KickrV5 - drift in ERG-mode?
I have to diagree with Wahoo on this one. The power numbers transmitted over ANT+ are sent using a rolling counter update. So even if you lose a few ANT+ packets, you will still get the correct average power. It will just mean your instantaneous power will be wrong for a second or so.
The list they gave you just shows they know the product is not 1% accurate If a product says 1%, that should mean it works under all these conditions. If it doesn’t, it should be shown in detail in the manual, or on their web site.
I think there needs to be a standard testing/certification setup for all manufacturers to follow. These products are not cheap. Someone is going to get pissed off enough to start broader legal action.
@NickL and @stevemz: The 1h30min@200W in both ERG and standard mode is probably the way to go, will however try to get those assiomas first to get even better datasets. Doesnt sound like a very fun workout, so it better be worth it. I did experiment with resistance mode in TR during a workout earlier, but didnt find anything special.
Oct22, ERG+resistance mode: DC Rainmaker Analyzer
@road_wars: I completely agree with you, I was just quoting what Wahoo-support wrote, and its the same as stated on their website: KICKR Power Accuracy
Did a new workout in Sim-mode/Zwift yesterday, Quarq back to reading +1%, no drift.
Oct30, sim-mode: DC Rainmaker Analyzer
ERG-workout today, back to drifting from 2% to 6%.
Oct31, ERG mode: DC Rainmaker Analyzer
Since I did the excact same workout oct24 and oct31, I tried to compare them, the drift is almost completely similar: DC Rainmaker Analyzer
That would be great!
This was Picket Guard +2. No warmup before, no kind of calibration/spindown.
This one is super obvious! Talk about brutal at the end where you are doing the last set at 10-12w higher!
Wahoo definitely needs to fix this or send you a new unit because this just isn’t acceptable.
Very good argument for using powermatch until they do something.
So I did the 1h30min ERG@200W today, and result was a bit suprising. No drift, but one “power-jump” at 28min, when I did some low cadence out of the saddle and sat back returning to normal cadence. Really dont know what to get from this.
Nov1: DC Rainmaker Analyzer
(I normally do this between intervals, so that would mean I get several similar “power-jumps” during an interval workout.)
:thinking:
Definitely a new wrinkle to the Erg mode theory.
The only other thing that I can think of that might be going on is that during the transition from high power to low power, it’s triggering a calibration event but whiffing due to a lack of true coasting. The offset seems consistent within an interval on your Oct31 workout, but gets progressively larger.
If it’s not that, I’m out of ideas :man_shrugging:
Could be interesting to try an actual coast down during a recovery to see if that resets the drift for the following work interval.
@daniebr, have you tried an Advanced/Factory Spindown? This looks exactly like the issue I had with my KICKR '18 for months. It was a bit of a crap-shot, tried it a few times over a couple of months and eventually it seemed to fix things. Although by that time I had already ended up just getting an extra power meter to leave on the trainer bike for PowerMatch…
I wonder. Did the temperature drift in your pain cave when there was power drift? Maybe that is the difference between the drifting and non-drifting workouts?
@mcneese.chad: How would you do that? Just let the Kickr be in ERG-mode, do some fast pedaling and letting it go?
@chidlow: Im not sure how to do that, remember I did this with Snap/Kickr18, but for the KickrV5 there isnt even a spindown-button in the Wahoo-app.
@road_wars: The temperature in room drifts about 2 degrees from about 16 to 18 degrees for all workouts, less for the shortest I guess. So room temperature drifted the same for non-drift-workout-oct28 and drift-workout-oct31. I initially thougt this was a temperature-issue. But based on last workout, it doesnt seem so.
@chidlow: seems like that guide works, even though buttons are a litte different now:
I will however save the factory-spindown option for later.
Firstly I will do a new ride like yesterdays, trying to trigger the “power-jumps” as many times as I can to get a really “drifty” dataset.
Later I will see if it is possible to do a factory reset (this will disable auto-calibrate since that feature is part of the first firmware upgrade) and see if the “power-jumps” are affected by that, as mentioned by @stevemz.
Trying to do this as systematic as possible, and only change one thing at the time.
This is really interesting.
My guess would be that its getting confused trying to do it’s auto-calibration while in erg mode.
The flywheel is slowing down - because you are lowering the cadence - so the kickr thinks “i’ll do a calibration now” but simultaneously trainerroad is altering the resistance to keep your power on target - messing up the calculation.
Just a guess and if true I would have thought everyone would see it - not just you.
Yup, wait until the power drops and stabilizes in the recovery, make sure to spin 90rpm or more and just coast. I think you will get at least the 2 seconds that seem required. Let the flywheel come to a full stop to let ERG reset, then restart pedaling quickly.
See if there was drift before and/or after the spindown.
Will try this tonight. If all goes well, the power-graph will look like a ramp test…
I don’t have a kickr, but couldn’t you just pause the workout? Then the trainer will coast rather than adjust the power?
This didnt go as expected, some small “power-jumps”, largest “power-jump” is after 1h50min when Im trying to do a spindown/auto-calibration, tried two more spindowns(last one pausing the workout in wahoo-app):
Nov2: DC Rainmaker Analyzer
Im running out of ideas, asked support about how to factory reset(to see if removing auto-cal will influence something), will also try advanced spindown later.
(pausing workout didnt affect coasting time, it was like coasting in ERG-mode, trainer stops completely within 3-4sec)
A little update.
Asked Wahoo support about a factory reset. That was not possible.
Wahoo support then asked me if I was having issues with my KICKR.
I tried to explain it as good as I could. Last time I was only told that the Kickr is operating within tolerances. This time, they kind of admitted that I was experiencing a issue with my trainer, and based on my description, they said I would need to perform a factory spindown.
I did the factory spindown, and have done two workouts after.
Basically the results was pretty different for the two workouts:
  • The first one showed less drift than before. PM reading +3% at start, and +4,5% at end, which gives a drift of only 1,5%. (A litte power jump/red flag at 1h14min though)
    Nov4: DC Rainmaker Analyzer
  • The second one looked pretty similar to the old datasets again. PM reading +0% at start(which is the lowest I have ever seen in ERG-mode, seen similar in SIM-mode though), and +4% at end, which gives a drift of 4%.
    Nov5: DC Rainmaker Analyzer
At the start of the Nov5-ride I was really optimistic, readings seemed stable, and at a level pretty similar to what I have seen in sim-mode/zwift. But at the second half of the workout there was power jumps/drift again(best seen at 40min and 1h13min).
I have done a second factory spindown now, and will continue testing during the weekend.
My hope is that I can end up with a trainer that has no more than approx 1% drift, and that the difference between PM and trainer should be about the same in ERG-mode and sim-mode. That is at least what I was used to.
The last factory spindown I did (that worked for me to fix drift it seems) was one I did after a workout - much more warmup time than if you just follow the instructions in the app, or ride for 10-15 minutes easy first. YMMV - good luck!
Thanks for the tip. Did second factory spindown right after yesterdays workout, so hopefully that will give results today.
