I’ve also had good success with Muc Off tape. It also holds up to Silca Sealant, which I was using for a while and has been reported to break down some brands of rim tape.
Before taping, really cleaning the rim bed well with isopropyl alcohol can make a big difference.
I had this happen last year where I heard something rattling with the rim but didn’t initially realize what it was. Turned out it was a broken spoken on an Enve wheel which has internal nipples. The spoke ended up coming out completely during a gravel race. Still finished the race minus one spoke but lesson learnt.
No personal experience with it but over at MTBR the stuff is pretty much hated by almost everyone that’s used it due to the residue it leaves being very difficult to remove.
I have used Muc Off tubeless tape on road wheels without major issues. I have applied it as per instructions one turn overlapping the valve hole.
I think i have only replaced one of the tape once in last 2 years or so. This is on bar or better than factory inserted tape from Roval and Reynolds. Reynolds have lasted around two year (with multiple tire changes). Roval tape lasted around one season with maybe one tire change or so.
Some residue is left behind but so from other (factory inserted) tapes and from sealant. If anyone knows better tape for high pressure use i am all ears.
As someone else said above, I’ve also had good experience with WTB and similar tape. I’ve never had it fail in 5 or 6 years. The only times I’ve re-taped a rim is because the tyre got so stuck that when taking it off, it lifted the edge of the tape off. It would have likely been fine to use and I just changed it out of precaution. No residue either, in case that is a concern.
New Canyon Endurace on the way and debating whether to go tubeless on it and have a couple of questions.
It comes with GP5000 S TR 30mm on the stock wheelset. I was thinking of swapping these over to some Hunt Aero Light wheels I have.
I’ve been running 28mm tubed GP5000 on these for the last 18 months with Conti tubes. Didn’t go tubeless initially when getting these wheels as the tyres were pretty new and not compatible.
First question is, the Hunts came tubeless ready all taped up, but is running them with tubes for 18 months likely to have caused any issues that I need to be aware of? Is it just a case of making sure the rim tape is still good, or should I start from scratch?
Second question, I’ve also picked up some TPU tubes of AliExpress. I’d be interested in people’s thoughts/experience on TPU tubes versus tubeless?
TPU is not quite as nice as latex tubes, but not having to pump your tyres before every ride is worth something. Not sure how much you paid, but the prices even on aliexpress were a bit prohibitive last I checked, and lacking niceties like removable valves means that it’s a hassle to use valve extenders - which I need.
Re your hunt wheels, how wide are they internal & external? You may be about to wreck any aero credentials by putting 30c (wider on wide rims) tyres on rims with <<30mm external width.
In my experience of running a tube in a Hunt aero wide for several months after repeated tubeless failures before giving tubeless one more go. The rim tape was fine. Just give it an inspection before you put the sealant in but a decent sealant will solve any slight imperfections in the tape. I say decent sealant because when I almost gave up on tubeless I realised it was the Finishline sealant that was duff. I had ran stans/Joes on my tubeless disc for a few years, no problem, and the hunt wheels initially were no problem either. But at some point I replaced the original sealant with FinishLine (promoted as never dries out, it never dries to seal the tiniest of holes either, the gradual loss of air causes the tyre to unseat on a minor bump like a cateye). When I realised it was the sealant that was the problem I went back to Stans/Joes and have no problem (touch wood) since; the wheels were transferred to my new bike which has now done 21,000miles no problem. I’ve also put a tube in my gravel bike wheels a couple of times but that has been short term before re-adding sealant but a tube has never done any damage there either.
I couldn’t compare to TPU tubes but for a mate who runs Tubolito’s they seem to work.
The width on the Hunts is narrower than the stock DT Swiss wheelset on the new bike. Neither are particularly aero but the Hunts are 0.5kg lighter.
Hunt 17/22/28mm vs DT Swiss 22.5/25/23mm (inner/outer/depth).
Biggest problem is likely the valve hole in the tape, which is probably wider than a tubeless valve will plug easily. If you have tubeless tape lying around, I’d put a strip over it. You could also try electrical tape, but IMO that is too flexible to work there.
I have this issue with about 90% of tubeless setups whether there’s been a tube installed or not. The solution that works every time is to cut a little square of an old inner tube, poke a hole through the middle, then stretch it over the tubeless valve before installing. The softer rubber works like a gasket to make a good seal with the rim/tape interface.
I’m not understanding the issues people are having with the tape valve hole being too big…
I’ve never had to use a supplemental gasket/piece of inner tube etc with good tubeless valves in any of my setups.
Even on wheels that were taped, then run with a tube, then set up tubeless.
The size of the valve hole in the tape is limited by the size of the actual drilled hole in the rim bed, and a tubeless valve once properly tightened down seals that.
I can see the logic in that situation, if it is not possible to then re-tape the rim. (any sort of split in the tape = should be redone imo).
Barring that though, i’m still a bit perplexed about it being an issue.
Perhaps I’ve just been lucky since I don’t do any sort of particularly special technique to create the valve hole in the tape either (I’ve seen online that people recommend all sort of strange convoluted techniques like using a red hot awl to melt a hole etc).
I’ve basically given up on tubeless with my current wheelset (Prime), which after trying a swap with another bike/set of tires I believe is a major part of my issues. Besides being a total PITA to get on, the Conti 5Ks didn’t maintain air pressure well. I tried swapping wheelsets and the Gravelkings that worked flawlessly with another wheelset (Novatec Jetflys) wouldn’t seal on the Prime wheels. Bottom line is back to tubes until a new wheelset.
I’ve had to use a section of electrical tape sometimes round the valve hole. Taped over it. then pushed the new valve through with the rubber bung on the stem and tightening of the lock nut its been fine.
Wiggle/ CRCs manufacturing can’t be the most consistent. I got Prime wheels as winter wheels and 5000TLs in the middle of my chemopherapy which wrecked my hands. I was dreading the install going on the wide reviews of 5000TL’s being hard to fit. It was the opposite though, for me they were very easy to fit even with weak and numb hands and the tyres hardly lost pressure (at most 20psi in a week). The only time I have had problems with tubeless losing pressure was when I once used FinishLine sealant, never again, I almost gave up om tubeless until I realised it was that cr@p that was the problem.
