Are you willing to do any DIY or are you only interested in a finished solution?
What trainer do you have (since some options vary per trainer)?
Where are you located and have you checked the listings in my doc for sellers in your region?
I may be able to offer specific recommendations depending on where you are located & shopping.
As a guess, that is probably Eric Schlange of Zwift Insider. He and I have a long history of rockers and similar understanding and experience with respect to rocker setup for best motion control. In short, if people want the most “realistic” experience on a rocker plate, that means using a setup with minimal Leveling Spring Force. That is because we have minimal force when riding outside and using lower forces on rockers is the best approach with that in mind.
The mention of the Saris MP1 is for two reasons. First, their rocker is a fixed Leveling Spring Force that is not adjustable by the rider. Second, that fixed Leveling Spring Force is rather high. It offers firm support that is welcomed by many new rocker plate users, but that high force also prevents the best use of a rocker IMO. High leveling spring forces make standing efforts in particular more awkward and difficult (if not impossible) to achieve the proper Lean to Pedal timing.
So, the high force and non-adjustable nature of the Saris MP1 don’t sit well with me. Add in the exorbitant pricing they started with ($1200 USD) and still high pricing today ($950 USD) make it a terrible option IMO. I’ve seen people get them at nice discounts, and that is the only way I’d ever recommend that specific option.
I’m in New England. I would prefer to spend as $200-400 if that’s an option, but if there is a substantial quality difference then I would consider going higher. Not keen on DIY (saw your online stuff) as I don’t think I have the time. I guess I am just really interested in good adjustable lateral movement, fore-aft is less interesting. Idc about name brand as long as functionality is there
I have used one for a decent amount of time and it is great bang for buck. It comes with inflatables that are adjustable, but I ditched them entirely and relied on the rib curve for centering. It is loose in the middle and naturally increases leveling force the further the rocker & bike lean.
Ultimately, it’s slightly stiffer at the 5-7* angle than I personally like, but I am a very edge case user. I think the default curve with no inflatables is likely close to what may work well for you. Check out my pics and review here for more info. I am happy to dive deeper if you have more questions too.
I bought this and I like it. Good price for a manufactured option and gives side to side and fore aft. Does require user assembly but it’s really simple and he gives you everything you need.
Very doubtful. If it was tens of thousands of pounds and spinning at a higher rate, sure it would. A fifty pound flywheel? Sure the bearing feels it, but it’s so slight. Centrifugal force…
The magnitude of centrifugal force F on an object of [mass] m at the distance r from the origin of a frame of reference rotating with [angular velocity] ω is:
F = m ω2 r
With ω2 being ω squared.
Related: someone proclaimed that old saw about toilets ‘only’ flowing one direction in the northern hemisphere and opposite in the southern. I had a house with a toilet that rotated clockwise, and the other one rotated counterclockwise. They said I was delusional. At a party we had a bit later I showed him. DUH!! The mass of the water is so insignificant to the motion of the planet that it can flow anyway it wants. It’s just so insignificant as to be completely nonexistent. I was retelling that just this weekend. (Why do people still believe that?)
I appreciate the link again. I forget to add this to my Rocker doc before, but will get it done today.
But… Imagine my surprise as I dug in a bit to find this maker & seller is actually just 6 hours away in my home state I had no idea and should make a trip to connect with them now.
This is really good stuff and nice to find I could get into one for $150. I see that the big difference is the LifeLine is a full plate (spanning front to rear) whereas the Pod Lite only goes on the rear. Is there much difference there? Could I simply get a board the same height was the Pod Liite to stick under my front tire and be (nearly) just as well off?
Any recommendations for getting a good front wheel lockdown on a rocker? I have a custom full board (side to side only) rocker but everytime i race on sprint in a race on Zwift the front wheel always moves out of alignment. I have tried velcro straps but they dont seem to hold the wheel in place.
For starters, I and many others use proper lean timing & form on our rockers. I get great results from overall body use, power production and comfort from this correct rocking direction (bike leans away from side with foot down). That applies in the saddle as well as standing at all effort levels.
This type of use requires a very low leveling spring force (much like the minimal amount we get outside) AND active control of the handlebars by the rider (vs too many people that passively ride the bike as though it were still rigid). The two leading factors for opposite timing are people using leveling spring force that is too strong and/or passive control of the handlebars. This is all well addressed by Eric in his article.
Once you get the rocker leveling spring low enough, it’s just a matter of the rider actually using the leverage present in the handlebars to control the lean timing relative to their pedal timing. I and others wrote some guides to help people find this timing.
Opposite rocking direction is possible (bike leans towards side with foot down), but I still consider this better than rigid riding. The comfort aspect is huge for most users and can’t be ignored as a benefit regardless of the wrong lean timing.
With respect to the wrong lean timing and muscle engagement, it depends on a persons goals to some extent. Even with the wrong timing, a person is using more muscle activation when compared to a rigid setup. That is true seated as well as standing. So, if a person is just looking to be more “active” on the bike, even a rocker with wrong timing is an improvement compared to a fixed setup.
I have a more lengthy work in progress about wrong timing that is worth a look and expands on some of what I covered already.
Thanks. Currently, the trainer and front wheel has some heavy duty straps but they are a bit elasticated - the trainer doesnot move though. I didnt want to really go down the cable tie route but that may be the best way to get a decent lockdown.
If the front wheel is moving sideways, the trainer almost certainly must be twisting in those elastic straps. I personally prefer hard stops in the form of wood blocks or steel angle to restrain the trainer. Once that is done and the trainer can’t twist, the front never moves.
I use Voile straps instead of Velcro with my Velocity Rocker (https://velocityrockers.com) and a Tacx Neo 2t. I use two on each side in the back (one will do). Voile Straps Nylon Buckle — 12": Voile. I don’t use a strap in the front. I use an Elite Sterzo Smart I bought used. I don’t care about the steering, but it does allow the bars and front wheel to move a bit and I think it is more comfortable than being locked down. Even during out-of-saddle efforts, it has been pretty sturdy.
So I ended up buying the Pod lite which is due to arrive early this week. I noticed in your video that you put some weights on the side of it. I imagine was to offset the weight of the flywheel, but can you elaborate a bit on that?
Thanks
You want the bike dead center over the rocker deck, which means the left side has more weight due to the heavy flywheel on the left side of the trainer.
10 lbs [5 kg] worth on the right side is a counterweight that balances the rocker, bike and trainer. Gives is an even lean force, whether you use the inflatables or none and just the ribs.
My pod lite came today. Kinda rough unsealed wood. A few min with a palm sander and some finish to seal it up should do the trick. I’m also going to counter sink the screws a bit and putty over them to give it more of a finished look. Going to hit the thrift stores in hopes of finding a used 10lb weight.
Yeah, it is pretty much just cut plywood right from the CNC router. I build rough stuff like that and tend not to put much time into finishing. But the work you mention is a good way to go to give it some nice looking details. Would love to see what you end up with when you get it all done.
Are the Tacx T2 rocker plates of any use, any good? I hear they are expensive, but are they a waste of money, better than nothing but barely, or are they actually usable decent things?
