Why does it have to be a sub-compact? If the chainring bolts are the problem, wouldn’t you need to find something with a different bcd? Or can you go 1x with a direct mount chainring?
You really should. From some quick Googling I’m pretty sure Trek sold the last gen Emonda with Force eTap AXS stock. I cant imagine they sent them out the door with chainring bolts hitting the frame.
Yeah I’ve done some digging here as well. Even if they didn’t sell it with AXS as stock, it was available as a frameset only, and nowhere on the website are any incompatibilities stated.
My problem, though, is I’m not the original owner, so I’m essentially dependent on Trek’s goodwill here.
I have contacted the eBay seller, pointed out the problem and asked for details of original purchase in the faint hope it might help.
Quite probably that guy was running a Shimano drivetrain and hasn’t had problems. I really find it unlikely that this person would even think in this direction.
I’d get in touch with Trek and see if they can accommodate you. Or you have to sell that frame. Sorry to hear, your build seemed to have gone flawlessly and quickly from inception to finished bike.
Is there enough play to shim the drive side end of the crank spindle by 0.5-1mm? Maybe a slight bodge, but would probably stop the rubbing. Shouldn’t be an issue for the front derailleur either, but you’d want to set up its adjustment again.
