I have absoluteblack oval rings on my hardtail and the inner ring on my road bike.
I have found (might just be in my head) that it is harder to get on top of/get in the sweetspot for a gear with the oval rings, but once you are on top of that gear, it is easier to stay there, especially when climbing.
There is a theory that oval rings reduce rear suspension bob on full sus mtbs.
I don’t know what, if any, benefits there are to oval chainrings on road but for me they are a no-brainer off-road.
None of us have perfect pedalling technique so the oval ring helps smooth that out, circling the square if you like. This manifests itself as more even power applied at the tyre contact area so on loose ground you don’t spin out as often and on snow you wouldn’t be digging the back wheel in. I was out in 15cm deep snow at the weekend and could keep pedalling for much longer than my companions, well until I ran into 30cm drifts!
If you ride up a road climb on an MTB with knobbly tyres then you can hear the difference: rather than a rhythmic “thrumm, thrumm, thrumm” as you pedal you get a near constant sound coming back from the tyre.
Chain retention: no worse or better than a round chainring but I use a 1x drivetrain with narrow-wide chainrings and get zero dropped chains even with chains that have done 3000km. In fact the NW chainring on my fat bike is missing a tooth (clumsy airport baggage handlers) and still doesn’t drop the chain.
OP - there was another thread recently about oval chainrings that might be worth reading.
I would never not run one on a mountain bike. Much better traction on loose stuff and I’ve never dropped a chain. Pros don’t run them because they arent sponsored by them. Pros aren’t paid to win races, they’re paid to be a billboard.
I’ve never dropped a chain on my MTB either and I don’t loose traction with my normal chainring. If oval chainrings were superior I’d see them at amateur races, but I rarely do. Oval chainrings may be beneficial to some with a certain pedal stroke, but I’d imagine it’s marginal at best. If it’s helped you then great, but I wouldn’t recommend it as cure all.
As I stressed in my earlier post, they are a no-brainer off-road for me, sample of n=1, etc. but most, and I stress most, of those I know who’ve tried them prefer them to round chainrings. Maybe snake oil, maybe not but these are all people like me who’ve paid money for both and could switch back should they so desire but don’t.
I wouldn’t say the benefits are something obvious like 10% better, it’s subtler than that, maybe 2-5%, just enough to notice but not something that slaps you in the face. I’m not someone who notices things like a 10mm difference in stem length that others scream about it completely changing the handling of the bike but I do notice this.
What is the supposed mechanism of better traction? I just ordered an oval ring for my XC bike, really just to try it out, not expecting massive differences
Not discounting the results or experience, but has anyone (chainring builders, or better… independent testing sites) actually shown data on this improved power application?
Not seen any, certainly not independent testing, like I said: “what I’m led to believe”.
So … a bit of research, well Googling, came up with this piece - https://gearjunkie.com/oval-bike-chainring-review in which there’s links to a couple of papers. Unfortunately both link to the same one, the conclusion of that one shows no benefit - http://ro.ecu.edu.au/cgi/viewcontent.cgi?article=7377&context=ecuworks - or at least small benefits that vary between individuals. The other paper was meant to show an improvement but since the link is broken I’ve not, yet, found it.
The next result on Google was this - https://bikefitadviser.com/oval-chainrings/ where he assesses four studies. His takeaway about oval rings is, you’ve guessed it: it depends. He quotes parts of the conclusion of each study at the foot of the piece. Interesting the last has this:
We have interpreted our results cautiously and suggest that the subjects who had greater lower limb muscle volume and greater calf muscle volume, seem to have had a significant advantage in performing with the eccentric chainring.
Though he’s not currently very popular on the TR forum due to another video, his video on oval chainrings is interesting:
Do Q-rings improve power? Here is our answer, focusing on scientific facts and evidence not speculation. Yes here at FFT we have used q-rings & osymetric for over a year. However absolute proof they help is not clear. Here we talk about the basics of the effect of non-round (oval) rings on power, torque, pedal speed, bike speed. Firstly from a lab perspective where we can test one leg at a time, then in the field two legs. Thus we address: what exactly is the “dead spot” in the pedaling motion? In the lab it is the effort the carry the leg back up to the 12oclock position, in the field it is the transition between the dominant downstrokes. Perhaps oval cranks work because of biomechanical comfort for some, perceived mechanical advantage for others. However we suggest to take into account the exact chainring size when deciding what ring is best for you. (rotor Q ring, osymmetric, doval, absolute black, ogival, one up, woolf, biopace). BTW if you were hoping for a simple “one-size fits all” answer…you will be disappointed. Non-round chainrings work for some people, sometimes for comfort, sometimes for pedal action, sometimes for power. For others they don’t. In the opinion of FFT benefits on power are mainly because of the benefit of finding more appropriate gearing/gear ratios. However benefits in comfort may be seen.
They’re the same price as a round ring, so why not just try it and decide for yourself? Other than off road traction I don’t feel any difference at all.
Lots of reports of poor front shifting and chain dropping. And an artificial 1-2% inflation in power readings. That’s the cons to non-circular chainrings that I keep reading.
I have an oval chainring on my enduro bike, dirt jumper and a normal pair of chainrings on my roadbike.
I’ve found on climbs its ‘easier’ (more consistent output of power) to pedal my enduro bike (heavier and off road) with its oval chainring than it is on my roadbike with it’s regular rings (on a road obviously ).
Not a lot of pedaling on my dirt jumper, but when when i do it’s hard and it counts. I’ve noticed zero difference having an oval chainring on that.
I’m looking to put an oval ring on my roadbike, lots of hills where I am so hoping that benefits me.
It looks like there’s a pay off between a consistent feel of pedal power against a slight loss of overall power.
I honestly think it is more of a “feel” thing — and I happen to like the feel of oval chain rings. I only have it on my mountain bike, because I have heard some power meters struggle with oval chain rings — with the exception of Rotor that is (was?) famous for power meters and oval chain rings.
