’t as ‘set and forget’ as rim brakes. I’ve had mountain and gravel bikes with disks and they have at times been a big PITA. But you’ll learn the ropes over time or just have a shop service it.
I have a completely different experience. Discs on my road bikes are set and forget, until you ned to change pads. I guess bleeding them every 3ish years is more work…..but otherwise perfecto. The only thing that may cause grief is if you use different wheelsets and the rotor spacing is not the same….that can be annoying, but shims can solve that issue.
I’ve had two bent rotors on two bikes - just a minor out of true but enough to be an annoyance. No idea how they got that way. I haven’t really had squealing brakes at all.
My biggest annoyance has been with my Sram master cylinders. I’ve had two brakes go flat over winter storage. One couldn’t be rebled and still needs to be rebuilt. The other needed to be rebled.
I finally just replaced the rotors and pads on my gravel bike and it has been perfect since minus the lever going flat over the winter.
It’s all manageable but just a small series of PITAs that you don’t get with rim brakes. Maybe Shimano is more set it and forget it? I also find the Sram DOT brake fluid to be annoying to work with. I read that they are switching to mineral oil like Shimano?
Yeah, that’s my experience as well. Much less “routine” hassle compared to rim brakes. With rim brakes (especially on carbon), brakes tend to glaze pretty quick and/or pick up debris (particularly in the rain) and I’d always be pulling them off to sand them down to bring back the braking performance. Disk brakes just work, rain or shine. And besides the improved performance, disk brakes don’t wear out your wheels like rim brakes do. Replacing a rotor is a lot cheaper than replacing a wheel with a worn brake track.
Biggest downside IMO is that so many bikes have cables/hoses routed through the headset these days that you often have to redo brake lines when swapping parts or changing headset bearings. It’s a pain whether you have cable brakes or hydraulic, but hydraulic adds some steps and you can only cut and redo the hoses so many times before you run out of hose and have to buy another set. If you don’t do your own maintenance, something as simple as a headset swap can get really expensive. I guess another negative is if you are swapping wheels. Some hubs have just enough difference in spacing that you might need to adjust your calipers if swapping between wheels. Not always a problem, just depends on the wheels.
Not really. Bed them in as per instructions.
My works SL7 is a killer bike. Very snappy and fast. Shimano groupo. No issues with brake performance. I did ride thru some wet oil durning a rain storm. Replaced the pads and cleaned the rotors with alcohol. No problems.
I do have SRAM on my gravel bike. No issues with those brakes. Both groupos now have adjustable levers for feel and reach.
Just a bit of memory block when shifting.
Get the SL8. It’s amazing. I have an SL7 and love it. You won’t regret it.
Just got a Super Acciaio myself pretty much the same setup as yourself. Tarmacs a popular bike might be able to reach out to someone local through forums and group rides see if anyone will let you test ride that way. If you uses mechanical shifting your likely had to put up with derailleur rub from time to time can’t imagine disc being to much more of a hassle.
Not really, provided that your brakes are set up correctly. I only have a tiny amount of brake rub (a ting) after sustained long descents (think 500 m of elevation difference) with my Force D1 (first-gen Force eTap AXS). And I didn’t have issues with my 105/Ultegra hydraulic drivetrain either.
I think the current king of the hill are SRAM’s latest E1 groupsets (Red, Force and Rival E1), that’s the consensus of the reviews I have read. SRAM redesigned the brake mechanism, the master cylinder is now horizontal, which means it is larger and offers better leverage. The result is that you can consistently rely on 1-finger braking.
To chime in here: disc brakes are not fussy, but you need to learn new maintenance procedures. I’ve had hydraulic disc brakes since 2004 or 2005. In many circumstances, when people write that rim brakes are easier to set up (“set and forget”) one factor is simply experience, they aren’t as used to the new thing. This is mine:
  • You will need much less force to brake with a hydraulic (rim or disc) brake. This was a game changer for me.
  • Disc brakes are virtually maintenance free once set up. Unlike rim brakes, hydraulic disc brakes automatically adjust for wear and don’t need to be centered (something I hated on rim brake bikes I owned).
  • You should clean the rotors and brake pads every once in a while, especially if you rode offroad or in the wet. With installed correctly, I mean that the calipers need to be parallel to the rotors and the rotors need to be straight. When cleaning rotors, you should inspect the pads for wear. It happened to me twice that my brake pads were worn and I hadn’t noticed, because I had zero issues before and was too lazy to clean pads and rotors.
  • Bleeding a bike is definitely a procedure, and might take some time and skill. However, I think it matters what you compare it to. If you e. g. need to replace inner and outer cables of a rim brake bike with internal cable routing, you also need some patience. You can outsource this to your LBS.
  • New brake pads and rotors need to be bedded in.
  • When people complain about noise, I would like that they ride behind a former team mate with fancy Enve carbon rim brake wheels. His brake tracks literally sang :wink:
  • No more training wheels, because your rim is no longer a wear item.
Overall, it is really a no brainer, disc brakes are a lot better. Plus, they allow for new frame shapes and wider tires. (Before anyone responds to that, I know about things like V-brakes, my first mountain bike that I got over 30 years ago had wide tires and rim brakes. :wink:)
This is absolutely critical and often overlooked. Proper bedding not only creates improved braking performance but also reduces many of the problems people associate with disc brakes.
There was a good article on Escape collective about it at one point (might be a subscription article though).
Think it depends enormously on the riding you do. My nice/summer/race bike that rarely gets wet and only travels carefully placed inside the car is exactly as low maintenance as your experience. And my winter and gravel bikes which get used year round in all weathers and get wet, muddy, salty, put in bike bags and chucked in the hold of planes, etc require a lot more maintenance. Bleeding them, adjusting the calipers and cleaning up sticky pistons are pretty regular tasks, and have had to straighten rotors a couple of times as well.
Although any bike that rides a lot in adverse conditions needs to be maintained much, much more often. Your drivetrain components will wear out much more quickly, too. If you have exposed cables, for example, then they may be impacted, too. Another factor is how often and hard you use your brakes. Since I moved to someplace flat, my brakes need minimal maintenance as I rarely use them.
Can you tell the difference between the two? Do you have a favorite?
Only by cost. Both are more capable than me. I do not have the skills to test the limits.
They are very similar. The SL8 is lighter and stock vs stock is more aero. To me the SL7 looks better and is equally aero when used with the Rapide handlebar. You really can’t go wrong with either.
Sworks SL8 is the best bike I’ve ever owned. You’ll have no regrets.
I cannot speak for Shimano but with both Red D1 and E1 brakes and Rival XPLR the brakes are not set and forget. The calipers do not self adjust lihe tgey do on an automotive setup. Lever travel increases as pads wear until the levers will contact the bars. In my cases i need to adjust the pads to regain full brake power. It is not a problem as it is extremely linear and gives much warning. Both rim and disc brakes require maintenance to keep performance consistent just different tasks for each. Discs are without doubt superior in all aspects of performance. Many including myself may argue that rim brakes have a more traditional look and are lighter but it is old tech and the time for them has passed.
That’s surprising to hear. I have a Force D1 setup on my road bike and have never noticed that to be honest. Maybe I am also adjusting to the brakes as they wear, and I have adjusted my brake levers so as to leave ample space between brake levers and fingers/bars when the brakes are fully pulled.
