The weight difference has me believing the tire has pretty thin rubber. They had made it pretty thick, soft rubber. Now it should be about TT tire thick at around 1.1mm looking at the weight and the older slick. This is likely targeting sand racing.
I used to use the 30c G-one speed as my winter road tires, as they used to be basically a larger Pro One that didn’t spray water or attach to road debris as much…. Then they went e-bike casing/rubber.
G-one RS in black wall - that’s interesting to me.
I tried these (this version, at least: https://r2-bike.com/SCHWALBE-Tire-G-ONE-Speed-29-x-235-Super-Ground-ADDIX-SpeedGrip-EVO-SnakeSkin-TLE) last year and found they handled really weird. Being so large, but so light, they kinda bounced like basketballs. They also exhibited this weird wandering behavior – it was especially scary on hardpacked ruts. I actually had a big, high-speed crash I attribute to it.
I’m a big-volume, fast-rolling tire proponent, but something about these was really off.
Been really happy with Tufo’s Speedero 44. Before that I was on Terra Speed 45s, which rode awesome, but I had several punctures.
If you’re not set on schwalbe, rene herse makes slicks for gravelbikes in 38, 44, 48, 55mm which are really fast, especially their extralight variants. I run 44 and 55on two bikes and really like them. They are expensive though.
When running a 40mm tire on a 40mm rim do you have any problem with the tire sidewall being more exposed to damage from rocks? The new zipp xlpr wheels with 40/32 ext/iw has had a lot of forum chatter about the sidewall being exposed to damage and the tire being square profile instead of round making it poor cornering.
I’m thinking of running 2 configs, 45mm gravel tires and mtb tires, but may also run 40mm, so I’ve been debating what width of gravel wheelset to get, was thinking of the reserve 40/44 GR also which is 36/34 wide.
How are the terra speed 45s? Do you have the black or tan sidewall? Tan is thinner/faster per brr. I have terra speed 40s which I really like, haven’t had the clearance for 45s but my new bike will so debating which one, have been assuming 45 is better on a wide rim, by wide I mean 34mm+.
“The Schwalbe Thunder Burts don’t handle well,” Johnson said. “They’re extremely sketchy, but it was a risk I’m willing to take considering that this is probably the fastest tire that you can buy. I am not sponsored by them so that’s coming straight from heart when I say that.”
I post this as a FYI for people thinking fast rolling tires are the only thing that is important. Remember you got to corner too. The god has spoken.
TB as a rear tire for pro riders is common enough around euro mtb marathons (most are like tough gravel races).
TB at the front is so rare, I only see it in flow trail and hardpack heavy races and under very skilled pros. Like the ones who raced bmx when they were 3. And they keep crashing compared to other pros.
Of course there are sponsorships and not all of them have the choice.
His comments were in the context of racing at Leadville.
The Thunder Burt can be sketchy for MTB, but I can’t see how this applies to gravel. It’s got taller knobs than most gravel tires and the additional width provides more traction as well.
Going from Pathfinder Pro 47/Thundero 48/Terra Speed 45 to TB 2.1 or 2.35 was a big improvement in handling.
Sure, going from a Mezcal or DHF/DHR to the TB would probably be a big downgrade but I don’t think anyone is doing that. They’re going from ~47mm gravel to 2.1/2.2 MTB.
That doesn’t make any sense. I’ve lost track of how many “original gravel race” I’ve seen, I’m sure there will be a new one next year.
Regardless, it doesn’t matter, people will find out how much traction the TBs have on gravel, or not, immediately. Did you find the Thunder Burt sketchy for gravel? Compared to what?
Or not. My coach insisted that ardent race tires were much better than race kings or Thunder Burts for Leadville. Didn’t give brr or my field testing any credence. She said she had an 8 1/2 hour rider on ardent race so that’s how she knew they were the best. It was at that point I went rouge. It may not be that unrealistic to believe fast tires will continue to be an advantage.
I really feel bad for one of her athletes running slow tires. She is about 100#’s, missed the twin lakes cutoff by a single minute. She got passed by a zillion people on the rollout (being so light with slow tires), had to walk the entirety of Kevens, then legs were shot. Fast tires and “get on the wheels of the big Florida boys then drop them on the climb” would have been my advice. I was also told my 28t ring was a terrible idea as an 11 hour rider (you’ll be spun out) but as you might guess it was great and I spent more time in the 28x52 than any other gear. Not spun out a single time. Honestly it was 8 months of one fight after another. She’s no longer working with Boundless “values no longer align”. I got my entry but absolutely nothing else other than frustration with the coaching plan. A few other athletes and I have reached out to boundless for some type of closure but so far radio silence. Some of the other coaches seem to really have their act together so it may be luck of the draw.
Well, at least you got something out of it… Smart on your part ignoring her advice and rolling the 28 ring. There are situations where I might suggest someone pick a slower/grippier tire at leadville, but only if the rider was a really, really nervous bike handler and they understood they are prioritizing grip over quick.
I ran a thunder burt rear but racing ray front so right with you there on a grippier front if needed and it was probably the right choice. In Florida TB front can work but on that loose rocky stuff where the edge knobs aren’t always engaged I just didn’t have the guts to go for it. Kudos to anybody in TBs or aspens or similar who lived to tell the tale lol.
