Have been posting my experiences with my Halcyon on the Cyclechat thread:
August 2021
Not quite twelve months on, and another linear actuator bites the dust. I’ve put about 2,500 miles on it at >230W, so probably over 130 hours. Replaced from my little stock of actuators from those nice people at Actuonix. It now seems less likely that it was a faulty batch of actuators originally. When testing the actuators off the frame, don’t get a finger trapped in the mechanism as no mercy will be shown - don’t ask me how I know! With careful alignment and a home-made wobble board there is no wheel rub, and it’s good for >600W and 10% hills. Really like riding the Halcyon, not wanting to use anything else, but do expect the actuator on the other side to fail in the next few weeks.
September 2021:
This week my Halcyon has decided not to charge. In the process of running a very low battery for a few days it managed to brick itself again - this being a recognised problem with low battery. The Chinesium 18350 1200mAh battery was the original, so I substituted another battery (same make) and after unbricking the unit using the link to the instructions posted earlier, was again able to establish communication with the Stac Zero app. Happily this seems to confirm that the ‘new’ battery is charging - the Halcyon lives to fight me another day!
Update - New battery was actually charging during my ride, when the old one at best lost a few percent, the old battery also not charging in a separate charger, so definitely a dud battery - not a fault with the Halcyon which is working well again.
Update 2 - The ‘new’ battery typically starts at 99% charge, but drops to 81% during my ride, then recharges back to 87% by the end of the ride. Shades of what the original battery did right from the start until total failure. This might of course be intentional, but it does seem odd. Have now got a brand new battery and will try that next.
October 2021:
With my Halcyon having a steadily reducing charge visible on the phone app, I decided it was time to fit the new battery. This requires complete disassembly of the trainer and re-alignment of the magnets afterwards. To put it mildly, I was not amused to find that my new 18350 cell wouldn’t fit. How can this be you say? Well it seems not all 18350 cells are equal. In addition to the various capacities available some have add-ons that make them longer. My new cell had a button, this made it too long to fit, so an honest mistake in not buying the flat version; except, it’s not as simple as that, because the Trustfire battery supplied was also longer than ‘standard’ having PCB protection making it 36mm long. As far as I can tell, the only maker of such a battery is Trustfire, and these apparently unique batteries are only available via Amazon:
TrustFire 18350 Li-Ion Battery 3.7 V 1200 mAh PCB Protection Circuit (2 x Flat Top)
Since they are only available in pairs and I rarely use Amazon that’s £20 with postage!
December 2021:
New battery from Amazon still not fitted yet, as having eventually been externally charged, that original ‘dud’ battery is still showing 80% charge at the end of a ride. No sign of that second (fourth) actuator failure either. Both actuator cables now taped to the motherboard connectors with insulating tape.
