Silca super secret drip lube - so small
How does it compare to Silca Super Secret if you’ve used both?
I have not used both.
I will say that my initial application of smooth is an “immersion” like fashion.
After the chain is squeaky clean, it gets an alcohol rinse, I dry it, and then put a drop of Smoove on each roller. Then, it goes into a plastic zip lock and it gets dipped in a warm water bath sous-vide style. I’ll do this a few times over a couple of days working the links.
I get fantastic penetration - as good as hot dip. My chains have lasted over 10k miles with no wear measuring on a Park chain checker.
I developed this method based on comments in the Zero Friction reports on drip on waxes. Super Secret though might be a bit expensive for this method. I used a good amount of Smoove for the initial application.
(To clean, I follow Smoove’s instructions of cleaning the chain with biodegradeable degreaser and then reapplying a drop to each link. Works really well. The chain never comes off the bike again until I replace the chain.)
Same results on my Silca hot waxed chains for mtb -about 50-60 miles they sound “dry” but I usually keep riding them to 100 miles. The chains still feel like there is wax inside the rollers, and the plates seem slightly stiff yet. Also, I still use the ole mineral spirits and denatured alcohol method on new chains. I usually never re-strip a waxed chain, just if it take up a lot of sand and gets crunchy. I would say the wear on a dry chain is probably pretty nonexistent, as long as it’s quiet.
I know there’s a few threads on this but…
Do folks have any good solutions for wet or wet-ish mtb rides and a waxed chain? I haven’t found that the silca hot wax lasts. I had a well-lubricated chain with super secret and yesterday when I was out I got rained on for all of 5 minutes and suddenly my chain was making noise. Never mind instances where I might have to do a shallow creek crossing in a race…
I have used squirt in the past and found that it had good staying power but I know it doesn’t have the best results from ZFC. I also think that squirt needs to be stripped before immersion waxing again?
Are you using the Silca Endurance chip? That made a significant difference on my road bike, although I haven’t tried in on my mtb, yet.
I’ve since read on ZFC that wax on shimano seems to wear off faster than sram. So perhaps that is part of the problem…
I have applied always this way top of the chain one tiny drop by roller.. one by one.. other people made me fun at me when i did in a cycling camp in calpe where we stayed in a villa and they saw me doing it like this.
glad the internet backs me up on this one.
First things first: IME and IMO I don’t believe Silca is the kind of company you can take for their word and 200 miles is not realistic under (my) normal real life conditions.
My experience is the opposite of yours: immersion wax lasts a lot longer and drip wax. In damp conditions on the mtb I get 2 weeks (about 80 miles) from an freshly waxed chain, and about 1.5 rides off a drip-waxed chain. I use the double dip method and even on the second crockpot I get an amazing amount of scum at the bottom. I scrape that off maybe once a year.
If I were you, I’d drop a strip chip in the crock pot, just to make sure residual oil is not a factor impacting your experience. Strip chips are better than their stripper anyways.
I added a strip chip last week actually and it has been working!! Was amazed my chain held up through two rainy and wet rides.
My hypothesis is that when I initially stripped the chains I put them in an ultrasonic cleaner with degreaser and perhaps the ultrasonic actually sort of embedded the grease deeper into the crevices of the chain and the surface? And also in general I noticed that a new chain felt cleaner after just a dip in mineral spirits rather than a pass through the ultrasonic with degreaser followed by mineral spirits. So either it is the degreaser (zepp purple) or ultrasonic or both and also the strip chip.
Why does she say to run thru your gears to get a coating on the cassette? Whats the benefit of that. Noise reduction?
It’s my understanding it’s not to get it on the gears. It’s to get the chain to flex so the wax penetrates into the rollers . When I apply it, I twist the chain with my fingers. I do this before moving to the next set of links. Shifting the chain up and down the cassette makes a bit of a mess if it’s still in a liquid state. Once dry, some will transfer to the chain ring and cassette
I put a small drop all the way across from chain ring to cassette then with a nitrile gloved hand work each link back and forth through full range of motion and massage the lube into each link. Then eventually will run the chain through the cassette at the end. Works great.
I put the chain in an aggressive cross-chain (big ring in the front, biggest / 2nd biggest cog in the back) and put the bottle touching the top of the rollers and then spin the crank till I cover the entire chain. I keep spinning the cranks until I see the lube on the top of the rollers on the inside of the chain. As Josh Poitner showed in the Silca video, you want to “suck” the lube through the rollers to make sure you are fully lubing the internals
:flushed_face:
:winking_face_with_tongue:
Missed a spot :winking_face_with_tongue:
I’ve been pretty disappointed with their chain stripper, I’ve had the same experience.
I’m also getting fewer miles on a waxed chain on my MTB compared to my gravel bike, I’ve honestly just gotten into the habit of wiping the chain every few rides and applying a little bit of their drip wax. I ride in pretty hot and humid conditions in Texas.
Yoghurt!
