Yup…I just placed a pre-emptive order. I won’t be able to get outside and ride the local gravel for a couple of months yet, but wanted to make sure I had them. Have an early season race in April that I want them for and didn’t want to be scrambling to find some.
Yeah I had to check it again but it’s right haha. At that surface and speed aero and CRR drag are about half and half!
Already sold out at BikeTiresDirect. Gotta use that bonkbros code! I don’t think the 2.1 is going work for my frame so I’ll be on the hunt for something slightly smaller but just as fast.
Might be worth checking European vendors even if you’re in the US…prices are usually great so even with shipping it ends up being a good deal if you stock up!
yeah, I placed my order to Merlin.
Thunder Burts are undoubtedly fast tires, but I feel like I’ve heard that they don’t last very long at all. So for gravel, that is really going to be a problem. One long race and your tires could be shot?
Yeah, I have heard the same about them so I made sure to go with the more durable but heavier casing option when I got them. As far as the durability that will just be a wait and find out sort of thing for me. Riding style and prior experience with tires should always be factored in when choosing them I think
Thunder Burts have been known as one of, if not the fastest tire out there (For a while now, this isn’t a new thing that should cause them to fly off the shelves). The issue is they’re fragile and can be low on traction. Great tire in the right scenario, but it’s not all that fast to tear a sidewall.
This is the main reason everyone likes the race king - almost as fast, better traction, and more durable. If they only made it in a 2.1" and a 2.4"
Take someone like DJ - wouldn’t run the Burt in an event like Unbound despite knowing how fast they are because of the puncture risk.
I ordered my thunder Burt super ground from modernbike.com a few weeks ago without issues: https://www.modernbike.com/schwalbe-thunder-burt-tire---29-x-2.1-tubeless-folding-black-evolution-super-ground-addix-speed
This weekend will be the first time taking the thunder burts on gravel. Had only had them on pavement this far. 60 mile ride/race with 2000’ climbing. Race is Sunday but looking like quite a bit of rain. I’m still recovering from a crash in November (fractured scapula) - so I may just go do the course tomorrow at 100% effort to test my fitness and try the new tires off road. No need to go through the mud/risk for a local C race. We’ll see if the weather changes.
I’m not sure that I’ll have that objective of data riding without a comparison on the same route solo on different tires, but we’ll see.
I’m not too thrilled on the comments of the fragile walls as I value durability a lot. One flat that doesn’t seal quickly destroys some watts savings, ten fold if you lose your group. I am only 157 lbs and running just over 4 oz of orange seal, so should be sufficient.
I have ThunderBurts on my 650b wheels and last spring did a ride that had a fairly long stretch of mud / slop. Gotta say they weren’t the best in those conditions. Slid out a couple of times while my buddies rode through cleanly.
So if you are worried about them in mud, you might want to make a different choice (at least based on my experience).
Sorta been on a testing spree with gravel and mtb tires the last few months.
Local gravel racing where I am can be a mix of rough forest road climbs, hard pack flat ag land roads and smooth tarmac.
Currently on a set of 40mm Terra Speeds on my aero wheelset, and a set of Hardpacks on my “rowdy” wheels. I’ve also had wtb raddler’s and Maxxis ramblers on those rowdy wheels. Hardpacks all the way in anything rough, loose or wet.
The hardpacks ARE noticeably slower than the terra speeds on anything flat or climbing. Heavier feeling too.
Have a set of Caracal races, and 2.1 thunderburt’s on the way. I also intend to test the G-One RS when I can get my hands on them.
The hardpacks have gotta be the weirdest handling tire I’ve ridden. They are OK just going on a straight line, but once that bike starts moving around ![]()
2.4 is coming soon apparently. I’ve been using 2.2 RK rear on an old single speed and it’s an absolute killer tire. Aspen 2.25 front there fwiw.
Yeah I’ll likely hit the route tomorrow before the rain comes in and just forego the race.
Do you have suggestions on a decent mud tire? I don’t really have clearance for mud anyways so would probably throw on something smaller or use my old diverge for mud.
It’s the squared off edge. I think it’s what makes it feel so stable descending. You gotta lean hard to transition to the knobs.
Yeah, I have a bunch of experience on the 2.2. I’ve beat it up on two trips to Leadville and two mud pit events at Lutsen and a bunch of training too. Only reason I’d pick a Burt instead is more sizes.
Edit - Pretty sure I let you know about the 2.4 RK in the Race Tire Thread too ![]()
I don’t, unfortunately. The gravel trails we have around here are packed sand / dirt with kitty litter on top, so they drain really well. There are just a few sections on the lower half of the trail system we ride that can get sloppy, so I really don’t have a need for a mud tire.
I have swapped summer Thunder Burts for Racing Ray+Ralph combo for the winter mud. They are 2.1, so I poke the mud out with a stick every now and again and use protective tape on the frame where clearance is tight.
The G-One RS Pro 50 is probably the best candidate there. Will be interesting to see how it tests on BRR.
I’m very excited that the Burts tested so well. I’ve been running them for a while and really like them, but from the earlier testing (and particularly the poor performance of the Hardpack) I was worried that they simply weren’t big enough. I can’t fit anything bigger so this test result makes me very happy (although it does mean I don’t have any excuses to get a new bike!)
Rene Herse makes gravel tires in 44, 48 and 55. I ride 44 Extra light slicks on my GRoad bike and the 55 slicks on my commuter and they both feel (and the 44 EL tested) super fast. Somehow those tires never come up in those discussions and I haven’ seen anyone else, besides Jan Heine, make claims about how fast they are. Is there a reason for this? Maybe due to cost?
